ABAQUS - how to multi cut the result leaving a slice portion of parts
Dear ABAQUS user,
I'm trying to cut the analysis result view by using multi cut. the shape is cylinder (attached pic).
I've been trying to use multi cut option from Tools - View Cut - Manager and do many 'plane cut' combinations,
but i couldn't get the slice cut what i want.
Is it possible to do by multiple view cut?
Thanks in advance
Thanks in advance
RE: ABAQUS - how to multi cut the result leaving a slice portion of parts
Maybe someone knows of a solution. Otherwise you can perhaps find a way to mark the area you are interested in and create a displaygroup of those elements.
Cheers
