NX Journal and Block UI Styler combination
Hi all, with the help of ufsure, I've learnt to combined a journal code with the UI Block Styler so as to retrieve the input co-ordinate values from the block dialog into my journal code.
The code was changed from
NXOpen.Point3d originPoint1 = new NXOpen.Point3d(0.0, 0.0, 0.0);
blockFeatureBuilder1.SetOriginAndLengths(originPoint1, "100", "100", "100");
to
NXOpen.Point3d originPoint1 = new NXOpen.Point3d(coOrds[0], coOrds[1], coOrds[2]);
This allowed me to change the co-ordinate to where the block will be created at.
Now i am trying to retrieve values to change the dimension of the block but am unable to succeed.
How do i convert the value into a string so that it can be used to replaced "100" ?
Below attached is my code :
// WARNING!! This file is overwritten by the Block UI Styler while generating
// the automation code. Any modifications to this file will be lost after
// generating the code again.
// Filename: C:\Users\MTS PG 6\Desktop\BlockDialog2.cs
// This file was generated by the NX Block UI Styler
// Created by: MTS PG 6
// Version: NX 10
// Date: 04-21-2017 (Format: mm-dd-yyyy)
// Time: 11:20 (Format: hh-mm)
// Purpose: This TEMPLATE file contains C# source to guide you in the
// construction of your Block application dialog. The generation of your
// dialog file (.dlx extension) is the first step towards dialog construction
// within NX. You must now create a NX Open application that
// utilizes this file (.dlx).
// The information in this file provides you with the following:
// 1. Help on how to load and display your Block UI Styler dialog in NX
// using APIs provided in NXOpen.BlockStyler namespace
// 2. The empty callback methods (stubs) associated with your dialog items
// have also been placed in this file. These empty methods have been
// created simply to start you along with your coding requirements.
// The method name, argument list and possible return values have already
// been provided for you.
//These imports are needed for the following template code
using System;
using NXOpen;
using NXOpen.BlockStyler;
//Represents Block Styler application class
public class BlockDialog2
//class members
private static Session theSession = null;
private static UI theUI = null;
private string theDlxFileName;
private NXOpen.BlockStyler.BlockDialog theDialog;
private NXOpen.BlockStyler.Group group0;// Block type: Group
private NXOpen.BlockStyler.IntegerBlock integer0;// Block type: Integer
private NXOpen.BlockStyler.IntegerBlock integer01;// Block type: Integer
private NXOpen.BlockStyler.IntegerBlock integer02;// Block type: Integer
private NXOpen.BlockStyler.Group group01;// Block type: Group
private NXOpen.BlockStyler.LinearDimension linear_dim0;// Block type: Linear Dim
private NXOpen.BlockStyler.LinearDimension linear_dim01;// Block type: Linear Dim
private NXOpen.BlockStyler.LinearDimension linear_dim02;// Block type: Linear Dim
//Bit Option for Property: SnapPointTypesOnByDefault
public static readonly int SnapPointTypesOnByDefault_UserDefined = (1 << 0);
public static readonly int SnapPointTypesOnByDefault_Inferred = (1 << 1);
public static readonly int SnapPointTypesOnByDefault_ScreenPosition = (1 << 2);
public static readonly int SnapPointTypesOnByDefault_EndPoint = (1 << 3);
public static readonly int SnapPointTypesOnByDefault_MidPoint = (1 << 4);
public static readonly int SnapPointTypesOnByDefault_ControlPoint = (1 << 5);
public static readonly int SnapPointTypesOnByDefault_Intersection = (1 << 6);
public static readonly int SnapPointTypesOnByDefault_ArcCenter = (1 << 7);
public static readonly int SnapPointTypesOnByDefault_QuadrantPoint = (1 << 8);
public static readonly int SnapPointTypesOnByDefault_ExistingPoint = (1 << 9);
public static readonly int SnapPointTypesOnByDefault_PointonCurve = (1 <<10);
public static readonly int SnapPointTypesOnByDefault_PointonSurface = (1 <<11);
public static readonly int SnapPointTypesOnByDefault_PointConstructor = (1 <<12);
public static readonly int SnapPointTypesOnByDefault_TwocurveIntersection = (1 <<13);
public static readonly int SnapPointTypesOnByDefault_TangentPoint = (1 <<14);
public static readonly int SnapPointTypesOnByDefault_Poles = (1 <<15);
public static readonly int SnapPointTypesOnByDefault_BoundedGridPoint = (1 <<16);
public static readonly int SnapPointTypesOnByDefault_FacetVertexPoint = (1 <<17);
//Constructor for NX Styler class
public BlockDialog2()
try
theSession = Session.GetSession();
theUI = UI.GetUI();
theDlxFileName = "BlockDialog2.dlx";
theDialog = theUI.CreateDialog(theDlxFileName);
theDialog.AddApplyHandler(new NXOpen.BlockStyler.BlockDialog.Apply(apply_cb));
theDialog.AddOkHandler(new NXOpen.BlockStyler.BlockDialog.Ok(ok_cb));
theDialog.AddUpdateHandler(new NXOpen.BlockStyler.BlockDialog.Update(update_cb));
theDialog.AddInitializeHandler(new NXOpen.BlockStyler.BlockDialog.Initialize(initialize_cb));
theDialog.AddDialogShownHandler(new NXOpen.BlockStyler.BlockDialog.DialogShown(dialogShown_cb));
catch (Exception ex)
//---- Enter your exception handling code here -----
throw ex;
//------------------------------- DIALOG LAUNCHING ---------------------------------
// Before invoking this application one needs to open any part/empty part in NX
// because of the behavior of the blocks.
// Make sure the dlx file is in one of the following locations:
// 1.) From where NX session is launched
// 2.) $UGII_USER_DIR/application
// 3.) For released applications, using UGII_CUSTOM_DIRECTORY_FILE is highly
// recommended. This variable is set to a full directory path to a file
// containing a list of root directories for all custom applications.
// e.g., UGII_CUSTOM_DIRECTORY_FILE=$UGII_ROOT_DIR\menus\custom_dirs.dat
// You can create the dialog using one of the following way:
// 1. Journal Replay
// 1) Replay this file through Tool->Journal->Play Menu.
// 2. USER EXIT
// 1) Create the Shared Library -- Refer "Block UI Styler programmer's guide"
// 2) Invoke the Shared Library through File->Execute->NX Open menu.
public static void Main()
BlockDialog2 theBlockDialog2 = null;
try
theBlockDialog2 = new BlockDialog2();
// The following method shows the dialog immediately
theBlockDialog2.Show();
theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString());
finally
if(theBlockDialog2 != null)
theBlockDialog2.Dispose();
// This method specifies how a shared image is unloaded from memory
// within NX. This method gives you the capability to unload an
// internal NX Open application or user exit from NX. Specify any
// one of the three constants as a return value to determine the type
// of unload to perform:
// Immediately : unload the library as soon as the automation program has completed
// Explicitly : unload the library from the "Unload Shared Image" dialog
// AtTermination : unload the library when the NX session terminates
// NOTE: A program which associates NX Open applications with the menubar
// MUST NOT use this option since it will UNLOAD your NX Open application image
// from the menubar.
public static int GetUnloadOption(string arg)
//return System.Convert.ToInt32(Session.LibraryUnloadOption.Explicitly);
return System.Convert.ToInt32(Session.LibraryUnloadOption.Immediately);
// return System.Convert.ToInt32(Session.LibraryUnloadOption.AtTermination);
// Following method cleanup any housekeeping chores that may be needed.
// This method is automatically called by NX.
public static void UnloadLibrary(string arg)
try
//---- Enter your code here -----
//This method shows the dialog on the screen
public NXOpen.UIStyler.DialogResponse Show()
try
theDialog.Show();
return 0;
//Method Name: Dispose
public void Dispose()
if(theDialog != null)
theDialog.Dispose();
theDialog = null;
//---------------------Block UI Styler Callback Functions--------------------------
//Callback Name: initialize_cb
public void initialize_cb()
try
group0 = (NXOpen.BlockStyler.Group)theDialog.TopBlock.FindBlock("group0");
integer0 = (NXOpen.BlockStyler.IntegerBlock)theDialog.TopBlock.FindBlock("integer0");
integer01 = (NXOpen.BlockStyler.IntegerBlock)theDialog.TopBlock.FindBlock("integer01");
integer02 = (NXOpen.BlockStyler.IntegerBlock)theDialog.TopBlock.FindBlock("integer02");
group01 = (NXOpen.BlockStyler.Group)theDialog.TopBlock.FindBlock("group01");
linear_dim0 = (NXOpen.BlockStyler.LinearDimension)theDialog.TopBlock.FindBlock("linear_dim0");
linear_dim01 = (NXOpen.BlockStyler.LinearDimension)theDialog.TopBlock.FindBlock("linear_dim01");
linear_dim02 = (NXOpen.BlockStyler.LinearDimension)theDialog.TopBlock.FindBlock("linear_dim02");
//Callback Name: dialogShown_cb
//This callback is executed just before the dialog launch. Thus any value set
//here will take precedence and dialog will be launched showing that value.
public void dialogShown_cb()
try
//---- Enter your callback code here -----
//Callback Name: apply_cb
public int apply_cb()
int errorCode = 0;
try
double[] coOrds = new double[3];
coOrds[0] = (double)integer0.Value;
coOrds[1] = (double)integer01.Value;
coOrds[2] = (double)integer02.Value;
double[] dimension = new double[3];
dimension[0] = (double)linear_dim0.Value;
dimension[1] = (double)linear_dim01.Value;
dimension[2] = (double)linear_dim02.Value;
CreateBlock(coOrds);
errorCode = 1;
return errorCode;
//Callback Name: update_cb
public int update_cb( NXOpen.BlockStyler.UIBlock block)
try
if(block == integer0)
//---------Enter your code here-----------
else if(block == integer01)
else if(block == integer02)
else if(block == linear_dim0)
else if(block == linear_dim01)
else if(block == linear_dim02)
return 0;
//Callback Name: ok_cb
public int ok_cb()
int errorCode = 0;
try
errorCode = apply_cb();
errorCode = 1;
return errorCode;
//Function Name: GetBlockProperties
//Returns the propertylist of the specified BlockID
public PropertyList GetBlockProperties(string blockID)
PropertyList plist =null;
try
plist = theDialog.GetBlockProperties(blockID);
return plist;
public void CreateBlock(double[] coOrds)
NXOpen.Session theSession = NXOpen.Session.GetSession();
NXOpen.Part workPart = theSession.Parts.Work;
NXOpen.Part displayPart = theSession.Parts.Display;
NXOpen.Features.Feature nullNXOpen_Features_Feature = null;
NXOpen.Features.BlockFeatureBuilder blockFeatureBuilder1;
blockFeatureBuilder1 = workPart.Features.CreateBlockFeatureBuilder(nullNXOpen_Features_Feature);
NXOpen.Features.Feature feature1;
feature1 = blockFeatureBuilder1.CommitFeature();
Thank you in advance for the help ! Much appreciated !
RE: NX Journal and Block UI Styler combination
CODE --> c#
int x = 100;
string expression = x.ToString();
Hi
A long time ago I wrote a program that uses a block styler
And I'm lazy to review my code and reduce it to a short and simple program
so I present the program as it is and I believe you will know how to
pull out what you want from it.
CODE -->
'  WARNING!!  This file is overwritten by the Block Styler while generating
'  the automation code. Any modifications to this file will be lost after
'  generating the code again.
'       Filename:  C:\HoneyCombHolesSketch.vb
'        This file was generated by the NX Block Styler
'        Created by: Internet
'              Version: NX 6
'              Date: 04-28-2014  (Format: mm-dd-yyyy)
'              Time: 19:34 (Format: hh-mm)
'  Purpose:  This TEMPLATE file contains VB.NET source to guide you in the
'  construction of your Block application dialog. The generation of your
'  dialog file (.dlx extension) is the first step towards dialog construction
'  within NX.  You must now create a NX Open application that
'  utilizes this file (.dlx).
'  The information in this file provides you with the following:
'  1.  Help on how to load and display your Block Styler dialog in NX
'      using APIs provided in NXOpen.BlockStyler namespace
'  2.  The empty callback methods (stubs) associated with your dialog items
'      have also been placed in this file. These empty methods have been
'      created simply to start you along with your coding requirements.
'      The method name, argument list and possible return values have already
'      been provided for you.
'These imports are needed for the following template code
Option Strict Off
Imports System
Imports System.Environment
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.BlockStyler
'Represents Block Styler application class
Public Class HoneyCombROCEPatterns
    'class members
    Private Shared theSession As Session
    Private Shared theUI As UI
    Public Shared theHoneyCombROCEPatterns As HoneyCombROCEPatterns
    Private theDialogName As String
    Private theDialog As NXOpen.BlockStyler.BlockDialog
    Private grpOptions As NXOpen.BlockStyler.UIBlock' Block type: Group
    Private SelectOption As NXOpen.BlockStyler.UIBlock' Block type: Enumeration
    Private grpType As NXOpen.BlockStyler.UIBlock' Block type: Group
    Private SelectPatternType As NXOpen.BlockStyler.UIBlock' Block type: Enumeration
    Private grpSpecifyPoint As NXOpen.BlockStyler.UIBlock' Block type: Group
    Private SelectPoint As NXOpen.BlockStyler.UIBlock' Block type: Specify Point
    Private grpSpecifyOrientation As NXOpen.BlockStyler.UIBlock' Block type: Group
    Private SelectManip As NXOpen.BlockStyler.UIBlock' Block type: Specify Orientation
    Private grpData As NXOpen.BlockStyler.UIBlock' Block type: Group
    Private DataHoneyCombW As NXOpen.BlockStyler.UIBlock' Block type: Double
    Private DataHoneyCombH As NXOpen.BlockStyler.UIBlock' Block type: Double
    Private DataHole As NXOpen.BlockStyler.UIBlock' Block type: Double
    Private DataSpace As NXOpen.BlockStyler.UIBlock' Block type: Double
    Private QTYholes As NXOpen.BlockStyler.UIBlock' Block type: Integer
    Private DataAdjut As NXOpen.BlockStyler.UIBlock' Block type: Double
    Private DataLabel As NXOpen.BlockStyler.UIBlock' Block type: Label
    'Bit Option for Property: SnapPointTypesEnabled
    Public Shared ReadOnly              SnapPointTypesEnabled_UserDefined =     1
    Public Shared ReadOnly                 SnapPointTypesEnabled_Inferred =     2
    Public Shared ReadOnly           SnapPointTypesEnabled_ScreenPosition =     4
    Public Shared ReadOnly                 SnapPointTypesEnabled_EndPoint =     8
    Public Shared ReadOnly                 SnapPointTypesEnabled_MidPoint =    16
    Public Shared ReadOnly             SnapPointTypesEnabled_ControlPoint =    32
    Public Shared ReadOnly             SnapPointTypesEnabled_Intersection =    64
    Public Shared ReadOnly                SnapPointTypesEnabled_ArcCenter =   128
    Public Shared ReadOnly            SnapPointTypesEnabled_QuadrantPoint =   256
    Public Shared ReadOnly            SnapPointTypesEnabled_ExistingPoint =   512
    Public Shared ReadOnly             SnapPointTypesEnabled_PointonCurve =  1024
    Public Shared ReadOnly           SnapPointTypesEnabled_PointonSurface =  2048
    Public Shared ReadOnly         SnapPointTypesEnabled_PointConstructor =  4096
    Public Shared ReadOnly     SnapPointTypesEnabled_TwocurveIntersection =  8192
    Public Shared ReadOnly             SnapPointTypesEnabled_TangentPoint = 16384
    Public Shared ReadOnly                    SnapPointTypesEnabled_Poles = 32768
    'Bit Option for Property: SnapPointTypesOnByDefault
    Public Shared ReadOnly          SnapPointTypesOnByDefault_UserDefined =     1
    Public Shared ReadOnly             SnapPointTypesOnByDefault_Inferred =     2
    Public Shared ReadOnly       SnapPointTypesOnByDefault_ScreenPosition =     4
    Public Shared ReadOnly             SnapPointTypesOnByDefault_EndPoint =     8
    Public Shared ReadOnly             SnapPointTypesOnByDefault_MidPoint =    16
    Public Shared ReadOnly         SnapPointTypesOnByDefault_ControlPoint =    32
    Public Shared ReadOnly         SnapPointTypesOnByDefault_Intersection =    64
    Public Shared ReadOnly            SnapPointTypesOnByDefault_ArcCenter =   128
    Public Shared ReadOnly        SnapPointTypesOnByDefault_QuadrantPoint =   256
    Public Shared ReadOnly        SnapPointTypesOnByDefault_ExistingPoint =   512
    Public Shared ReadOnly         SnapPointTypesOnByDefault_PointonCurve =  1024
    Public Shared ReadOnly       SnapPointTypesOnByDefault_PointonSurface =  2048
    Public Shared ReadOnly     SnapPointTypesOnByDefault_PointConstructor =  4096
    Public Shared ReadOnly SnapPointTypesOnByDefault_TwocurveIntersection =  8192
    Public Shared ReadOnly         SnapPointTypesOnByDefault_TangentPoint = 16384
    Public Shared ReadOnly                SnapPointTypesOnByDefault_Poles = 32768
    'my class members
    Dim PointOnface As Boolean = False
    Dim Manipulator As Boolean = False
    Dim applyin As Boolean = False
    Dim None As Boolean = False
    Dim Rectangular As Boolean = False
    Dim needDeleteRectangular As Boolean = False
    Dim Oval As Boolean = False
    Dim needDeleteOval As Boolean = False
    Dim Circular As Boolean = False
    Dim needDeleteCircular As Boolean = False
    Dim Elliptic As Boolean = False
    Dim needDeleteElliptic As Boolean = False
    Dim ufs As UFSession
    Dim facetag As Tag = Tag.Null
    Dim myPointTag As Tag = Tag.Null
    Dim cp(2) As Double
    Dim origin1 As Point3d
    Dim matrix1 As Matrix3x3
    Dim Honeycomb_Y As Double
    Dim Honeycomb_X As Double
    Dim holesDia As Double
    Dim holesSpace As Double
    Dim adjustment As Double
    Dim arcs(-1) As Arc
    Dim arc_ref As Arc = Nothing
    Dim ellipse_ref As Ellipse = Nothing
    Dim oval_ref_1 As Line = Nothing
    Dim oval_ref_2 As Arc = Nothing
    Dim oval_ref_3 As Line = Nothing
    Dim oval_ref_4 As Arc = Nothing
    Dim rect_ref_1 As Line = Nothing
    Dim rect_ref_2 As Line = Nothing
    Dim rect_ref_3 As Line = Nothing
    Dim rect_ref_4 As Line = Nothing
    Dim arcs_cnt As Integer
    Dim refs_cnt As Integer
    Dim geom2_cnt As Integer
    Dim needDelete As Boolean = False
    Dim wp_wcs_matrix3x3 As Matrix3x3
    Dim wp_wcs_origin As Point3d
#Region "Block Styler Dialog Designer generator code"
    'Constructor for NX Styler class
    Public Sub New()
        Try
            ufs = UFSession.GetUFSession()
            theUI = UI.GetUI()
            theDialogName = "C:\HoneyCombROCEPatterns3.dlx"
            theDialog = theUI.CreateDialog(theDialogName)
            theDialog.AddApplyHandler(AddressOf apply_cb)
            theDialog.AddOkHandler(AddressOf ok_cb)
            theDialog.AddUpdateHandler(AddressOf update_cb)
            theDialog.AddCancelHandler(AddressOf cancel_cb)
            theDialog.AddInitializeHandler(AddressOf initialize_cb)
            theDialog.AddDialogShownHandler(AddressOf dialogShown_cb)
        Catch ex As Exception
            '---- Enter your exception handling code here -----
            Throw ex
        End Try
    End Sub
#End Region
    '------------------------------- DIALOG LAUNCHING ---------------------------------
    '    Before invoking this application one needs to open any part/empty part in NX
    '    because of the behavior of the blocks.
    '    Make sure the dlx file is in one of the following locations:
    '        1.) From where NX session is launched
    '        2.) $UGII_USER_DIR/application
    '        3.) For released applications, using UGII_CUSTOM_DIRECTORY_FILE is highly
    '            recommended. This variable is set to a full directory path to a file
    '            containing a list of root directories for all custom applications.
    '            e.g., UGII_CUSTOM_DIRECTORY_FILE=$UGII_ROOT_DIR\menus\custom_dirs.dat
    '    You can create the dialog using one of the following way:
    '    1. Journal Replay
    '        1) Replay this file through Tool->Journal->Play Menu.
    '    2. USER EXIT
    '        1) Create the Shared Library -- Refer "Block Styler programmer's guide"
    '        2) Invoke the Shared Library through File->Execute->NX Open menu.
    Public Shared Sub Main()
      Dim ui As UI = UI.GetUI()
      Dim theSession As Session = Session.GetSession()
      Dim workPart As Part = theSession.Parts.Work
      Dim wp_wcs_origin As Point3d = workPart.WCS.Origin
      Dim wp_wcs_matrix3x3 As Matrix3x3 = workPart.WCS.CoordinateSystem.Orientation.Element
        'ui.NXMessageBox.Show("Information",NXMessageBox.DialogType.Information, _
                                                '"*** Helo HoneyCombROCEPatterns ***")
        Try
            theHoneyCombROCEPatterns = New HoneyCombROCEPatterns()
            theHoneyCombROCEPatterns.wp_wcs_origin = wp_wcs_origin
            theHoneyCombROCEPatterns.wp_wcs_matrix3x3 = wp_wcs_matrix3x3
            ' The following method shows the dialog immediately
            theHoneyCombROCEPatterns.Show()
                                                '"*** Bye HoneyCombROCEPatterns ***")
             theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
        Finally
            theHoneyCombROCEPatterns.Dispose()
        End Try
    End Sub
    ' This method specifies how a shared image is unloaded from memory
    ' within NX. This method gives you the capability to unload an
    ' internal NX Open application or user  exit from NX. Specify any
    ' one of the three constants as a return value to determine the type
    ' of unload to perform:
    '    Immediately : unload the library as soon as the automation program has completed
    '    Explicitly  : unload the library from the "Unload Shared Image" dialog
    '    AtTermination : unload the library when the NX session terminates
    ' NOTE:  A program which associates NX Open applications with the menubar
    ' MUST NOT use this option since it will UNLOAD your NX Open application image
    ' from the menubar.
    Public Shared Function GetUnloadOption(ByVal arg As String) As Integer
        'Return CType(Session.LibraryUnloadOption.Explicitly, Integer)
         Return CType(Session.LibraryUnloadOption.Immediately, Integer)
        ' Return CType(Session.LibraryUnloadOption.AtTermination, Integer)
    End Function
    ' Following method cleanup any housekeeping chores that may be needed.
    ' This method is automatically called by NX.
    Public Shared Function UnloadLibrary(ByVal arg As String) As Integer
        Try
            Return 0
        End Try
    End Function
    'This method shows the dialog on the screen
    Public Sub Show()
        Try
            theDialog.Show
             'theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
        End Try
    End Sub
    'Method Name: Dispose
    Public Sub Dispose()
        If theDialog IsNot Nothing Then
            theDialog.Dispose()
            theDialog = Nothing
        End If
    End Sub
    '---------------------Block Styler Callback Functions--------------------------
    'Callback Name: initialize_cb
    Public Sub initialize_cb()
        Try
            grpOptions = theDialog.TopBlock.FindBlock("grpOptions")
            SelectOption = theDialog.TopBlock.FindBlock("SelectOption")
            grpType = theDialog.TopBlock.FindBlock("grpType")
            SelectPatternType = theDialog.TopBlock.FindBlock("SelectPatternType")
            grpSpecifyPoint = theDialog.TopBlock.FindBlock("grpSpecifyPoint")
            SelectPoint = theDialog.TopBlock.FindBlock("SelectPoint")
            grpSpecifyOrientation = theDialog.TopBlock.FindBlock("grpSpecifyOrientation")
            SelectManip = theDialog.TopBlock.FindBlock("SelectManip")
            grpData = theDialog.TopBlock.FindBlock("grp4")
            DataHoneyCombW = theDialog.TopBlock.FindBlock("DataHoneyCombW")
            DataHoneyCombH = theDialog.TopBlock.FindBlock("DataHoneyCombH")
            DataHole = theDialog.TopBlock.FindBlock("DataHole")
            DataSpace = theDialog.TopBlock.FindBlock("DataSpace")
            QTYholes = theDialog.TopBlock.FindBlock("QTYholes")
            DataAdjut = theDialog.TopBlock.FindBlock("DataAdjut")
            DataLabel = theDialog.TopBlock.FindBlock("DataLabel")
            DataHoneyCombW.GetProperties.SetLogical("Enable",False)
            DataHoneyCombH.GetProperties.SetLogical("Enable",False)
            DataHole.GetProperties.SetLogical("Enable",False)
            DataSpace.GetProperties.SetLogical("Enable",False)
            DataAdjut.GetProperties.SetLogical("Enable",False)
            SelectOption.GetProperties.SetEnumAsString("Value","XY Plane By Default WCS")
            SelectPatternType.GetProperties.SetEnumAsString("Value","None")
        End Try
    End Sub
    'Callback Name: dialogShown_cb
    'This callback is executed just before the dialog launch. Thus any value set
    'here will take precedence and dialog will be launched showing that value.
    Public Sub dialogShown_cb()
        Try
            '---- Enter your callback code here -----
        End Try
    End Sub
    'Callback Name: apply_cb
    Public Function apply_cb() As Integer
        Try
        Dim rnd1 As New Random()
        Dim str(20) As String
        Dim i As Integer
        'i = rnd1.Next(1,20)
        str(0) = "*** To create PATTERN Sketch Click OK ***"
        'str(1) = "*** You have not Enough IQ to use this program ***"
        'str(2) = "*** Your computer is older than you ***"
        'str(3) = "*** Get off me ***"
        'str(4) = "*** I'm tired Is it possible to put off until tomorrow ***"
        'str(5) = "*** I forgot what I should do  ***"
        'str(6) = "*** You have not paid your taxes ***"
        'str(7) = "*** Go look for your friends ***"
        'str(8) = "*** It is hard for me, I will take it to a friend ***"
        'str(9) = "*** You're wasting your time ***"
        'str(10) = "*** Do you have nothing more useful to do ? ***"
        'str(11) = "*** Go complain to the programmer ***"
        'str(12) = "*** Dream that I will do it ***"
        'str(13) = "*** You happy ah ? ***"
        'str(14) = "*** Call me tomorrow and see what we can do ***"
        'str(15) = "*** The programmer does not know how to solve this ***"
        'str(16) = "*** Let me think what to do with it ***"
        'str(17) = "*** What happens a lot of time not heard from you ***"
        'str(18) = "*** Zumzum what do you want ***"
        'str(19) = "*** Every other day is OK but not today ***"
        'str(20) = "*** The code you entered is incorrect ***"
     If Not PointOnface And Not Manipulator Then
        ui.NXMessageBox.Show("Information",NXMessageBox.DialogType.Information,str(0))
     End If
        If needDelete Then
          DeletHoneyComb()
        End If
            Return 0
        End Try
        apply_cb = 0
    End Function
    'Callback Name: update_cb
    Public Function update_cb(ByVal block As NXOpen.BlockStyler.UIBlock) As Integer
        Try
            If block Is SelectOption Then
            '---- Enter your code here -----
              Apply_SelectOption()
            ElseIf block Is SelectPatternType Then
              Apply_SelectPatternType()
            ElseIf block Is SelectPoint Then
            '---- Enter your code here --------
              Apply_SelectPoint()
            ElseIf block Is SelectManip Then
            '---- Enter your code here ---------
              Apply_SelectManip()
            ElseIf block Is DataHoneyCombW Then
            ElseIf block Is DataHoneyCombH Then
            ElseIf block Is DataHole Then
            ElseIf block Is DataSpace Then
            ElseIf block Is QTYholes Then
            Dim QTYholesPL As PropertyList = QTYholes.GetProperties()
            QTYholesPL.SetInteger("Value",(arcs_cnt+1).ToString())
            QTYholesPL.Dispose()
            QTYholesPL = Nothing
            ElseIf block Is DataAdjut Then
              Apply_DataAdjut()
            ElseIf block Is DataLabel Then
            End If
        End Try
        update_cb = 0
    End Function
    'Callback Name: ok_cb
    Public Function ok_cb() As Integer
        Try
            Apply_Data( )
            CreatHoneyCombSketch()
        End Try
        ok_cb = 0
    End Function
    'Callback Name: cancel_cb
    Public Function cancel_cb() As Integer
        Try
        End Try
        cancel_cb = 0
    End Function
'***************************    - MY ROUTINES -    **********************************
 Function GetPointParentFace(ByVal objTag As Tag) As Face
  Dim n_parents As Integer
  Dim parentTags As Tag()
  Dim myFace As Face
  Try
   ufs.So.AskParents(objTag, UFConstants.UF_SO_ASK_ALL_PARENTS, n_parents, parentTags)
   For Each parentTag As Tag In parentTags
    Dim parent_object As TaggedObject = Utilities.NXObjectManager.Get(parentTag)
    If parent_object.ToString.ToLower.Contains("face") Then
      myFace = parent_object
    End If
   Next
    ' NXOpen.NXException: Current object is not smart
    'MessageBox.Show(" Error: " + ex.Message + NewLine _
                      ' + "    " + myTaggedObject.GetType.ToString)
  End Try
  GetPointParentFace = myFace
 End Function
 Public Function SetWcsByFaceUAndNormalAtPoint(ByVal face As Tag, ByRef origin() As Double)
  Dim mx As Tag
  Dim wcs As Tag
  Dim csys(8) As Double
  Dim xuv_csys(2) As Double
  Dim yuv_csys(2) As Double
  Dim zuv_csys(2) As Double
  Dim v1(2),u2(2),v2(2) As Double
  Dim mag As Double
  Dim parm(1) As Double
  Dim pnt(2) As Double
  Dim tol As Double
  Dim x_dir(2) As Double
  Dim y_dir(2) As Double
  Dim z_dir(2) As Double
  Dim radii(1) As Double
  Dim i As Integer
  ufs.Modl.AskDistanceTolerance(tol)
  ufs.Modl.AskFaceParm(face, Origin, parm, pnt)
  ufs.Modl.AskFaceProps(face, parm, pnt, x_dir, v1, u2, v2, Z_dir, radii)
  ufs.Vec3.Cross(Z_dir, x_dir, y_dir)
  ufs.Vec3.Unitize(x_dir, tol, mag, xuv_csys)
  ufs.Vec3.Unitize(y_dir, tol, mag, yuv_csys)
  ufs.Vec3.Unitize(z_dir, tol, mag, zuv_csys)
  For i=0 To 2
   csys(0+i) = xuv_csys(i)
   csys(3+i) = yuv_csys(i)
   csys(6+i) = zuv_csys(i)
  Next
  ufs.Mtx3.OrthoNormalize(csys)
  ufs.Csys.CreateMatrix(csys, mx)
  ufs.Csys.CreateTempCsys(origin, mx, wcs)
  ufs.Csys.SetWcs(wcs)
 End Function
 Function Point3d2Doubles(ByVal pt As Point3d) As Double()
  Dim da As Double() = {pt.X, pt.Y, pt.Z}
  Return da
 End Function
Function Doubles2Matrix3x3(ByVal mtx As Double()) As Matrix3x3
 Dim mx As Matrix3x3
  With mx
    .Xx = mtx(0)
    .Xy = mtx(1)
    .Xz = mtx(2)
    .Yx = mtx(3)
    .Yy = mtx(4)
    .Yz = mtx(5)
    .Zx = mtx(6)
    .Zy = mtx(7)
    .Zz = mtx(8)
  End With
  Return mx
 End Function
 Function CreateHoneyCombROCEPatterns()
  If Rectangular Then
    CreateHoneyCombROCEPatterns = _
     CreateRectangularHoneyCombROCEPatterns()
  ElseIf Oval Then
     CreateOvalHoneyCombROCEPatterns()
  ElseIf Circular Then
      CreateCircularHoneyCombROCEPatterns()
  ElseIf Elliptic Then
      CreateEllipticHoneyCombROCEPatterns()
  End If
 End Function
 Function CreateRectangularHoneyCombROCEPatterns()
   Dim wcs_nxmatrix As NXMatrix = workPart.WCS.CoordinateSystem.Orientation
   Dim xlimit As Integer
   Dim ylimit As Integer
   Dim x As Integer
   Dim y As Integer
   Dim xyPt As Point3d
   Dim hole_radius As Double
   Dim arc_ref_radius As Double
   Dim a As Double
   Dim XC As Double
   Dim YC As Double
   Dim Ws As Double
   Dim Hs As Double
   a = (holesSpace + holesDia)/2
   xlimit = ( (Honeycomb_X/2)/a ) + 2
   ylimit = ( (Honeycomb_Y/2)/(a*(3^0.5)) ) + 2
   hole_radius = holesDia/2
   arc_ref_radius = Honeycomb_Y/2
   adjustment = adjustment*holesDia
   arcs_cnt = -1
   Ws = ((Honeycomb_Y/2)-hole_radius + adjustment)
   Hs = ((Honeycomb_X/2)-hole_radius + adjustment)
  For y = -ylimit To ylimit
   For x = -xlimit To xlimit
    XC = (2*x+1)*a
    YC = (2*y+1)*a*(3^0.5)
    If Abs(XC) <= Hs AND Abs(YC) <= Ws Then
     xyPt.x = XC
     xyPt.y = YC
     xyPt.z = 0.0
     xyPt = WCS2Abs(xyPt)
     arcs_cnt = arcs_cnt + 1
     ReDim Preserve arcs(arcs_cnt)
     arcs(arcs_cnt) = workPart.Curves.CreateArc(xyPt,wcs_nxmatrix, _
                     hole_radius,0.0,(360.0*Math.Pi/180.0))
     arcs(arcs_cnt).RedisplayObject
    End If
    XC = (2*x)*a
    YC = (2*y)*a*(3^0.5)
     xyPt.x = XC
     xyPt.y = YC
     xyPt.z = 0.0
    End If
   Next
  Next
  arcs(0).Color = 7
  arcs(0).RedisplayObject
  Dim startPoint1 As Point3d = New Point3d((-Honeycomb_X/2), (Honeycomb_Y/2), 0.0)
  startPoint1 = WCS2Abs(startPoint1)
  Dim endPoint1 As Point3d = New Point3d((Honeycomb_X/2), (Honeycomb_Y/2), 0.0)
  endPoint1 = WCS2Abs(endPoint1)
  rect_ref_1 = workPart.Curves.CreateLine(startPoint1, endPoint1)
  rect_ref_1.LineFont = 1
  rect_ref_1.Color = 6
  rect_ref_1.RedisplayObject
  Dim startPoint2 As Point3d = New Point3d((Honeycomb_X/2), (Honeycomb_Y/2), 0.0)
  startPoint2 = WCS2Abs(startPoint2)
  Dim endPoint2 As Point3d = New Point3d((Honeycomb_X/2), (-Honeycomb_Y/2), 0.0)
  endPoint2 = WCS2Abs(endPoint2)
  rect_ref_2 = workPart.Curves.CreateLine(startPoint2, endPoint2)
  rect_ref_2.LineFont = 1
  rect_ref_2.Color = 6
  rect_ref_2.RedisplayObject
  Dim startPoint3 As Point3d = New Point3d((Honeycomb_X/2), (-Honeycomb_Y/2), 0.0)
  startPoint3 = WCS2Abs(startPoint3)
  Dim endPoint3 As Point3d = New Point3d((-Honeycomb_X/2), (-Honeycomb_Y/2), 0.0)
  endPoint3 = WCS2Abs(endPoint3)
  rect_ref_3 = workPart.Curves.CreateLine(startPoint3, endPoint3)
  rect_ref_3.LineFont = 1
  rect_ref_3.Color = 6
  rect_ref_3.RedisplayObject
  Dim startPoint4 As Point3d = New Point3d((-Honeycomb_X/2), (-Honeycomb_Y/2), 0.0)
  startPoint4 = WCS2Abs(startPoint4)
  Dim endPoint4 As Point3d = New Point3d((-Honeycomb_X/2), (Honeycomb_Y/2), 0.0)
  endPoint4 = WCS2Abs(endPoint4)
  rect_ref_4 = workPart.Curves.CreateLine(startPoint4, endPoint4)
  rect_ref_4.LineFont = 1
  rect_ref_4.Color = 6
  rect_ref_4.RedisplayObject
  refs_cnt = 3
  geom2_cnt = 1
  needDeleteRectangular = True
  CreateRectangularHoneyCombROCEPatterns = arcs_cnt
 End Function
 Function CreateOvalHoneyCombROCEPatterns()
   Dim x As Integer
   Dim y As Integer
   Dim xyPt As Point3d
   Dim a As Double
   Dim Rs As Double
   Dim XC As Double
   Dim YC As Double
   Dim Ws As Double
   Dim Hs As Double
   Dim H1 As Double
   H1 = (Honeycomb_X - Honeycomb_Y)/2
   arcs_cnt = -1
   Rs = (arc_ref_radius-hole_radius + adjustment)^2
    XC = (2*x+1)*a
    If ( Abs(XC) < H1 And Abs(YC) <= Ws ) Or _
       ( Abs(XC) >= H1 And ((Abs(XC)-H1)^2 + YC^2) <= Rs ) Then
     xyPt.x = XC
     xyPt.y = YC
     xyPt.z = 0.0
    End If
    XC = (2*x)*a
     xyPt.x = XC
     xyPt.y = YC
     xyPt.z = 0.0
    End If
   Next
  Next
  arcs(0).Color = 7
  Dim startPoint1 As Point3d = New Point3d(-((Honeycomb_X-Honeycomb_Y)/2), (Honeycomb_Y/2), 0.0)
  Dim endPoint1 As Point3d = New Point3d(((Honeycomb_X-Honeycomb_Y)/2), (Honeycomb_Y/2), 0.0)
  oval_ref_1 = workPart.Curves.CreateLine(startPoint1, endPoint1)
  oval_ref_1.LineFont = 1
  oval_ref_1.Color = 6
  oval_ref_1.RedisplayObject
  Dim startPoint2 As Point3d = New Point3d(((Honeycomb_X-Honeycomb_Y)/2), (Honeycomb_Y/2), 0.0)
  Dim pointOn2 As Point3d = New Point3d((Honeycomb_X/2), 0.0, 0.0)
  pointOn2 = WCS2Abs(pointOn2)
  Dim endPoint2 As Point3d = New Point3d(((Honeycomb_X-Honeycomb_Y)/2), (-Honeycomb_Y/2), 0.0)
  oval_ref_2 = workPart.Curves.CreateArc(startPoint2, pointOn2, endPoint2, False, False)
  oval_ref_2.LineFont = 1
  oval_ref_2.Color = 6
  oval_ref_2.RedisplayObject
  Dim startPoint3 As Point3d = New Point3d(((Honeycomb_X-Honeycomb_Y)/2), (-Honeycomb_Y/2), 0.0)
  Dim endPoint3 As Point3d = New Point3d(-((Honeycomb_X-Honeycomb_Y)/2), (-Honeycomb_Y/2), 0.0)
  oval_ref_3 = workPart.Curves.CreateLine(startPoint3, endPoint3)
  oval_ref_3.LineFont = 1
  oval_ref_3.Color = 6
  oval_ref_3.RedisplayObject
  Dim startPoint4 As Point3d = New Point3d(-((Honeycomb_X-Honeycomb_Y)/2), (-Honeycomb_Y/2), 0.0)
  Dim pointOn4 As Point3d = New Point3d(-(Honeycomb_X/2), 0.0, 0.0)
  pointOn4 = WCS2Abs(pointOn4)
  Dim endPoint4 As Point3d = New Point3d(-((Honeycomb_X-Honeycomb_Y)/2), (Honeycomb_Y/2), 0.0)
  oval_ref_4 = workPart.Curves.CreateArc(startPoint4, pointOn4, endPoint4, False, False)
  oval_ref_4.LineFont = 1
  oval_ref_4.Color = 6
  oval_ref_4.RedisplayObject
  refs_cnt = 3
  geom2_cnt = 1
  needDeleteOval = True
  CreateOvalHoneyCombROCEPatterns = arcs_cnt
 End Function
 Function CreateCircularHoneyCombROCEPatterns()
   Dim x As Integer
   Dim y As Integer
   Dim xyPt As Point3d
   Dim a As Double
   Dim XC As Double
   Dim YC As Double
   Dim Rs As Double
   xlimit = ( (Honeycomb_Y/2)/a ) + 2
   arcs_cnt = -1
    XC = (2*x+1)*a
    If (XC^2 + YC^2) <= Rs Then
     xyPt.x = XC
     xyPt.y = YC
     xyPt.z = 0.0
    End If
    XC = (2*x)*a
     xyPt.x = XC
     xyPt.y = YC
     xyPt.z = 0.0
    End If
   Next
  Next
  arcs(0).Color = 7
  xyPt.x = 0.0
  xyPt.y = 0.0
  xyPt.z = 0.0
  arc_ref = workPart.Curves.CreateArc(xyPt,wcs_nxmatrix, _
                     arc_ref_radius,0.0,(360.0*Math.Pi/180.0))
  arc_ref.LineFont = 1
  arc_ref.Color = 6
  arc_ref.RedisplayObject
  refs_cnt = 0
  geom2_cnt = 0
  needDeleteCircular = True
  CreateCircularHoneyCombROCEPatterns = arcs_cnt
 End Function
 Function CreateEllipticHoneyCombROCEPatterns()
   Dim x As Integer
   Dim y As Integer
   Dim xyPt As Point3d
   Dim a As Double
   Dim XC As Double
   Dim YC As Double
   Dim aR As Double
   Dim bR As Double
   Dim abRs As Double
   arcs_cnt = -1
   aR = Honeycomb_X/2
   bR = Honeycomb_Y/2
   abRs = (aR-hole_radius + adjustment)^2*(bR-hole_radius + adjustment)^2
    XC = (2*x+1)*a
    If (bR^2*XC^2 + aR^2*YC^2) <= abRs Then
     xyPt.x = XC
     xyPt.y = YC
     xyPt.z = 0.0
    End If
    XC = (2*x)*a
     xyPt.x = XC
     xyPt.y = YC
     xyPt.z = 0.0
    End If
   Next
  Next
  arcs(0).Color = 7
  xyPt.x = 0.0
  xyPt.y = 0.0
  xyPt.z = 0.0
  ellipse_ref = workPart.Curves.CreateEllipse(xyPt, aR, bR, 0.0, _
                          ( 360.0 * Math.Pi/180.0 ), 0.0, wcs_nxmatrix)
  ellipse_ref.LineFont = 1
  ellipse_ref.Color = 6
  ellipse_ref.RedisplayObject
  refs_cnt = 0
  geom2_cnt = 0
  needDeleteElliptic = True
  CreateEllipticHoneyCombROCEPatterns = arcs_cnt
 End Function
 Function Abs(ByVal d As Double) As Double
   If d < 0 Then
     d = -d
   End If
   Abs = d
 End Function
 Function DeletHoneyComb() As Integer
  If needDeleteRectangular Then
     DeletRectangularHoneyComb()
   End If
  If needDeleteOval Then
     DeletOvalHoneyComb()
   End If
  If needDeleteCircular Then
     DeletCircularHoneyComb()
   End If
  If needDeleteElliptic Then
     DeleteEllipticHoneyComb()
   End If
 End Function
 Function DeletRectangularHoneyComb() As Integer
  needDeleteRectangular = False
  Try
   Dim del_objects(arcs_cnt+4) As NXObject
   Dim i As Integer
   For i = 0 To arcs_cnt
     del_objects(i) = arcs(i)
   Next
   del_objects(arcs_cnt+1) = rect_ref_1
   del_objects(arcs_cnt+2) = rect_ref_2
   del_objects(arcs_cnt+3) = rect_ref_3
   del_objects(arcs_cnt+4) = rect_ref_4
   Dim del_markId As Session.UndoMarkId
   del_markId = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Delete")
   Dim nErrs1 As Integer
   nErrs1 = theSession.UpdateManager.AddToDeleteList(del_objects)
   Dim notifyOnDelete2 As Boolean
   notifyOnDelete2 = theSession.Preferences.Modeling.NotifyOnDelete
   workPart.ModelingViews.WorkView.Regenerate()
   Dim nErrs2 As Integer
   nErrs2 = theSession.UpdateManager.DoUpdate(del_markId)
   theSession.DeleteUndoMark(del_markId, Nothing)
    Return 0
  End Try
 End Function
 Function DeletOvalHoneyComb() As Integer
  needDeleteOval = False
  Try
   Dim i As Integer
   Next
   del_objects(arcs_cnt+1) = oval_ref_1
   del_objects(arcs_cnt+2) = oval_ref_2
   del_objects(arcs_cnt+3) = oval_ref_3
   del_objects(arcs_cnt+4) = oval_ref_4
    Return 0
  End Try
 End Function
 Function DeletCircularHoneyComb() As Integer
  needDeleteCircular = False
  Try
   Dim del_objects(arcs_cnt+1) As NXObject
   Dim i As Integer
   Next
   del_objects(arcs_cnt+1) = arc_ref
    Return 0
  End Try
 End Function
 Function DeleteEllipticHoneyComb() As Integer
  needDeleteElliptic = False
  Try
   Dim i As Integer
   Next
   del_objects(arcs_cnt+1) = ellipse_ref
    Return 0
  End Try
 End Function
 Function WCS2Abs(ByVal inPt As Point3d) As Point3d
  Dim ufs As UFSession = UFSession.GetUFSession()
   Dim pt1(2), pt2(2) As Double
   pt1(0) = inPt.X
   pt1(1) = inPt.Y
   pt1(2) = inPt.Z
   ufs.Csys.MapPoint(UFConstants.UF_CSYS_ROOT_WCS_COORDS, pt1, UFConstants.UF_CSYS_ROOT_COORDS, pt2)
   WCS2Abs.X = pt2(0)
   WCS2Abs.Y = pt2(1)
   WCS2Abs.Z = pt2(2)
 End Function
 Sub GetDoublesData()
  Dim DataHoneyCombWPL As PropertyList = DataHoneyCombW.GetProperties()
  Honeycomb_Y = DataHoneyCombwPL.GetDouble("Value")
  DataHoneyCombWPL.Dispose()
  DataHoneyCombwPL = Nothing
  Dim DataHoneyCombHPL As PropertyList = DataHoneyCombH.GetProperties()
  Honeycomb_X = DataHoneyCombHPL.GetDouble("Value")
  DataHoneyCombHPL.Dispose()
  DataHoneyCombHPL = Nothing
  Dim DataHolePL As PropertyList = DataHole.GetProperties()
  holesDia = DataHolePL.GetDouble("Value")
  DataHolePL.Dispose()
  DataHolePL = Nothing
  Dim DataSpacePL As PropertyList = DataSpace.GetProperties()
  holesSpace = DataSpacePL.GetDouble("Value")
  DataSpacePL.Dispose()
  DataSpacePL = Nothing
  Dim DataAdjutPL As PropertyList = DataAdjut.GetProperties()
  adjustment = DataAdjutPL.GetDouble("Value")
  DataAdjutPL.Dispose()
  DataAdjutPL = Nothing
 End Sub
Sub CreatHoneyCombSketch()
 Dim j As Integer
 Dim sketch_name As String = "HoneyComb X" & (arcs_cnt+1).ToString & " Holes"
 create_sketch_datums( )
 create_sketch( sketch_name )
 Dim curvesorpoints1(arcs_cnt) As SmartObject
 For j=0 To arcs_cnt
   curvesorpoints1(j) = arcs(j)
 Next
 theSession.ActiveSketch.AddGeometry(Sketch.InferConstraintsOption. _
          InferCoincidentConstraints, Sketch.AddEllipseOption. _
                                 TreatAsEllipse, curvesorpoints1)
 Dim curvesorpoints2(refs_cnt) As SmartObject
 If Rectangular Then
   curvesorpoints2(0) = rect_ref_1
   curvesorpoints2(1) = rect_ref_2
   curvesorpoints2(2) = rect_ref_3
   curvesorpoints2(3) = rect_ref_4
 ElseIf Oval Then
   curvesorpoints2(0) = oval_ref_1
   curvesorpoints2(1) = oval_ref_2
   curvesorpoints2(2) = oval_ref_3
   curvesorpoints2(3) = oval_ref_4
   curvesorpoints2(0) = arc_ref
   curvesorpoints2(0) = ellipse_ref
 End If
                                             TreatAsEllipse, curvesorpoints2)
 theSession.ActiveSketch.Update()
 Dim sketchAutoConstrainBuilder1 As SketchAutoConstrainBuilder
 sketchAutoConstrainBuilder1 = workPart.Sketches.CreateAutoConstrainBuilder()
 sketchAutoConstrainBuilder1.DistanceTolerance = 0.0254
 sketchAutoConstrainBuilder1.AngleTolerance = 0.5
 sketchAutoConstrainBuilder1.Horizontal = False
 sketchAutoConstrainBuilder1.Vertical = False
 sketchAutoConstrainBuilder1.Tangent = False
 sketchAutoConstrainBuilder1.Parallel = False
 sketchAutoConstrainBuilder1.Perpendicular = False
 sketchAutoConstrainBuilder1.EqualRadius = True
 Dim objects1(arcs_cnt) As TaggedObject
 For j=0 To arcs_cnt
   objects1(j) = arcs(j)
 Next
 Dim added1 As Boolean
 added1 = sketchAutoConstrainBuilder1.CurveList.Add(objects1)
 Dim nXObject1 As NXObject
 nXObject1 = sketchAutoConstrainBuilder1.Commit()
 sketchAutoConstrainBuilder1.Destroy()
 Dim geom1(arcs_cnt) As Sketch.ConstraintGeometry
 For j=0 to arcs_cnt
  geom1(j).Geometry = arcs(j)
  geom1(j).PointType = Sketch.ConstraintPointType.ArcCenter
  geom1(j).SplineDefiningPointIndex = 0
  Dim sketchGeometricConstraint1 As SketchGeometricConstraint
  sketchGeometricConstraint1 = theSession.ActiveSketch.CreateFixedConstraint(geom1(j))
 Next
 Dim geom2(geom2_cnt) As Sketch.ConstraintGeometry
 If Rectangular Then
   geom2(0).Geometry = rect_ref_1
   'geom2(1).Geometry = rect_ref_2
   geom2(1).Geometry = rect_ref_3
   'geom2(3).Geometry = rect_ref_4
 ElseIf Oval Then
   'geom2(0).Geometry = oval_ref_1
   geom2(0).Geometry = oval_ref_2
   'geom2(2).Geometry = oval_ref_3
   geom2(1).Geometry = oval_ref_4
   geom2(0).Geometry = arc_ref
   geom2(0).Geometry = ellipse_ref
 End If
   Dim constraints2() As SketchGeometricConstraint
 For k As Integer = 0 To geom2_cnt
   geom2(k).PointType = Sketch.ConstraintPointType.None
   geom2(k).SplineDefiningPointIndex = 0
   constraints2 = theSession.ActiveSketch.CreateFullyFixedConstraints(geom2(k))
 Next
 Dim convertToFromReferenceBuilder1 As ConvertToFromReferenceBuilder
 convertToFromReferenceBuilder1 = workPart.Sketches.CreateConvertToFromReferenceBuilder()
 Dim selectNXObjectList1 As SelectNXObjectList
 selectNXObjectList1 = convertToFromReferenceBuilder1.InputObjects
 Dim added2(refs_cnt) As Boolean
 If Rectangular Then
   added2(0) = selectNXObjectList1.Add(rect_ref_1)
   added2(1) = selectNXObjectList1.Add(rect_ref_2)
   added2(2) = selectNXObjectList1.Add(rect_ref_3)
   added2(3) = selectNXObjectList1.Add(rect_ref_4)
 ElseIf Oval Then
   added2(0) = selectNXObjectList1.Add(oval_ref_1)
   added2(1) = selectNXObjectList1.Add(oval_ref_2)
   added2(2) = selectNXObjectList1.Add(oval_ref_3)
   added2(3) = selectNXObjectList1.Add(oval_ref_4)
   added2(0) = selectNXObjectList1.Add(arc_ref)
  added2(0) = selectNXObjectList1.Add(ellipse_ref)
 End If
 convertToFromReferenceBuilder1.OutputState = ConvertToFromReferenceBuilder.OutputType.Reference
 Dim nXObject2 As NXObject
 nXObject2 = convertToFromReferenceBuilder1.Commit()
 convertToFromReferenceBuilder1.Destroy()
 Dim dimObject1_1 As Sketch.DimensionGeometry
 dimObject1_1.Geometry = arcs(0)
 dimObject1_1.AssocType = Sketch.AssocType.Tangency
 dimObject1_1.AssocValue = 32
 dimObject1_1.HelpPoint.X = 0.0
 dimObject1_1.HelpPoint.Y = 0.0
 dimObject1_1.HelpPoint.Z = 0.0
 dimObject1_1.View = workPart.ModelingViews.WorkView
 Dim dimOrigin1 As Point3d = New Point3d(-18.2484565044161, 25.3425962369545, 0.0)
 Dim nullExpression As Expression = Nothing
 Dim sketchDimensionalConstraint1 As SketchDimensionalConstraint
 sketchDimensionalConstraint1 = theSession.ActiveSketch. _
          CreateDiameterDimension(dimObject1_1, dimOrigin1, nullExpression, _
                                      Sketch.DimensionOption.CreateAsDriving)
 Dim dimension1 As Annotations.Dimension
 dimension1 = sketchDimensionalConstraint1.AssociatedDimension
 Dim expression1 As Expression
 expression1 = sketchDimensionalConstraint1.AssociatedExpression
 expression1.SetName("Hole_1_Of_" & (arcs_cnt+1).ToString & "_Holes")
 '   ****** Menu: Sketch->Finish Sketch ******
 theSession.ActiveSketch.Deactivate(Sketch.ViewReorient.True, _
                                    Sketch.UpdateLevel.Model)
 theSession.EndTaskEnvironment()
 '   ****** Menu: Tools->Journal->Stop Recording ******
End Sub
Sub create_sketch( ByRef sk_name As String )
  Dim displayPart As Part = theSession.Parts.Display
  '   ****** Menu: Insert->Sketch... ******
  Dim markId1 As Session.UndoMarkId
  markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Enter Sketcher")
  theSession.BeginTaskEnvironment()
  Dim nullSketch As Sketch = Nothing
  Dim sketchInPlaceBuilder1 As SketchInPlaceBuilder
  sketchInPlaceBuilder1 = workPart.Sketches.CreateSketchInPlaceBuilder(nullSketch)
  nXObject1 = sketchInPlaceBuilder1.Commit()
  Dim sketch1 As Sketch = CType(nXObject1, Sketch)
  Dim feature1 As Features.Feature
  feature1 = sketch1.Feature
  sketch1.Activate(Sketch.ViewReorient.True)
  sketchInPlaceBuilder1.Destroy()
  theSession.ActiveSketch.SetName(sk_name)
 End Sub
 Sub create_sketch_datums( )
  Dim wcs_origin As Point3d = workPart.WCS.Origin
  Dim wcs_matrix3x3 As Matrix3x3 = workPart.WCS.CoordinateSystem.Orientation.Element
  Dim featdatum_tag As Tag
  Dim featdatum_obj As NXObject
  Dim xyplane As DatumPlane
  xyplane = workPart.Datums.CreateFixedDatumPlane(wcs_origin,wcs_matrix3x3)
  xyplane.SetName("_XY_")
  ufs.Modl.AskObjectFeat(xyplane.Tag,featdatum_tag)
  featdatum_obj = NXOpen.Utilities.NXObjectManager.Get(featdatum_tag)
  Dim xy_PlaneFeat As Features.DatumPlaneFeature = CType(featdatum_obj,Features.DatumPlaneFeature)
  xy_PlaneFeat.SetName("_XY_")
  Dim Xdir As New Point3d(1,0,0)
  Xdir = WCS2Abs(Xdir)
  Dim Xaxis As DatumAxis
  Xaxis = workPart.Datums.CreateFixedDatumAxis(wcs_origin,Xdir)
  Xaxis.SetName("_X_")
  ufs.Modl.AskObjectFeat(Xaxis.Tag,featdatum_tag)
  Dim x_AxisFeat As Features.DatumAxisFeature = CType(featdatum_obj,Features.DatumAxisFeature)
  x_AxisFeat.SetName("_X_")
  Dim Ydir As New Point3d(0,1,0)
  Ydir = WCS2Abs(Ydir)
  Dim Yaxis As DatumAxis
  Yaxis = workPart.Datums.CreateFixedDatumAxis(wcs_origin,Ydir)
  Yaxis.SetName("_Y_")
  ufs.Modl.AskObjectFeat(Yaxis.Tag,featdatum_tag)
  Dim y_AxisFeat As Features.DatumAxisFeature = CType(featdatum_obj,Features.DatumAxisFeature)
  y_AxisFeat.SetName("_Y_")
 End Sub
 Sub Apply_Data( )
              PointOnface = False
              Manipulator = False
              SelectPoint.GetProperties.SetLogical("Enable",False)
              SelectManip.GetProperties.SetLogical("Enable",False)
              SelectManip.GetProperties.SetLogical("Show",False)
              grpSpecifyOrientation.GetProperties.SetLogical("Show",False)
              grpSpecifyPoint.GetProperties.SetLogical("Show",False)
              DataHoneyCombW.GetProperties.SetLogical("Enable",True)
              DataHoneyCombH.GetProperties.SetLogical("Enable",True)
              DataHole.GetProperties.SetLogical("Enable",True)
              DataSpace.GetProperties.SetLogical("Enable",True)
              DataAdjut.GetProperties.SetLogical("Enable",True)
              GetDoublesData()
               If needDelete Then
                 DeletHoneyComb()
                 arcs_cnt = CreateHoneyCombROCEPatterns()
                 needDelete = True
               Else
                 needDelete = True
               End If
               workPart.ModelingViews.WorkView.Fit()
 End Sub
 Sub Apply_SelectOption()
            Dim opt As String = SelectOption.GetProperties.GetEnumAsString("Value")
            If opt = "XY Plane By Default WCS" Then
              PointOnface = False
              Manipulator = False
              workPart.WCS.SetOriginAndMatrix(wp_wcs_origin, wp_wcs_matrix3x3)
            ElseIf opt = "XY Plane By PointOnface" Then
              PointOnface = True
              Manipulator = False
              SelectPoint.GetProperties.SetLogical("Enable",True)
              grpSpecifyPoint.GetProperties.SetLogical("Show",True)
            ElseIf opt =  "XY Plane By Manipulator" Then
              Manipulator = True
              PointOnface = False
              SelectManip.GetProperties.SetLogical("Enable",True)
              SelectManip.GetProperties.SetLogical("Show",True)
              grpSpecifyOrientation.GetProperties.SetLogical("Show",True)
            End If
 End Sub
 Sub Apply_SelectPatternType()
            Dim spt As String = SelectPatternType.GetProperties.GetEnumAsString("Value")
            If spt = "None" Then
              Rectangular = False
              Oval = False
              Circular = False
              Elliptic = False
              Apply_Data( )
            ElseIf spt = "Rectangular" Then
              Rectangular = True
              Oval = False
              Circular = False
              Elliptic = False
              Apply_Data( )
            ElseIf spt = "Oval" Then
              Rectangular = False
              Oval = True
              Circular = False
              Elliptic = False
              Apply_Data( )
            ElseIf spt = "Circular" Then
              Rectangular = False
              Oval = False
              Circular = True
              Elliptic = False
              Apply_Data( )
            ElseIf spt = "Elliptic" Then
              Rectangular = False
              Oval = False
              Circular = False
              Elliptic = True
              Apply_Data( )
            End If
 End Sub
 Sub Apply_SelectPoint()
            Dim SelectPointPL As PropertyList = SelectPoint.GetProperties()
            Dim point1 As Point3d = SelectPointPL.GetPoint("Point")
            cp(0) = point1.X
            cp(1) = point1.Y
            cp(2) = point1.Z
            Dim pt As Point = CType((SelectPointPL.GetTaggedObjectVector("SelectedObjects"))(0), Point)
            myPointTag = pt.Tag
            SelectPointPL.Dispose()
            SelectPointPL = Nothing
            facetag = (GetPointParentFace(myPointTag)).Tag
            SetWcsByFaceUAndNormalAtPoint(facetag, cp)
 End Sub
 Sub Apply_SelectManip()
            Dim SelectManipPL As PropertyList = SelectManip.GetProperties()
            origin1 = SelectManipPL.GetPoint("Origin")
            Dim x_axis As Vector3d = SelectManipPL.GetVector("XAxis")
            Dim y_axis As Vector3d = SelectManipPL.GetVector("YAxis")
            SelectManipPL.Dispose()
            SelectManipPL = Nothing
            Dim xVector(2) As Double
            Dim yVector(2) As Double
            Dim mtxDoubles(8) As Double
            xVector = Vector3d2Doubles(x_axis)
            yVector = Vector3d2Doubles(y_axis)
            ufs.Mtx3.Initialize(xVector, yVector, mtxDoubles)
            matrix1 = Doubles2Matrix3x3(mtxDoubles)
            workPart.WCS.SetOriginAndMatrix(origin1, matrix1)
 End Sub
 Sub Apply_DataAdjut()
             GetDoublesData()
             If Honeycomb_Y > 0 And holesDia > 0 And holesSpace > 0 Then
               If needDelete Then
                 DeletHoneyComb()
                 needDelete = True
               Else
                 needDelete = True
               End If
             End If
 End Sub
 Function Vector3d2Doubles(ByVal pt As Vector3d) As Double()
  Return da
 End Function
End Class
And this for fun
CODE -->
'       Filename:  C:\Sudoku.vb
'        Created by: I'm
'              Version: NX 6
'              Date: 06-28-2015  (Format: mm-dd-yyyy)
'              Time: 19:14 (Format: hh-mm)
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Public Class Sudoku
    'class members
    Public Shared theSudoku As Sudoku
    Private type1 As NXOpen.BlockStyler.UIBlock' Block type: Group
    Private Type As NXOpen.BlockStyler.UIBlock' Block type: Enumeration
    Private StopAt As NXOpen.BlockStyler.UIBlock' Block type: Integer
    Private matrix1 As NXOpen.BlockStyler.UIBlock' Block type: Group
    Private intTable As NXOpen.BlockStyler.UIBlock' Block type: Integer Table
    'my members
    Dim RegularType As Boolean
    Dim DiagonalType As Boolean
    Dim TimerFlag As Boolean = True
    Dim stop_at_solution As Integer = 2
    Dim a(80) as Integer
    Public Sub New()
        Try
            theUI = UI.GetUI()
            theDialogName = "C:\sudoku9x9.dlx"
            Throw ex
        End Try
    End Sub
#End Region
    '    1. Journal Replay
    '    2. USER EXIT
        Try
            theSudoku = New Sudoku()
            theSudoku.Show()
        Finally
            theSudoku.Dispose()
        End Try
    End Sub
    ' from the menubar.
    End Function
        Try
            Return 0
        End Try
    End Function
    Public Sub Show()
        Try
            theDialog.Show
        End Try
    End Sub
            theDialog.Dispose()
            theDialog = Nothing
        End If
    End Sub
        Try
            type1 = theDialog.TopBlock.FindBlock("type1")
            Type = theDialog.TopBlock.FindBlock("Type")
            StopAt = theDialog.TopBlock.FindBlock("StopAt")
            matrix1 = theDialog.TopBlock.FindBlock("matrix1")
            intTable = theDialog.TopBlock.FindBlock("intTable")
            StopAt.GetProperties.SetInteger("Value",2)
        Dim j1 As Integer
        Dim mxv(80) As Integer
        For j1 = 0 To 80
          mxv(j1) = 0
        Next
        intTable.GetProperties.SetIntegerMatrix("MinimumValues",9,9,mxv)
        For j1 = 0 To 80
          mxv(j1) = 9
        Next
        intTable.GetProperties.SetIntegerMatrix("MaximumValues",9,9,mxv)
        RegularType = True
        TimerFlag = True
        End Try
    End Sub
        Try
        End Try
    End Sub
        Try
              a = intTable.GetProperties().GetIntegerMatrix("Values",9,9)
              GetOptions()
              GetStopNum()
              TimerFlag = True
              If RegularType = True Then
                RSudoku
              Else If DiagonalType = True Then
                DSudoku
              End If
        End Try
        apply_cb = 0
    End Function
        Try
            If block Is Type Then
              GetOptions()
            ElseIf block Is StopAt Then
              GetStopNum()
            ElseIf block Is intTable Then
            End If
        End Try
        update_cb = 0
    End Function
        Try
            apply_cb()
        End Try
        ok_cb = 0
    End Function
        Try
        End Try
        cancel_cb = 0
    End Function
 Public Sub GetStopNum()
    stop_at_solution = StopAt.GetProperties.GetInteger("Value")
 End Sub
 Public Sub GetOptions()
              Dim typ As String = Type.GetProperties.GetEnumAsString("Value")
              If typ = "Regular" Then
                RegularType = True
                DiagonalType = False
              Else If typ = "Diagonal" Then
                RegularType = False
                DiagonalType = True
              End If
 End Sub
Public Sub RSudoku()
   Dim s As Session = Session.GetSession()
   Dim lw As ListingWindow = s.ListingWindow
   Dim si(8,8) As Integer
   Dim ss(8,8) As Integer
   Dim Go_up As Boolean = False
   Dim si00,si10,si20,si30,si40,si50,si60,si70,si80 As Integer
   Dim si01,si11,si21,si31,si41,si51,si61,si71,si81 As Integer
   Dim si02,si12,si22,si32,si42,si52,si62,si72,si82 As Integer
   Dim si03,si13,si23,si33,si43,si53,si63,si73,si83 As Integer
   Dim si04,si14,si24,si34,si44,si54,si64,si74,si84 As Integer
   Dim si05,si15,si25,si35,si45,si55,si65,si75,si85 As Integer
   Dim si06,si16,si26,si36,si46,si56,si66,si76,si86 As Integer
   Dim si07,si17,si27,si37,si47,si57,si67,si77,si87 As Integer
   Dim si08,si18,si28,si38,si48,si58,si68,si78,si88 As Integer
   Dim start As Short
   Dim tv As NXOpen.UF.TimerValues
   ufs.UF.BeginTimer(start)
   Dim jj As Integer
   For jj=0 To 8
     si(0,jj) = a(jj)
     ss(0,jj) = si(0,jj)
   Next
   For jj=9 To 17
     si(1,jj-9) = a(jj)
     ss(1,jj-9) = si(1,jj-9)
   Next
   For jj=18 To 26
     si(2,jj-18) = a(jj)
     ss(2,jj-18) = si(2,jj-18)
   Next
   For jj=27 To 35
     si(3,jj-27) = a(jj)
     ss(3,jj-27) = si(3,jj-27)
   Next
   For jj=36 To 44
     si(4,jj-36) = a(jj)
     ss(4,jj-36) = si(4,jj-36)
   Next
   For jj=45 To 53
     si(5,jj-45) = a(jj)
     ss(5,jj-45) = si(5,jj-45)
   Next
   For jj=54 To 62
     si(6,jj-54) = a(jj)
     ss(6,jj-54) = si(6,jj-54)
   Next
   For jj=63 To 71
     si(7,jj-63) = a(jj)
     ss(7,jj-63) = si(7,jj-63)
   Next
   For jj=72 To 80
     si(8,jj-72) = a(jj)
     ss(8,jj-72) = si(8,jj-72)
   Next
  lw.Open()
   If valid_check( ss ) = False Then
     'lw.WriteLine(" Input not valid ! ")
     msgbox(" Input not valid ! ")
     Exit Sub
   End If
  si00 = 0: si01 = 0: si02 = 0: si03 = 0: si04 = 0: si05 = 0: si06 = 0: si07 = 0: si08 = 0
  si10 = 0: si11 = 0: si12 = 0: si13 = 0: si14 = 0: si15 = 0: si16 = 0: si17 = 0: si18 = 0
  si20 = 0: si21 = 0: si22 = 0: si23 = 0: si24 = 0: si25 = 0: si26 = 0: si27 = 0: si28 = 0
  si30 = 0: si31 = 0: si32 = 0: si33 = 0: si34 = 0: si35 = 0: si36 = 0: si37 = 0: si38 = 0
  si40 = 0: si41 = 0: si42 = 0: si43 = 0: si44 = 0: si45 = 0: si46 = 0: si47 = 0: si48 = 0
  si50 = 0: si51 = 0: si52 = 0: si53 = 0: si54 = 0: si55 = 0: si56 = 0: si57 = 0: si58 = 0
  si60 = 0: si61 = 0: si62 = 0: si63 = 0: si64 = 0: si65 = 0: si66 = 0: si67 = 0: si68 = 0
  si70 = 0: si71 = 0: si72 = 0: si73 = 0: si74 = 0: si75 = 0: si76 = 0: si77 = 0: si78 = 0
  si80 = 0: si81 = 0: si82 = 0: si83 = 0: si84 = 0: si85 = 0: si86 = 0: si87 = 0: si88 = 0
  Dim cnt_stop As Integer = 0
si00:
  If si(0,0) = 0 Then
    Go_up = False
    si00 = si00 + 1
    If si00 > 9 Then
       lw.WriteLine("***  Sudoku Processing Ended ! ***")
       Exit Sub
    End If
    If si00 = ss(0,1) OrElse si00 = ss(0,2) OrElse si00 = ss(0,3) OrElse si00 = ss(0,4) OrElse _
       si00 = ss(0,5) OrElse si00 = ss(0,6) OrElse si00 = ss(0,7) OrElse si00 = ss(0,8) OrElse _
       si00 = ss(1,0) OrElse si00 = ss(2,0) OrElse si00 = ss(3,0) OrElse si00 = ss(4,0) OrElse _
       si00 = ss(5,0) OrElse si00 = ss(6,0) OrElse si00 = ss(7,0) OrElse si00 = ss(8,0) OrElse _
       si00 = ss(1,1) OrElse si00 = ss(1,2) OrElse si00 = ss(2,1) OrElse si00 = ss(2,2) Then GoTo si00
    ss(0,0) = si00
    'lw.WriteLine(" ==> si00 - Passed si00 = " & si00.ToString)
  End If
si01:
  If si(0,1) = 0 Then
  Go_up = False
  si01 = si01 + 1
  If si01 > 9 Then
     si01 = 0
     ss(0,1) = 0
     Go_up = True
     GoTo si00
  End If
    If si01 = ss(0,0) OrElse si01 = ss(0,2) OrElse si01 = ss(0,3) OrElse si01 = ss(0,4) OrElse _
       si01 = ss(0,5) OrElse si01 = ss(0,6) OrElse si01 = ss(0,7) OrElse si01 = ss(0,8) OrElse _
       si01 = ss(1,1) OrElse si01 = ss(2,1) OrElse si01 = ss(3,1) OrElse si01 = ss(4,1) OrElse _
       si01 = ss(5,1) OrElse si01 = ss(6,1) OrElse si01 = ss(7,1) OrElse si01 = ss(8,1) OrElse _
       si01 = ss(1,0) OrElse si01 = ss(1,2) OrElse si01 = ss(2,0) OrElse si01 = ss(2,2) Then GoTo si01
    ss(0,1) = si01
    'lw.WriteLine(" ==> si01 - Passed si01 = " & si01.ToString)
  Else
    If Go_up = True Then GoTo si00
  End If
si02:
  If si(0,2) = 0 Then
  Go_up = False
  si02 = si02 + 1
  If si02 > 9 Then
     si02 = 0
     ss(0,2) = 0
     Go_up = True
     GoTo si01
  End If
    If si02 = ss(0,0) OrElse si02 = ss(0,1) OrElse si02 = ss(0,3) OrElse si02 = ss(0,4) OrElse _
       si02 = ss(0,5) OrElse si02 = ss(0,6) OrElse si02 = ss(0,7) OrElse si02 = ss(0,8) OrElse _
       si02 = ss(1,2) OrElse si02 = ss(2,2) OrElse si02 = ss(3,2) OrElse si02 = ss(4,2) OrElse _
       si02 = ss(5,2) OrElse si02 = ss(6,2) OrElse si02 = ss(7,2) OrElse si02 = ss(8,2) OrElse _
       si02 = ss(1,0) OrElse si02 = ss(1,1) OrElse si02 = ss(2,0) OrElse si02 = ss(2,1) Then GoTo si02
    ss(0,2) = si02
    'lw.WriteLine(" ==> si02 - Passed si02 = " & si02.ToString)
  Else
    If Go_up = True Then GoTo si01
  End If
si03:
  If si(0,3) = 0 Then
  Go_up = False
  si03 = si03 + 1
  If si03 > 9 Then
     si03 = 0
     ss(0,3) = 0
     Go_up = True
     GoTo si02
  End If
    If si03 = ss(0,0) OrElse si03 = ss(0,1) OrElse si03 = ss(0,2) OrElse si03 = ss(0,4) OrElse _
       si03 = ss(0,5) OrElse si03 = ss(0,6) OrElse si03 = ss(0,7) OrElse si03 = ss(0,8) OrElse _
       si03 = ss(1,3) OrElse si03 = ss(2,3) OrElse si03 = ss(3,3) OrElse si03 = ss(4,3) OrElse _
       si03 = ss(5,3) OrElse si03 = ss(6,3) OrElse si03 = ss(7,3) OrElse si03 = ss(8,3) OrElse _
       si03 = ss(1,4) OrElse si03 = ss(1,5) OrElse si03 = ss(2,4) OrElse si03 = ss(2,5) Then GoTo si03
    ss(0,3) = si03
    'lw.WriteLine(" ==> si03 - Passed si03 = " & si03.ToString)
  Else
    If Go_up = True Then GoTo si02
  End If
si04:
  If si(0,4) = 0 Then
  Go_up = False
  si04 = si04 + 1
  If si04 > 9 Then
     si04 = 0
     ss(0,4) = 0
     Go_up = True
     GoTo si03
  End If
    If si04 = ss(0,0) OrElse si04 = ss(0,1) OrElse si04 = ss(0,2) OrElse si04 = ss(0,3) OrElse _
       si04 = ss(0,5) OrElse si04 = ss(0,6) OrElse si04 = ss(0,7) OrElse si04 = ss(0,8) OrElse _
       si04 = ss(1,4) OrElse si04 = ss(2,4) OrElse si04 = ss(3,4) OrElse si04 = ss(4,4) OrElse _
       si04 = ss(5,4) OrElse si04 = ss(6,4) OrElse si04 = ss(7,4) OrElse si04 = ss(8,4) OrElse _
       si04 = ss(1,3) OrElse si04 = ss(1,5) OrElse si04 = ss(2,3) OrElse si04 = ss(2,5) Then GoTo si04
    ss(0,4) = si04
    'lw.WriteLine(" ==> si04 - Passed si04 = " & si04.ToString)
  Else
    If Go_up = True Then GoTo si03
  End If
si05:
  If si(0,5) = 0 Then
  Go_up = False
  si05 = si05 + 1
  If si05 > 9 Then
     si05 = 0
     ss(0,5) = 0
     Go_up = True
     GoTo si04
  End If
    If si05 = ss(0,0) OrElse si05 = ss(0,1) OrElse si05 = ss(0,2) OrElse si05 = ss(0,3) OrElse _
       si05 = ss(0,4) OrElse si05 = ss(0,6) OrElse si05 = ss(0,7) OrElse si05 = ss(0,8) OrElse _
       si05 = ss(1,5) OrElse si05 = ss(2,5) OrElse si05 = ss(3,5) OrElse si05 = ss(4,5) OrElse _
       si05 = ss(5,5) OrElse si05 = ss(6,5) OrElse si05 = ss(7,5) OrElse si05 = ss(8,5) OrElse _
       si05 = ss(1,3) OrElse si05 = ss(1,4) OrElse si05 = ss(2,3) OrElse si05 = ss(2,4) Then GoTo si05
    ss(0,5) = si05
    'lw.WriteLine(" ==> si05 - Passed si05 = " & si05.ToString)
  Else
    If Go_up = True Then GoTo si04
  End If
si06:
  If si(0,6) = 0 Then
  Go_up = False
  si06 = si06 + 1
  If si06 > 9 Then
     si06 = 0
     ss(0,6) = 0
     Go_up = True
     GoTo si05
  End If
    If si06 = ss(0,0) OrElse si06 = ss(0,1) OrElse si06 = ss(0,2) OrElse si06 = ss(0,3) OrElse _
       si06 = ss(0,4) OrElse si06 = ss(0,5) OrElse si06 = ss(0,7) OrElse si06 = ss(0,8) OrElse _
       si06 = ss(1,6) OrElse si06 = ss(2,6) OrElse si06 = ss(3,6) OrElse si06 = ss(4,6) OrElse _
       si06 = ss(5,6) OrElse si06 = ss(6,6) OrElse si06 = ss(7,6) OrElse si06 = ss(8,6) OrElse _
       si06 = ss(1,7) OrElse si06 = ss(1,8) OrElse si06 = ss(2,7) OrElse si06 = ss(2,8) Then GoTo si06
    ss(0,6) = si06
    'lw.WriteLine(" ==> si06 - Passed si06 = " & si06.ToString)
  Else
    If Go_up = True Then GoTo si05
  End If
si07:
  If si(0,7) = 0 Then
  Go_up = False
  si07 = si07 + 1
  If si07 > 9 Then
     si07 = 0
     ss(0,7) = 0
     Go_up = True
     GoTo si06
  End If
    If si07 = ss(0,0) OrElse si07 = ss(0,1) OrElse si07 = ss(0,2) OrElse si07 = ss(0,3) OrElse _
       si07 = ss(0,4) OrElse si07 = ss(0,5) OrElse si07 = ss(0,6) OrElse si07 = ss(0,8) OrElse _
       si07 = ss(1,7) OrElse si07 = ss(2,7) OrElse si07 = ss(3,7) OrElse si07 = ss(4,7) OrElse _
       si07 = ss(5,7) OrElse si07 = ss(6,7) OrElse si07 = ss(7,7) OrElse si07 = ss(8,7) OrElse _
       si07 = ss(1,6) OrElse si07 = ss(1,8) OrElse si07 = ss(2,6) OrElse si07 = ss(2,8) Then GoTo si07
    ss(0,7) = si07
    'lw.WriteLine(" ==> si07 - Passed si07 = " & si07.ToString)
  Else
    If Go_up = True Then GoTo si06
  End If
si08:
  If si(0,8) = 0 Then
  Go_up = False
  si08 = si08 + 1
  If si08 > 9 Then
     si08 = 0
     ss(0,8) = 0
     Go_up = True
     GoTo si07
  End If
    If si08 = ss(0,0) OrElse si08 = ss(0,1) OrElse si08 = ss(0,2) OrElse si08 = ss(0,3) OrElse _
       si08 = ss(0,4) OrElse si08 = ss(0,5) OrElse si08 = ss(0,6) OrElse si08 = ss(0,7) OrElse _
       si08 = ss(1,8) OrElse si08 = ss(2,8) OrElse si08 = ss(3,8) OrElse si08 = ss(4,8) OrElse _
       si08 = ss(5,8) OrElse si08 = ss(6,8) OrElse si08 = ss(7,8) OrElse si08 = ss(8,8) OrElse _
       si08 = ss(1,6) OrElse si08 = ss(1,7) OrElse si08 = ss(2,6) OrElse si08 = ss(2,7) Then GoTo si08
    ss(0,8) = si08
    'lw.WriteLine(" ==> si08 - Passed si08 = " & si08.ToString)
  Else
    If Go_up = True Then GoTo si07
  End If
si10:
  If si(1,0) = 0 Then
  Go_up = False
  si10 = si10 + 1
  If si10 > 9 Then
     si10 = 0
     ss(1,0) = 0
     Go_up = True
     GoTo si08
  End If
    If si10 = ss(1,1) OrElse si10 = ss(1,2) OrElse si10 = ss(1,3) OrElse si10 = ss(1,4) OrElse _
       si10 = ss(1,5) OrElse si10 = ss(1,6) OrElse si10 = ss(1,7) OrElse si10 = ss(1,8) OrElse _
       si10 = ss(0,0) OrElse si10 = ss(2,0) OrElse si10 = ss(3,0) OrElse si10 = ss(4,0) OrElse _
       si10 = ss(5,0) OrElse si10 = ss(6,0) OrElse si10 = ss(7,0) OrElse si10 = ss(8,0) OrElse _
       si10 = ss(0,1) OrElse si10 = ss(0,2) OrElse si10 = ss(2,1) OrElse si10 = ss(2,2) Then GoTo si10
    ss(1,0) = si10
    'lw.WriteLine(" ==> si10 - Passed si10 = " & si10.ToString)
  Else
    If Go_up = True Then GoTo si08
  End If
si11:
  If si(1,1) = 0 Then
  Go_up = False
  si11 = si11 + 1
  If si11 > 9 Then
     si11 = 0
     ss(1,1) = 0
     Go_up = True
     GoTo si10
  End If
    If si11 = ss(1,0) OrElse si11 = ss(1,2) OrElse si11 = ss(1,3) OrElse si11 = ss(1,4) OrElse _
       si11 = ss(1,5) OrElse si11 = ss(1,6) OrElse si11 = ss(1,7) OrElse si11 = ss(1,8) OrElse _
       si11 = ss(0,1) OrElse si11 = ss(2,1) OrElse si11 = ss(3,1) OrElse si11 = ss(4,1) OrElse _
       si11 = ss(5,1) OrElse si11 = ss(6,1) OrElse si11 = ss(7,1) OrElse si11 = ss(8,1) OrElse _
       si11 = ss(0,0) OrElse si11 = ss(0,2) OrElse si11 = ss(2,0) OrElse si11 = ss(2,2) Then GoTo si11
    ss(1,1) = si11
    'lw.WriteLine(" ==> si11 - Passed si11 = " & si11.ToString)
  Else
    If Go_up = True Then GoTo si10
  End If
si12:
  If si(1,2) = 0 Then
  Go_up = False
  si12 = si12 + 1
  If si12 > 9 Then
     si12 = 0
     ss(1,2) = 0
     Go_up = True
     GoTo si11
  End If
    If si12 = ss(1,0) OrElse si12 = ss(1,1) OrElse si12 = ss(1,3) OrElse si12 = ss(1,4) OrElse _
       si12 = ss(1,5) OrElse si12 = ss(1,6) OrElse si12 = ss(1,7) OrElse si12 = ss(1,8) OrElse _
       si12 = ss(0,2) OrElse si12 = ss(2,2) OrElse si12 = ss(3,2) OrElse si12 = ss(4,2) OrElse _
       si12 = ss(5,2) OrElse si12 = ss(6,2) OrElse si12 = ss(7,2) OrElse si12 = ss(8,2) OrElse _
       si12 = ss(0,0) OrElse si12 = ss(0,1) OrElse si12 = ss(2,0) OrElse si12 = ss(2,1) Then GoTo si12
    ss(1,2) = si12
    'lw.WriteLine(" ==> si12 - Passed si12 = " & si12.ToString)
  Else
    If Go_up = True Then GoTo si11
  End If
si13:
  If si(1,3) = 0 Then
  Go_up = False
  si13 = si13 + 1
  If si13 > 9 Then
     si13 = 0
     ss(1,3) = 0
     Go_up = True
     GoTo si12
  End If
    If si13 = ss(1,0) OrElse si13 = ss(1,1) OrElse si13 = ss(1,2) OrElse si13 = ss(1,4) OrElse _
       si13 = ss(1,5) OrElse si13 = ss(1,6) OrElse si13 = ss(1,7) OrElse si13 = ss(1,8) OrElse _
       si13 = ss(0,3) OrElse si13 = ss(2,3) OrElse si13 = ss(3,3) OrElse si13 = ss(4,3) OrElse _
       si13 = ss(5,3) OrElse si13 = ss(6,3) OrElse si13 = ss(7,3) OrElse si13 = ss(8,3) OrElse _
       si13 = ss(0,4) OrElse si13 = ss(0,5) OrElse si13 = ss(2,4) OrElse si13 = ss(2,5) Then GoTo si13
    ss(1,3) = si13
    'lw.WriteLine(" ==> si13 - Passed si13 = " & si13.ToString)
  Else
    If Go_up = True Then GoTo si12
  End If
si14:
  If si(1,4) = 0 Then
  Go_up = False
  si14 = si14 + 1
  If si14 > 9 Then
     si14 = 0
     ss(1,4) = 0
     Go_up = True
     GoTo si13
  End If
    If si14 = ss(1,0) OrElse si14 = ss(1,1) OrElse si14 = ss(1,2) OrElse si14 = ss(1,3) OrElse _
       si14 = ss(1,5) OrElse si14 = ss(1,6) OrElse si14 = ss(1,7) OrElse si14 = ss(1,8) OrElse _
       si14 = ss(0,4) OrElse si14 = ss(2,4) OrElse si14 = ss(3,4) OrElse si14 = ss(4,4) OrElse _
       si14 = ss(5,4) OrElse si14 = ss(6,4) OrElse si14 = ss(7,4) OrElse si14 = ss(8,4) OrElse _
       si14 = ss(0,3) OrElse si14 = ss(0,5) OrElse si14 = ss(2,3) OrElse si14 = ss(2,5) Then GoTo si14
    ss(1,4) = si14
    'lw.WriteLine(" ==> si14 - Passed si14 = " & si14.ToString)
  Else
    If Go_up = True Then GoTo si13
  End If
si15:
  If si(1,5) = 0 Then
  Go_up = False
  si15 = si15 + 1
  If si15 > 9 Then
     si15 = 0
     ss(1,5) = 0
     Go_up = True
     GoTo si14
  End If
    If si15 = ss(1,0) OrElse si15 = ss(1,1) OrElse si15 = ss(1,2) OrElse si15 = ss(1,3) OrElse _
       si15 = ss(1,4) OrElse si15 = ss(1,6) OrElse si15 = ss(1,7) OrElse si15 = ss(1,8) OrElse _
       si15 = ss(0,5) OrElse si15 = ss(2,5) OrElse si15 = ss(3,5) OrElse si15 = ss(4,5) OrElse _
       si15 = ss(5,5) OrElse si15 = ss(6,5) OrElse si15 = ss(7,5) OrElse si15 = ss(8,5) OrElse _
       si15 = ss(0,3) OrElse si15 = ss(0,4) OrElse si15 = ss(2,3) OrElse si15 = ss(2,4) Then GoTo si15
    ss(1,5) = si15
    'lw.WriteLine(" ==> si15 - Passed si15 = " & si15.ToString)
  Else
    If Go_up = True Then GoTo si14
  End If
si16:
  If si(1,6) = 0 Then
  Go_up = False
  si16 = si16 + 1
  If si16 > 9 Then
     si16 = 0
     ss(1,6) = 0
     Go_up = True
     GoTo si15
  End If
    If si16 = ss(1,0) OrElse si16 = ss(1,1) OrElse si16 = ss(1,2) OrElse si16 = ss(1,3) OrElse _
       si16 = ss(1,4) OrElse si16 = ss(1,5) OrElse si16 = ss(1,7) OrElse si16 = ss(1,8) OrElse _
       si16 = ss(0,6) OrElse si16 = ss(2,6) OrElse si16 = ss(3,6) OrElse si16 = ss(4,6) OrElse _
       si16 = ss(5,6) OrElse si16 = ss(6,6) OrElse si16 = ss(7,6) OrElse si16 = ss(8,6) OrElse _
       si16 = ss(0,7) OrElse si16 = ss(0,8) OrElse si16 = ss(2,7) OrElse si16 = ss(2,8) Then GoTo si16
    ss(1,6) = si16
    'lw.WriteLine(" ==> si16 - Passed si16 = " & si16.ToString)
  Else
    If Go_up = True Then GoTo si15
  End If
si17:
  If si(1,7) = 0 Then
  Go_up = False
  si17 = si17 + 1
  If si17 > 9 Then
     si17 = 0
     ss(1,7) = 0
     Go_up = True
     GoTo si16
  End If
    If si17 = ss(1,0) OrElse si17 = ss(1,1) OrElse si17 = ss(1,2) OrElse si17 = ss(1,3) OrElse _
       si17 = ss(1,4) OrElse si17 = ss(1,5) OrElse si17 = ss(1,6) OrElse si17 = ss(1,8) OrElse _
       si17 = ss(0,7) OrElse si17 = ss(2,7) OrElse si17 = ss(3,7) OrElse si17 = ss(4,7) OrElse _
       si17 = ss(5,7) OrElse si17 = ss(6,7) OrElse si17 = ss(7,7) OrElse si17 = ss(8,7) OrElse _
       si17 = ss(0,6) OrElse si17 = ss(0,8) OrElse si17 = ss(2,6) OrElse si17 = ss(2,8) Then GoTo si17
    ss(1,7) = si17
    'lw.WriteLine(" ==> si17 - Passed si17 = " & si17.ToString)
  Else
    If Go_up = True Then GoTo si16
  End If
si18:
  If si(1,8) = 0 Then
  Go_up = False
  si18 = si18 + 1
  If si18 > 9 Then
     si18 = 0
     ss(1,8) = 0
     Go_up = True
     GoTo si17
  End If
    If si18 = ss(1,0) OrElse si18 = ss(1,1) OrElse si18 = ss(1,2) OrElse si18 = ss(1,3) OrElse _
       si18 = ss(1,4) OrElse si18 = ss(1,5) OrElse si18 = ss(1,6) OrElse si18 = ss(1,7) OrElse _
       si18 = ss(0,8) OrElse si18 = ss(2,8) OrElse si18 = ss(3,8) OrElse si18 = ss(4,8) OrElse _
       si18 = ss(5,8) OrElse si18 = ss(6,8) OrElse si18 = ss(7,8) OrElse si18 = ss(8,8) OrElse _
       si18 = ss(0,6) OrElse si18 = ss(0,7) OrElse si18 = ss(2,6) OrElse si18 = ss(2,7) Then GoTo si18
    ss(1,8) = si18
    'lw.WriteLine(" ==> si18 - Passed si18 = " & si18.ToString)
  Else
    If Go_up = True Then GoTo si17
  End If
si20:
  If si(2,0) = 0 Then
  Go_up = False
  si20 = si20 + 1
  If si20 > 9 Then
     si20 = 0
     ss(2,0) = 0
     Go_up = True
     GoTo si18
  End If
    If si20 = ss(2,1) OrElse si20 = ss(2,2) OrElse si20 = ss(2,3) OrElse si20 = ss(2,4) OrElse _
       si20 = ss(2,5) OrElse si20 = ss(2,6) OrElse si20 = ss(2,7) OrElse si20 = ss(2,8) OrElse _
       si20 = ss(0,0) OrElse si20 = ss(1,0) OrElse si20 = ss(3,0) OrElse si20 = ss(4,0) OrElse _
       si20 = ss(5,0) OrElse si20 = ss(6,0) OrElse si20 = ss(7,0) OrElse si20 = ss(8,0) OrElse _
       si20 = ss(0,1) OrElse si20 = ss(0,2) OrElse si20 = ss(1,1) OrElse si20 = ss(1,2) Then GoTo si20
    ss(2,0) = si20
    'lw.WriteLine(" ==> si20 - Passed si20 = " & si20.ToString)
  Else
    If Go_up = True Then GoTo si18
  End If
si21:
  If si(2,1) = 0 Then
  Go_up = False
  si21 = si21 + 1
  If si21 > 9 Then
     si21 = 0
     ss(2,1) = 0
     Go_up = True
     GoTo si20
  End If
    If si21 = ss(2,0) OrElse si21 = ss(2,2) OrElse si21 = ss(2,3) OrElse si21 = ss(2,4) OrElse _
       si21 = ss(2,5) OrElse si21 = ss(2,6) OrElse si21 = ss(2,7) OrElse si21 = ss(2,8) OrElse _
       si21 = ss(0,1) OrElse si21 = ss(1,1) OrElse si21 = ss(3,1) OrElse si21 = ss(4,1) OrElse _
       si21 = ss(5,1) OrElse si21 = ss(6,1) OrElse si21 = ss(7,1) OrElse si21 = ss(8,1) OrElse _
       si21 = ss(0,0) OrElse si21 = ss(0,2) OrElse si21 = ss(1,0) OrElse si21 = ss(1,2) Then GoTo si21
    ss(2,1) = si21
    'lw.WriteLine(" ==> si21 - Passed si21 = " & si21.ToString)
  Else
    If Go_up = True Then GoTo si20
  End If
si22:
  If si(2,2) = 0 Then
  Go_up = False
  si22 = si22 + 1
  If si22 > 9 Then
     si22 = 0
     ss(2,2) = 0
     Go_up = True
     GoTo si21
  End If
    If si22 = ss(2,0) OrElse si22 = ss(2,1) OrElse si22 = ss(2,3) OrElse si22 = ss(2,4) OrElse _
       si22 = ss(2,5) OrElse si22 = ss(2,6) OrElse si22 = ss(2,7) OrElse si22 = ss(2,8) OrElse _
       si22 = ss(0,2) OrElse si22 = ss(1,2) OrElse si22 = ss(3,2) OrElse si22 = ss(4,2) OrElse _
       si22 = ss(5,2) OrElse si22 = ss(6,2) OrElse si22 = ss(7,2) OrElse si22 = ss(8,2) OrElse _
       si22 = ss(0,0) OrElse si22 = ss(0,1) OrElse si22 = ss(1,0) OrElse si22 = ss(1,1) Then GoTo si22
    ss(2,2) = si22
    'lw.WriteLine(" ==> si22 - Passed si22 = " & si22.ToString)
  Else
    If Go_up = True Then GoTo si21
  End If
si23:
  If si(2,3) = 0 Then
  Go_up = False
  si23 = si23 + 1
  If si23 > 9 Then
     si23 = 0
     ss(2,3) = 0
     Go_up = True
     GoTo si22
  End If
    If si23 = ss(2,0) OrElse si23 = ss(2,1) OrElse si23 = ss(2,2) OrElse si23 = ss(2,4) OrElse _
       si23 = ss(2,5) OrElse si23 = ss(2,6) OrElse si23 = ss(2,7) OrElse si23 = ss(2,8) OrElse _
       si23 = ss(0,3) OrElse si23 = ss(1,3) OrElse si23 = ss(3,3) OrElse si23 = ss(4,3) OrElse _
       si23 = ss(5,3) OrElse si23 = ss(6,3) OrElse si23 = ss(7,3) OrElse si23 = ss(8,3) OrElse _
       si23 = ss(0,4) OrElse si23 = ss(0,5) OrElse si23 = ss(1,4) OrElse si23 = ss(1,5) Then GoTo si23
    ss(2,3) = si23
    'lw.WriteLine(" ==> si23 - Passed si23 = " & si23.ToString)
  Else
    If Go_up = True Then GoTo si22
  End If
si24:
  If si(2,4) = 0 Then
  Go_up = False
  si24 = si24 + 1
  If si24 > 9 Then
     si24 = 0
     ss(2,4) = 0
     Go_up = True
     GoTo si23
  End If
    If si24 = ss(2,0) OrElse si24 = ss(2,1) OrElse si24 = ss(2,2) OrElse si24 = ss(2,3) OrElse _
       si24 = ss(2,5) OrElse si24 = ss(2,6) OrElse si24 = ss(2,7) OrElse si24 = ss(2,8) OrElse _
       si24 = ss(0,4) OrElse si24 = ss(1,4) OrElse si24 = ss(3,4) OrElse si24 = ss(4,4) OrElse _
       si24 = ss(5,4) OrElse si24 = ss(6,4) OrElse si24 = ss(7,4) OrElse si24 = ss(8,4) OrElse _
       si24 = ss(0,3) OrElse si24 = ss(0,5) OrElse si24 = ss(1,3) OrElse si24 = ss(1,5) Then GoTo si24
    ss(2,4) = si24
    'lw.WriteLine(" ==> si24 - Passed si24 = " & si22.ToString)
  Else
    If Go_up = True Then GoTo si23
  End If
si25:
  If si(2,5) = 0 Then
  Go_up = False
  si25 = si25 + 1
  If si25 > 9 Then
     si25 = 0
     ss(2,5) = 0
     Go_up = True
     GoTo si24
  End If
    If si25 = ss(2,0) OrElse si25 = ss(2,1) OrElse si25 = ss(2,2) OrElse si25 = ss(2,3) OrElse _
       si25 = ss(2,4) OrElse si25 = ss(2,6) OrElse si25 = ss(2,7) OrElse si25 = ss(2,8) OrElse _
       si25 = ss(0,5) OrElse si25 = ss(1,5) OrElse si25 = ss(3,5) OrElse si25 = ss(4,5) OrElse _
       si25 = ss(5,5) OrElse si25 = ss(6,5) OrElse si25 = ss(7,5) OrElse si25 = ss(8,5) OrElse _
       si25 = ss(0,3) OrElse si25 = ss(0,4) OrElse si25 = ss(1,3) OrElse si25 = ss(1,4) Then GoTo si25
    ss(2,5) = si25
    'lw.WriteLine(" ==> si25 - Passed si25 = " & si25.ToString)
  Else
    If Go_up = True Then GoTo si24
  End If
si26:
  If si(2,6) = 0 Then
  Go_up = False
  si26 = si26 + 1
  If si26 > 9 Then
     si26 = 0
     ss(2,6) = 0
     Go_up = True
     GoTo si25
  End If
    If si26 = ss(2,0) OrElse si26 = ss(2,1) OrElse si26 = ss(2,2) OrElse si26 = ss(2,3) OrElse _
       si26 = ss(2,4) OrElse si26 = ss(2,5) OrElse si26 = ss(2,7) OrElse si26 = ss(2,8) OrElse _
       si26 = ss(0,6) OrElse si26 = ss(1,6) OrElse si26 = ss(3,6) OrElse si26 = ss(4,6) OrElse _
       si26 = ss(5,6) OrElse si26 = ss(6,6) OrElse si26 = ss(7,6) OrElse si26 = ss(8,6) OrElse _
       si26 = ss(0,7) OrElse si26 = ss(0,8) OrElse si26 = ss(1,7) OrElse si26 = ss(1,8) Then GoTo si26
    ss(2,6) = si26
    'lw.WriteLine(" ==> si26 - Passed si26 = " & si26.ToString)
  Else
    If Go_up = True Then GoTo si25
  End If
si27:
  If si(2,7) = 0 Then
  Go_up = False
  si27 = si27 + 1
  If si27 > 9 Then
     si27 = 0
     ss(2,7) = 0
     Go_up = True
     GoTo si26
  End If
    If si27 = ss(2,0) OrElse si27 = ss(2,1) OrElse si27 = ss(2,2) OrElse si27 = ss(2,3) OrElse _
       si27 = ss(2,4) OrElse si27 = ss(2,5) OrElse si27 = ss(2,6) OrElse si27 = ss(2,8) OrElse _
       si27 = ss(0,7) OrElse si27 = ss(1,7) OrElse si27 = ss(3,7) OrElse si27 = ss(4,7) OrElse _
       si27 = ss(5,7) OrElse si27 = ss(6,7) OrElse si27 = ss(7,7) OrElse si27 = ss(8,7) OrElse _
       si27 = ss(0,6) OrElse si27 = ss(0,8) OrElse si27 = ss(1,6) OrElse si27 = ss(1,8) Then GoTo si27
    ss(2,7) = si27
    'lw.WriteLine(" ==> si27 - Passed si27 = " & si27.ToString)
  Else
    If Go_up = True Then GoTo si26
  End If
si28:
  If si(2,8) = 0 Then
  Go_up = False
  si28 = si28 + 1
  If si28 > 9 Then
     si28 = 0
     ss(2,8) = 0
     Go_up = True
     GoTo si27
  End If
    If si28 = ss(2,0) OrElse si28 = ss(2,1) OrElse si28 = ss(2,2) OrElse si28 = ss(2,3) OrElse _
       si28 = ss(2,4) OrElse si28 = ss(2,5) OrElse si28 = ss(2,6) OrElse si28 = ss(2,7) OrElse _
       si28 = ss(0,8) OrElse si28 = ss(1,8) OrElse si28 = ss(3,8) OrElse si28 = ss(4,8) OrElse _
       si28 = ss(5,8) OrElse si28 = ss(6,8) OrElse si28 = ss(7,8) OrElse si28 = ss(8,8) OrElse _
       si28 = ss(0,6) OrElse si28 = ss(0,7) OrElse si28 = ss(1,6) OrElse si28 = ss(1,7) Then GoTo si28
    ss(2,8) = si28
    'lw.WriteLine(" ==> si28 - Passed si28 = " & si28.ToString)
  Else
    If Go_up = True Then GoTo si27
  End If
si30:
  If si(3,0) = 0 Then
  Go_up = False
  si30 = si30 + 1
  If si30 > 9 Then
     si30 = 0
     ss(3,0) = 0
     Go_up = True
     GoTo si28
  End If
    If si30 = ss(3,1) OrElse si30 = ss(3,2) OrElse si30 = ss(3,3) OrElse si30 = ss(3,4) OrElse _
       si30 = ss(3,5) OrElse si30 = ss(3,6) OrElse si30 = ss(3,7) OrElse si30 = ss(3,8) OrElse _
       si30 = ss(0,0) OrElse si30 = ss(1,0) OrElse si30 = ss(2,0) OrElse si30 = ss(4,0) OrElse _
       si30 = ss(5,0) OrElse si30 = ss(6,0) OrElse si30 = ss(7,0) OrElse si30 = ss(8,0) OrElse _
       si30 = ss(4,1) OrElse si30 = ss(4,2) OrElse si30 = ss(5,1) OrElse si30 = ss(5,2) Then GoTo si30
    ss(3,0) = si30
    'lw.WriteLine(" ==> si30 - Passed si30 = " & si30.ToString)
  Else
    If Go_up = True Then GoTo si28
  End If
si31:
  If si(3,1) = 0 Then
  Go_up = False
  si31 = si31 + 1
  If si31 > 9 Then
     si31 = 0
     ss(3,1) = 0
     Go_up = True
     GoTo si30
  End If
    If si31 = ss(3,0) OrElse si31 = ss(3,2) OrElse si31 = ss(3,3) OrElse si31 = ss(3,4) OrElse _
       si31 = ss(3,5) OrElse si31 = ss(3,6) OrElse si31 = ss(3,7) OrElse si31 = ss(3,8) OrElse _
       si31 = ss(0,1) OrElse si31 = ss(1,1) OrElse si31 = ss(2,1) OrElse si31 = ss(4,1) OrElse _
       si31 = ss(5,1) OrElse si31 = ss(6,1) OrElse si31 = ss(7,1) OrElse si31 = ss(8,1) OrElse _
       si31 = ss(4,0) OrElse si31 = ss(4,2) OrElse si31 = ss(5,0) OrElse si31 = ss(5,2) Then GoTo si31
    ss(3,1) = si31
    'lw.WriteLine(" ==> si31 - Passed si31 = " & si31.ToString)
  Else
    If Go_up = True Then GoTo si30
  End If
si32:
  If si(3,2) = 0 Then
  Go_up = False
  si32 = si32 + 1
  If si32 > 9 Then
     si32 = 0
     ss(3,2) = 0
     Go_up = True
     GoTo si31
  End If
    If si32 = ss(3,0) OrElse si32 = ss(3,1) OrElse si32 = ss(3,3) OrElse si32 = ss(3,4) OrElse _
       si32 = ss(3,5) OrElse si32 = ss(3,6) OrElse si32 = ss(3,7) OrElse si32 = ss(3,8) OrElse _
       si32 = ss(0,2) OrElse si32 = ss(1,2) OrElse si32 = ss(2,2) OrElse si32 = ss(4,2) OrElse _
       si32 = ss(5,2) OrElse si32 = ss(6,2) OrElse si32 = ss(7,2) OrElse si32 = ss(8,2) OrElse _
       si32 = ss(4,0) OrElse si32 = ss(4,1) OrElse si32 = ss(5,0) OrElse si32 = ss(5,1) Then GoTo si32
    ss(3,2) = si32
    'lw.WriteLine(" ==> si32 - Passed si32 = " & si32.ToString)
  Else
    If Go_up = True Then GoTo si31
  End If
si33:
  If si(3,3) = 0 Then
  Go_up = False
  si33 = si33 + 1
  If si33 > 9 Then
     si33 = 0
     ss(3,3) = 0
     Go_up = True
     GoTo si32
  End If
    If si33 = ss(3,0) OrElse si33 = ss(3,1) OrElse si33 = ss(3,2) OrElse si33 = ss(3,4) OrElse _
       si33 = ss(3,5) OrElse si33 = ss(3,6) OrElse si33 = ss(3,7) OrElse si33 = ss(3,8) OrElse _
       si33 = ss(0,3) OrElse si33 = ss(1,3) OrElse si33 = ss(2,3) OrElse si33 = ss(4,3) OrElse _
       si33 = ss(5,3) OrElse si33 = ss(6,3) OrElse si33 = ss(7,3) OrElse si33 = ss(8,3) OrElse _
       si33 = ss(4,4) OrElse si33 = ss(4,5) OrElse si33 = ss(5,4) OrElse si33 = ss(5,5) Then GoTo si33
    ss(3,3) = si33
    'lw.WriteLine(" ==> si33 - Passed si33 = " & si33.ToString)
  Else
    If Go_up = True Then GoTo si32
  End If
si34:
  If si(3,4) = 0 Then
  Go_up = False
  si34 = si34 + 1
  If si34 > 9 Then
     si34 = 0
     ss(3,4) = 0
     Go_up = True
     GoTo si33
  End If
    If si34 = ss(3,0) OrElse si34 = ss(3,1) OrElse si34 = ss(3,2) OrElse si34 = ss(3,3) OrElse _
       si34 = ss(3,5) OrElse si34 = ss(3,6) OrElse si34 = ss(3,7) OrElse si34 = ss(3,8) OrElse _
       si34 = ss(0,4) OrElse si34 = ss(1,4) OrElse si34 = ss(2,4) OrElse si34 = ss(4,4) OrElse _
       si34 = ss(5,4) OrElse si34 = ss(6,4) OrElse si34 = ss(7,4) OrElse si34 = ss(8,4) OrElse _
       si34 = ss(4,3) OrElse si34 = ss(4,5) OrElse si34 = ss(5,3) OrElse si34 = ss(5,5) Then GoTo si34
    ss(3,4) = si34
    'lw.WriteLine(" ==> si34 - Passed si34 = " & si34.ToString)
  Else
    If Go_up = True Then GoTo si33
  End If
si35:
  If si(3,5) = 0 Then
  Go_up = False
  si35 = si35 + 1
  If si35 > 9 Then
     si35 = 0
     ss(3,5) = 0
     Go_up = True
     GoTo si34
  End If
    If si35 = ss(3,0) OrElse si35 = ss(3,1) OrElse si35 = ss(3,2) OrElse si35 = ss(3,3) OrElse _
       si35 = ss(3,4) OrElse si35 = ss(3,6) OrElse si35 = ss(3,7) OrElse si35 = ss(3,8) OrElse _
       si35 = ss(0,5) OrElse si35 = ss(1,5) OrElse si35 = ss(2,5) OrElse si35 = ss(4,5) OrElse _
       si35 = ss(5,5) OrElse si35 = ss(6,5) OrElse si35 = ss(7,5) OrElse si35 = ss(8,5) OrElse _
       si35 = ss(4,3) OrElse si35 = ss(4,4) OrElse si35 = ss(5,3) OrElse si35 = ss(5,4) Then GoTo si35
    ss(3,5) = si35
    'lw.WriteLine(" ==> si35 - Passed si35 = " & si35.ToString)
  Else
    If Go_up = True Then GoTo si34
  End If
si36:
  If si(3,6) = 0 Then
  Go_up = False
  si36 = si36 + 1
  If si36 > 9 Then
     si36 = 0
     ss(3,6) = 0
     Go_up = True
     GoTo si35
  End If
    If si36 = ss(3,0) OrElse si36 = ss(3,1) OrElse si36 = ss(3,2) OrElse si36 = ss(3,3) OrElse _
       si36 = ss(3,4) OrElse si36 = ss(3,5) OrElse si36 = ss(3,7) OrElse si36 = ss(3,8) OrElse _
       si36 = ss(0,6) OrElse si36 = ss(1,6) OrElse si36 = ss(2,6) OrElse si36 = ss(4,6) OrElse _
       si36 = ss(5,6) OrElse si36 = ss(6,6) OrElse si36 = ss(7,6) OrElse si36 = ss(8,6) OrElse _
       si36 = ss(4,7) OrElse si36 = ss(4,8) OrElse si36 = ss(5,7) OrElse si36 = ss(5,8) Then GoTo si36
    ss(3,6) = si36
    'lw.WriteLine(" ==> si36 - Passed si36 = " & si36.ToString)
  Else
    If Go_up = True Then GoTo si35
  End If
si37:
  If si(3,7) = 0 Then
  Go_up = False
  si37 = si37 + 1
  If si37 > 9 Then
     si37 = 0
     ss(3,7) = 0
     Go_up = True
     GoTo si36
  End If
    If si37 = ss(3,0) OrElse si37 = ss(3,1) OrElse si37 = ss(3,2) OrElse si37 = ss(3,3) OrElse _
       si37 = ss(3,4) OrElse si37 = ss(3,5) OrElse si37 = ss(3,6) OrElse si37 = ss(3,8) OrElse _
       si37 = ss(0,7) OrElse si37 = ss(1,7) OrElse si37 = ss(2,7) OrElse si37 = ss(4,7) OrElse _
       si37 = ss(5,7) OrElse si37 = ss(6,7) OrElse si37 = ss(7,7) OrElse si37 = ss(8,7) OrElse _
       si37 = ss(4,6) OrElse si37 = ss(4,8) OrElse si37 = ss(5,6) OrElse si37 = ss(5,8) Then GoTo si37
    ss(3,7) = si37
    'lw.WriteLine(" ==> si37 - Passed si37 = " & si37.ToString)
  Else
    If Go_up = True Then GoTo si36
  End If
si38:
  If si(3,8) = 0 Then
  Go_up = False
  si38 = si38 + 1
  If si38 > 9 Then
     si38 = 0
     ss(3,8) = 0
     Go_up = True
     GoTo si37
  End If
    If si38 = ss(3,0) OrElse si38 = ss(3,1) OrElse si38 = ss(3,2) OrElse si38 = ss(3,3) OrElse _
       si38 = ss(3,4) OrElse si38 = ss(3,5) OrElse si38 = ss(3,6) OrElse si38 = ss(3,7) OrElse _
       si38 = ss(0,8) OrElse si38 = ss(1,8) OrElse si38 = ss(2,8) OrElse si38 = ss(4,8) OrElse _
       si38 = ss(5,8) OrElse si38 = ss(6,8) OrElse si38 = ss(7,8) OrElse si38 = ss(8,8) OrElse _
       si38 = ss(4,6) OrElse si38 = ss(4,7) OrElse si38 = ss(5,6) OrElse si38 = ss(5,7) Then GoTo si38
    ss(3,8) = si38
    'lw.WriteLine(" ==> si38 - Passed si38 = " & si38.ToString)
  Else
    If Go_up = True Then GoTo si37
  End If
si40:
  If si(4,0) = 0 Then
  Go_up = False
  si40 = si40 + 1
  If si40 > 9 Then
     si40 = 0
     ss(4,0) = 0
     Go_up = True
     GoTo si38
  End If
    If si40 = ss(4,1) OrElse si40 = ss(4,2) OrElse si40 = ss(4,3) OrElse si40 = ss(4,4) OrElse _
       si40 = ss(4,5) OrElse si40 = ss(4,6) OrElse si40 = ss(4,7) OrElse si40 = ss(4,8) OrElse _
       si40 = ss(0,0) OrElse si40 = ss(1,0) OrElse si40 = ss(2,0) OrElse si40 = ss(3,0) OrElse _
       si40 = ss(5,0) OrElse si40 = ss(6,0) OrElse si40 = ss(7,0) OrElse si40 = ss(8,0) OrElse _
       si40 = ss(3,1) OrElse si40 = ss(3,2) OrElse si40 = ss(5,1) OrElse si40 = ss(5,2) Then GoTo si40
    ss(4,0) = si40
    'lw.WriteLine(" ==> si40 - Passed si40 = " & si40.ToString)
  Else
    If Go_up = True Then GoTo si38
  End If
si41:
  If si(4,1) = 0 Then
  Go_up = False
  si41 = si41 + 1
  If si41 > 9 Then
     si41 = 0
     ss(4,1) = 0
     Go_up = True
     GoTo si40
  End If
    If si41 = ss(4,0) OrElse si41 = ss(4,2) OrElse si41 = ss(4,3) OrElse si41 = ss(4,4) OrElse _
       si41 = ss(4,5) OrElse si41 = ss(4,6) OrElse si41 = ss(4,7) OrElse si41 = ss(4,8) OrElse _
       si41 = ss(0,1) OrElse si41 = ss(1,1) OrElse si41 = ss(2,1) OrElse si41 = ss(3,1) OrElse _
       si41 = ss(5,1) OrElse si41 = ss(6,1) OrElse si41 = ss(7,1) OrElse si41 = ss(8,1) OrElse _
       si41 = ss(3,0) OrElse si41 = ss(3,2) OrElse si41 = ss(5,0) OrElse si41 = ss(5,2) Then GoTo si41
    ss(4,1) = si41
    'lw.WriteLine(" ==> si41 - Passed si41 = " & si41.ToString)
  Else
    If Go_up = True Then GoTo si40
  End If
si42:
  If si(4,2) = 0 Then
  Go_up = False
  si42 = si42 + 1
  If si42 > 9 Then
     si42 = 0
     ss(4,2) = 0
     Go_up = True
     GoTo si41
  End If
    If si42 = ss(4,0) OrElse si42 = ss(4,1) OrElse si42 = ss(4,3) OrElse si42 = ss(4,4) OrElse _
       si42 = ss(4,5) OrElse si42 = ss(4,6) OrElse si42 = ss(4,7) OrElse si42 = ss(4,8) OrElse _
       si42 = ss(0,2) OrElse si42 = ss(1,2) OrElse si42 = ss(2,2) OrElse si42 = ss(3,2) OrElse _
       si42 = ss(5,2) OrElse si42 = ss(6,2) OrElse si42 = ss(7,2) OrElse si42 = ss(8,2) OrElse _
       si42 = ss(3,0) OrElse si42 = ss(3,1) OrElse si42 = ss(5,0) OrElse si42 = ss(5,1) Then GoTo si42
    ss(4,2) = si42
    'lw.WriteLine(" ==> si42 - Passed si42 = " & si42.ToString)
  Else
    If Go_up = True Then GoTo si41
  End If
si43:
  If si(4,3) = 0 Then
  Go_up = False
  si43 = si43 + 1
  If si43 > 9 Then
     si43 = 0
     ss(4,3) = 0
     Go_up = True
     GoTo si42
  End If
    If si43 = ss(4,0) OrElse si43 = ss(4,1) OrElse si43 = ss(4,2) OrElse si43 = ss(4,4) OrElse _
       si43 = ss(4,5) OrElse si43 = ss(4,6) OrElse si43 = ss(4,7) OrElse si43 = ss(4,8) OrElse _
       si43 = ss(0,3) OrElse si43 = ss(1,3) OrElse si43 = ss(2,3) OrElse si43 = ss(3,3) OrElse _
       si43 = ss(5,3) OrElse si43 = ss(6,3) OrElse si43 = ss(7,3) OrElse si43 = ss(8,3) OrElse _
       si43 = ss(3,4) OrElse si43 = ss(3,5) OrElse si43 = ss(5,4) OrElse si43 = ss(5,5) Then GoTo si43
    ss(4,3) = si43
    'lw.WriteLine(" ==> si43 - Passed si43 = " & si43.ToString)
  Else
    If Go_up = True Then GoTo si42
  End If
si44:
  If si(4,4) = 0 Then
  Go_up = False
  si44 = si44 + 1
  If si44 > 9 Then
     si44 = 0
     ss(4,4) = 0
     Go_up = True
     GoTo si43
  End If
    If si44 = ss(4,0) OrElse si44 = ss(4,1) OrElse si44 = ss(4,2) OrElse si44 = ss(4,3) OrElse _
       si44 = ss(4,5) OrElse si44 = ss(4,6) OrElse si44 = ss(4,7) OrElse si44 = ss(4,8) OrElse _
       si44 = ss(0,4) OrElse si44 = ss(1,4) OrElse si44 = ss(2,4) OrElse si44 = ss(3,4) OrElse _
       si44 = ss(5,4) OrElse si44 = ss(6,4) OrElse si44 = ss(7,4) OrElse si44 = ss(8,4) OrElse _
       si44 = ss(3,3) OrElse si44 = ss(3,5) OrElse si44 = ss(5,3) OrElse si44 = ss(5,5) Then GoTo si44
    ss(4,4) = si44
    'lw.WriteLine(" ==> si44 - Passed si44 = " & si44.ToString)
  Else
    If Go_up = True Then GoTo si43
  End If
si45:
  If si(4,5) = 0 Then
  Go_up = False
  si45 = si45 + 1
  If si45 > 9 Then
     si45 = 0
     ss(4,5) = 0
     Go_up = True
     GoTo si44
  End If
    If si45 = ss(4,0) OrElse si45 = ss(4,1) OrElse si45 = ss(4,2) OrElse si45 = ss(4,3) OrElse _
       si45 = ss(4,4) OrElse si45 = ss(4,6) OrElse si45 = ss(4,7) OrElse si45 = ss(4,8) OrElse _
       si45 = ss(0,5) OrElse si45 = ss(1,5) OrElse si45 = ss(2,5) OrElse si45 = ss(3,5) OrElse _
       si45 = ss(5,5) OrElse si45 = ss(6,5) OrElse si45 = ss(7,5) OrElse si45 = ss(8,5) OrElse _
       si45 = ss(3,3) OrElse si45 = ss(3,4) OrElse si45 = ss(5,3) OrElse si45 = ss(5,4) Then GoTo si45
    ss(4,5) = si45
    'lw.WriteLine(" ==> si45 - Passed si45 = " & si45.ToString)
  Else
    If Go_up = True Then GoTo si44
  End If
si46:
  If si(4,6) = 0 Then
  Go_up = False
  si46 = si46 + 1
  If si46 > 9 Then
     si46 = 0
     ss(4,6) = 0
     Go_up = True
     GoTo si45
  End If
    If si46 = ss(4,0) OrElse si46 = ss(4,1) OrElse si46 = ss(4,2) OrElse si46 = ss(4,3) OrElse _
       si46 = ss(4,4) OrElse si46 = ss(4,5) OrElse si46 = ss(4,7) OrElse si46 = ss(4,8) OrElse _
       si46 = ss(0,6) OrElse si46 = ss(1,6) OrElse si46 = ss(2,6) OrElse si46 = ss(3,6) OrElse _
       si46 = ss(5,6) OrElse si46 = ss(6,6) OrElse si46 = ss(7,6) OrElse si46 = ss(8,6) OrElse _
       si46 = ss(3,7) OrElse si46 = ss(3,8) OrElse si46 = ss(5,7) OrElse si46 = ss(5,8) Then GoTo si46
    ss(4,6) = si46
    'lw.WriteLine(" ==> si46 - Passed si46 = " & si46.ToString)
  Else
    If Go_up = True Then GoTo si45
  End If
si47:
  If si(4,7) = 0 Then
  Go_up = False
  si47 = si47 + 1
  If si47 > 9 Then
     si47 = 0
     ss(4,7) = 0
     Go_up = True
     GoTo si46
  End If
    If si47 = ss(4,0) OrElse si47 = ss(4,1) OrElse si47 = ss(4,2) OrElse si47 = ss(4,3) OrElse _
       si47 = ss(4,4) OrElse si47 = ss(4,5) OrElse si47 = ss(4,6) OrElse si47 = ss(4,8) OrElse _
       si47 = ss(0,7) OrElse si47 = ss(1,7) OrElse si47 = ss(2,7) OrElse si47 = ss(3,7) OrElse _
       si47 = ss(5,7) OrElse si47 = ss(6,7) OrElse si47 = ss(7,7) OrElse si47 = ss(8,7) OrElse _
       si47 = ss(3,6) OrElse si47 = ss(3,8) OrElse si47 = ss(5,6) OrElse si47 = ss(5,8) Then GoTo si47
    ss(4,7) = si47
    'lw.WriteLine(" ==> si47 - Passed si47 = " & si47.ToString)
  Else
    If Go_up = True Then GoTo si46
  End If
si48:
  If si(4,8) = 0 Then
  Go_up = False
  si48 = si48 + 1
  If si48 > 9 Then
     si48 = 0
     ss(4,8) = 0
     Go_up = True
     GoTo si47
  End If
    If si48 = ss(4,0) OrElse si48 = ss(4,1) OrElse si48 = ss(4,2) OrElse si48 = ss(4,3) OrElse _
       si48 = ss(4,4) OrElse si48 = ss(4,5) OrElse si48 = ss(4,6) OrElse si48 = ss(4,7) OrElse _
       si48 = ss(0,8) OrElse si48 = ss(1,8) OrElse si48 = ss(2,8) OrElse si48 = ss(3,8) OrElse _
       si48 = ss(5,8) OrElse si48 = ss(6,8) OrElse si48 = ss(7,8) OrElse si48 = ss(8,8) OrElse _
       si48 = ss(3,6) OrElse si48 = ss(3,7) OrElse si48 = ss(5,6) OrElse si48 = ss(5,7) Then GoTo si48
    ss(4,8) = si48
    'lw.WriteLine(" ==> si48 - Passed si48 = " & si48.ToString)
  Else
    If Go_up = True Then GoTo si47
  End If
si50:
  If si(5,0) = 0 Then
  Go_up = False
  si50 = si50 + 1
  If si50 > 9 Then
     si50 = 0
     ss(5,0) = 0
     Go_up = True
     GoTo si48
  End If
    If si50 = ss(5,1) OrElse si50 = ss(5,2) OrElse si50 = ss(5,3) OrElse si50 = ss(5,4) OrElse _
       si50 = ss(5,5) OrElse si50 = ss(5,6) OrElse si50 = ss(5,7) OrElse si50 = ss(5,8) OrElse _
       si50 = ss(0,0) OrElse si50 = ss(1,0) OrElse si50 = ss(2,0) OrElse si50 = ss(3,0) OrElse _
       si50 = ss(4,0) OrElse si50 = ss(6,0) OrElse si50 = ss(7,0) OrElse si50 = ss(8,0) OrElse _
       si50 = ss(3,1) OrElse si50 = ss(3,2) OrElse si50 = ss(4,1) OrElse si50 = ss(4,2) Then GoTo si50
    ss(5,0) = si50
    'lw.WriteLine(" ==> si50 - Passed si50 = " & si50.ToString)
  Else
    If Go_up = True Then GoTo si48
  End If
si51:
  If si(5,1) = 0 Then
  Go_up = False
  si51 = si51 + 1
  If si51 > 9 Then
     si51 = 0
     ss(5,1) = 0
     Go_up = True
     GoTo si50
  End If
    If si51 = ss(5,0) OrElse si51 = ss(5,2) OrElse si51 = ss(5,3) OrElse si51 = ss(5,4) OrElse _
       si51 = ss(5,5) OrElse si51 = ss(5,6) OrElse si51 = ss(5,7) OrElse si51 = ss(5,8) OrElse _
       si51 = ss(0,1) OrElse si51 = ss(1,1) OrElse si51 = ss(2,1) OrElse si51 = ss(3,1) OrElse _
       si51 = ss(4,1) OrElse si51 = ss(6,1) OrElse si51 = ss(7,1) OrElse si51 = ss(8,1) OrElse _
       si51 = ss(3,0) OrElse si51 = ss(3,2) OrElse si51 = ss(4,0) OrElse si51 = ss(4,2) Then GoTo si51
    ss(5,1) = si51
    'lw.WriteLine(" ==> si51 - Passed si51 = " & si51.ToString)
  Else
    If Go_up = True Then GoTo si50
  End If
si52:
  If si(5,2) = 0 Then
  Go_up = False
  si52 = si52 + 1
  If si52 > 9 Then
     si52 = 0
     ss(5,2) = 0
     Go_up = True
     GoTo si51
  End If
    If si52 = ss(5,0) OrElse si52 = ss(5,1) OrElse si52 = ss(5,3) OrElse si52 = ss(5,4) OrElse _
       si52 = ss(5,5) OrElse si52 = ss(5,6) OrElse si52 = ss(5,7) OrElse si52 = ss(5,8) OrElse _
       si52 = ss(0,2) OrElse si52 = ss(1,2) OrElse si52 = ss(2,2) OrElse si52 = ss(3,2) OrElse _
       si52 = ss(4,2) OrElse si52 = ss(6,2) OrElse si52 = ss(7,2) OrElse si52 = ss(8,2) OrElse _
       si52 = ss(3,0) OrElse si52 = ss(3,1) OrElse si52 = ss(4,0) OrElse si52 = ss(4,1) Then GoTo si52
    ss(5,2) = si52
    'lw.WriteLine(" ==> si52 - Passed si52 = " & si52.ToString)
  Else
    If Go_up = True Then GoTo si51
  End If
si53:
  If si(5,3) = 0 Then
  Go_up = False
  si53 = si53 + 1
  If si53 > 9 Then
     si53 = 0
     ss(5,3) = 0
     Go_up = True
     GoTo si52
  End If
    If si53 = ss(5,0) OrElse si53 = ss(5,1) OrElse si53 = ss(5,2) OrElse si53 = ss(5,4) OrElse _
       si53 = ss(5,5) OrElse si53 = ss(5,6) OrElse si53 = ss(5,7) OrElse si53 = ss(5,8) OrElse _
       si53 = ss(0,3) OrElse si53 = ss(1,3) OrElse si53 = ss(2,3) OrElse si53 = ss(3,3) OrElse _
       si53 = ss(4,3) OrElse si53 = ss(6,3) OrElse si53 = ss(7,3) OrElse si53 = ss(8,3) OrElse _
       si53 = ss(3,4) OrElse si53 = ss(3,5) OrElse si53 = ss(4,4) OrElse si53 = ss(4,5) Then GoTo si53
    ss(5,3) = si53
    'lw.WriteLine(" ==> si53 - Passed si53 = " & si53.ToString)
  Else
    If Go_up = True Then GoTo si52
  End If
si54:
  If si(5,4) = 0 Then
  Go_up = False
  si54 = si54 + 1
  If si54 > 9 Then
     si54 = 0
     ss(5,4) = 0
     Go_up = True
     GoTo si53
  End If
    If si54 = ss(5,0) OrElse si54 = ss(5,1) OrElse si54 = ss(5,2) OrElse si54 = ss(5,3) OrElse _
       si54 = ss(5,5) OrElse si54 = ss(5,6) OrElse si54 = ss(5,7) OrElse si54 = ss(5,8) OrElse _
       si54 = ss(0,4) OrElse si54 = ss(1,4) OrElse si54 = ss(2,4) OrElse si54 = ss(3,4) OrElse _
       si54 = ss(4,4) OrElse si54 = ss(6,4) OrElse si54 = ss(7,4) OrElse si54 = ss(8,4) OrElse _
       si54 = ss(3,3) OrElse si54 = ss(3,5) OrElse si54 = ss(4,3) OrElse si54 = ss(4,5) Then GoTo si54
    ss(5,4) = si54
    'lw.WriteLine(" ==> si54 - Passed si54 = " & si54.ToString)
  Else
    If Go_up = True Then GoTo si53
  End If
si55:
  If si(5,5) = 0 Then
  Go_up = False
  si55 = si55 + 1
  If si55 > 9 Then
     si55 = 0
     ss(5,5) = 0
     Go_up = True
     GoTo si54
  End If
    If si55 = ss(5,0) OrElse si55 = ss(5,1) OrElse si55 = ss(5,2) OrElse si55 = ss(5,3) OrElse _
       si55 = ss(5,4) OrElse si55 = ss(5,6) OrElse si55 = ss(5,7) OrElse si55 = ss(5,8) OrElse _
       si55 = ss(0,5) OrElse si55 = ss(1,5) OrElse si55 = ss(2,5) OrElse si55 = ss(3,5) OrElse _
       si55 = ss(4,5) OrElse si55 = ss(6,5) OrElse si55 = ss(7,5) OrElse si55 = ss(8,5) OrElse _
       si55 = ss(3,3) OrElse si55 = ss(3,4) OrElse si55 = ss(4,3) OrElse si55 = ss(4,4) Then GoTo si55
    ss(5,5) = si55
    'lw.WriteLine(" ==> si55 - Passed si55 = " & si55.ToString)
  Else
    If Go_up = True Then GoTo si54
  End If
si56:
  If si(5,6) = 0 Then
  Go_up = False
  si56 = si56 + 1
  If si56 > 9 Then
     si56 = 0
     ss(5,6) = 0
     Go_up = True
     GoTo si55
  End If
    If si56 = ss(5,0) OrElse si56 = ss(5,1) OrElse si56 = ss(5,2) OrElse si56 = ss(5,3) OrElse _
       si56 = ss(5,4) OrElse si56 = ss(5,5) OrElse si56 = ss(5,7) OrElse si56 = ss(5,8) OrElse _
       si56 = ss(0,6) OrElse si56 = ss(1,6) OrElse si56 = ss(2,6) OrElse si56 = ss(3,6) OrElse _
       si56 = ss(4,6) OrElse si56 = ss(6,6) OrElse si56 = ss(7,6) OrElse si56 = ss(8,6) OrElse _
       si56 = ss(3,7) OrElse si56 = ss(3,8) OrElse si56 = ss(4,7) OrElse si56 = ss(4,8) Then GoTo si56
    ss(5,6) = si56
    'lw.WriteLine(" ==> si56 - Passed si56 = " & si56.ToString)
  Else
    If Go_up = True Then GoTo si55
  End If
si57:
  If si(5,7) = 0 Then
  Go_up = False
  si57 = si57 + 1
  If si57 > 9 Then
     si57 = 0
     ss(5,7) = 0
     Go_up = True
     GoTo si56
  End If
    If si57 = ss(5,0) OrElse si57 = ss(5,1) OrElse si57 = ss(5,2) OrElse si57 = ss(5,3) OrElse _
       si57 = ss(5,4) OrElse si57 = ss(5,5) OrElse si57 = ss(5,6) OrElse si57 = ss(5,8) OrElse _
       si57 = ss(0,7) OrElse si57 = ss(1,7) OrElse si57 = ss(2,7) OrElse si57 = ss(3,7) OrElse _
       si57 = ss(4,7) OrElse si57 = ss(6,7) OrElse si57 = ss(7,7) OrElse si57 = ss(8,7) OrElse _
       si57 = ss(3,6) OrElse si57 = ss(3,8) OrElse si57 = ss(4,6) OrElse si57 = ss(4,8) Then GoTo si57
    ss(5,7) = si57
    'lw.WriteLine(" ==> si57 - Passed si57 = " & si57.ToString)
  Else
    If Go_up = True Then GoTo si56
  End If
si58:
  If si(5,8) = 0 Then
  Go_up = False
  si58 = si58 + 1
  If si58 > 9 Then
     si58 = 0
     ss(5,8) = 0
     Go_up = True
     GoTo si57
  End If
    If si58 = ss(5,0) OrElse si58 = ss(5,1) OrElse si58 = ss(5,2) OrElse si58 = ss(5,3) OrElse _
       si58 = ss(5,4) OrElse si58 = ss(5,5) OrElse si58 = ss(5,6) OrElse si58 = ss(5,7) OrElse _
       si58 = ss(0,8) OrElse si58 = ss(1,8) OrElse si58 = ss(2,8) OrElse si58 = ss(3,8) OrElse _
       si58 = ss(4,8) OrElse si58 = ss(6,8) OrElse si58 = ss(7,8) OrElse si58 = ss(8,8) OrElse _
       si58 = ss(3,6) OrElse si58 = ss(3,7) OrElse si58 = ss(4,6) OrElse si58 = ss(4,7) Then GoTo si58
    ss(5,8) = si58
    'lw.WriteLine(" ==> si58 - Passed si58 = " & si58.ToString)
  Else
    If Go_up = True Then GoTo si57
  End If
si60:
  If si(6,0) = 0 Then
  Go_up = False
  si60 = si60 + 1
  If si60 > 9 Then
     si60 = 0
     ss(6,0) = 0
     Go_up = True
     GoTo si58
  End If
    If si60 = ss(6,1) OrElse si60 = ss(6,2) OrElse si60 = ss(6,3) OrElse si60 = ss(6,4) OrElse _
       si60 = ss(6,5) OrElse si60 = ss(6,6) OrElse si60 = ss(6,7) OrElse si60 = ss(6,8) OrElse _
       si60 = ss(0,0) OrElse si60 = ss(1,0) OrElse si60 = ss(2,0) OrElse si60 = ss(3,0) OrElse _
       si60 = ss(4,0) OrElse si60 = ss(6,0) OrElse si60 = ss(7,0) OrElse si60 = ss(8,0) OrElse _
       si60 = ss(7,1) OrElse si60 = ss(7,2) OrElse si60 = ss(8,1) OrElse si60 = ss(8,2) Then GoTo si60
    ss(6,0) = si60
    'lw.WriteLine(" ==> si60 - Passed si60 = " & si60.ToString)
  Else
    If Go_up = True Then GoTo si58
  End If
si61:
  If si(6,1) = 0 Then
  Go_up = False
  si61 = si61 + 1
  If si61 > 9 Then
     si61 = 0
     ss(6,1) = 0
     Go_up = True
     GoTo si60
  End If
    If si61 = ss(6,0) OrElse si61 = ss(6,2) OrElse si61 = ss(6,3) OrElse si61 = ss(6,4) OrElse _
       si61 = ss(6,5) OrElse si61 = ss(6,6) OrElse si61 = ss(6,7) OrElse si61 = ss(6,8) OrElse _
       si61 = ss(0,1) OrElse si61 = ss(1,1) OrElse si61 = ss(2,1) OrElse si61 = ss(3,1) OrElse _
       si61 = ss(4,1) OrElse si61 = ss(5,1) OrElse si61 = ss(7,1) OrElse si61 = ss(8,1) OrElse _
       si61 = ss(7,0) OrElse si61 = ss(7,2) OrElse si61 = ss(8,0) OrElse si61 = ss(8,2) Then GoTo si61
    ss(6,1) = si61
    'lw.WriteLine(" ==> si61 - Passed si61 = " & si61.ToString)
  Else
    If Go_up = True Then GoTo si60
  End If
si62:
  If si(6,2) = 0 Then
  Go_up = False
  si62 = si62 + 1
  If si62 > 9 Then
     si62 = 0
     ss(6,2) = 0
     Go_up = True
     GoTo si61
  End If
    If si62 = ss(6,0) OrElse si62 = ss(6,1) OrElse si62 = ss(6,3) OrElse si62 = ss(6,4) OrElse _
       si62 = ss(6,5) OrElse si62 = ss(6,6) OrElse si62 = ss(6,7) OrElse si62 = ss(6,8) OrElse _
       si62 = ss(0,2) OrElse si62 = ss(1,2) OrElse si62 = ss(2,2) OrElse si62 = ss(3,2) OrElse _
       si62 = ss(4,2) OrElse si62 = ss(5,2) OrElse si62 = ss(7,2) OrElse si62 = ss(8,2) OrElse _
       si62 = ss(7,0) OrElse si62 = ss(7,1) OrElse si62 = ss(8,0) OrElse si62 = ss(8,1) Then GoTo si62
    ss(6,2) = si62
    'lw.WriteLine(" ==> si62 - Passed si62 = " & si62.ToString)
  Else
    If Go_up = True Then GoTo si61
  End If
si63:
  If si(6,3) = 0 Then
  Go_up = False
  si63 = si63 + 1
  If si63 > 9 Then
     si63 = 0
     ss(6,3) = 0
     Go_up = True
     GoTo si62
  End If
    If si63 = ss(6,0) OrElse si63 = ss(6,1) OrElse si63 = ss(6,2) OrElse si63 = ss(6,4) OrElse _
       si63 = ss(6,5) OrElse si63 = ss(6,6) OrElse si63 = ss(6,7) OrElse si63 = ss(6,8) OrElse _
       si63 = ss(0,3) OrElse si63 = ss(1,3) OrElse si63 = ss(2,3) OrElse si63 = ss(3,3) OrElse _
       si63 = ss(4,3) OrElse si63 = ss(5,3) OrElse si63 = ss(7,3) OrElse si63 = ss(8,3) OrElse _
       si63 = ss(7,4) OrElse si63 = ss(7,5) OrElse si63 = ss(8,4) OrElse si63 = ss(8,5) Then GoTo si63
    ss(6,3) = si63
    'lw.WriteLine(" ==> si63 - Passed si63 = " & si63.ToString)
  Else
    If Go_up = True Then GoTo si62
  End If
si64:
  If si(6,4) = 0 Then
  Go_up = False
  si64 = si64 + 1
  If si64 > 9 Then
     si64 = 0
     ss(6,4) = 0
     Go_up = True
     GoTo si63
  End If
    If si64 = ss(6,0) OrElse si64 = ss(6,1) OrElse si64 = ss(6,2) OrElse si64 = ss(6,3) OrElse _
       si64 = ss(6,5) OrElse si64 = ss(6,6) OrElse si64 = ss(6,7) OrElse si64 = ss(6,8) OrElse _
       si64 = ss(0,4) OrElse si64 = ss(1,4) OrElse si64 = ss(2,4) OrElse si64 = ss(3,4) OrElse _
       si64 = ss(4,4) OrElse si64 = ss(5,4) OrElse si64 = ss(7,4) OrElse si64 = ss(8,4) OrElse _
       si64 = ss(7,3) OrElse si64 = ss(7,5) OrElse si64 = ss(8,3) OrElse si64 = ss(8,5) Then GoTo si64
    ss(6,4) = si64
    'lw.WriteLine(" ==> si64 - Passed si64 = " & si64.ToString)
  Else
    If Go_up = True Then GoTo si63
  End If
si65:
  If si(6,5) = 0 Then
  Go_up = False
  si65 = si65 + 1
  If si65 > 9 Then
     si65 = 0
     ss(6,5) = 0
     Go_up = True
     GoTo si64
  End If
    If si65 = ss(6,0) OrElse si65 = ss(6,1) OrElse si65 = ss(6,2) OrElse si65 = ss(6,3) OrElse _
       si65 = ss(6,4) OrElse si65 = ss(6,6) OrElse si65 = ss(6,7) OrElse si65 = ss(6,8) OrElse _
       si65 = ss(0,5) OrElse si65 = ss(1,5) OrElse si65 = ss(2,5) OrElse si65 = ss(3,5) OrElse _
       si65 = ss(4,5) OrElse si65 = ss(5,5) OrElse si65 = ss(7,5) OrElse si65 = ss(8,5) OrElse _
       si65 = ss(7,3) OrElse si65 = ss(7,4) OrElse si65 = ss(8,3) OrElse si65 = ss(8,4) Then GoTo si65
    ss(6,5) = si65
    'lw.WriteLine(" ==> si65 - Passed si65 = " & si65.ToString)
  Else
    If Go_up = True Then GoTo si64
  End If
si66:
  If si(6,6) = 0 Then
  Go_up = False
  si66 = si66 + 1
  If si66 > 9 Then
     si66 = 0
     ss(6,6) = 0
     Go_up = True
     GoTo si65
  End If
    If si66 = ss(6,0) OrElse si66 = ss(6,1) OrElse si66 = ss(6,2) OrElse si66 = ss(6,3) OrElse _
       si66 = ss(6,4) OrElse si66 = ss(6,5) OrElse si66 = ss(6,7) OrElse si66 = ss(6,8) OrElse _
       si66 = ss(0,6) OrElse si66 = ss(1,6) OrElse si66 = ss(2,6) OrElse si66 = ss(3,6) OrElse _
       si66 = ss(4,6) OrElse si66 = ss(5,6) OrElse si66 = ss(7,6) OrElse si66 = ss(8,6) OrElse _
       si66 = ss(7,7) OrElse si66 = ss(7,8) OrElse si66 = ss(8,7) OrElse si66 = ss(8,8) Then GoTo si66
    ss(6,6) = si66
    'lw.WriteLine(" ==> si66 - Passed si66 = " & si66.ToString)
  Else
    If Go_up = True Then GoTo si65
  End If
si67:
  If si(6,7) = 0 Then
  Go_up = False
  si67 = si67 + 1
  If si67 > 9 Then
     si67 = 0
     ss(6,7) = 0
     Go_up = True
     GoTo si66
  End If
    If si67 = ss(6,0) OrElse si67 = ss(6,1) OrElse si67 = ss(6,2) OrElse si67 = ss(6,3) OrElse _
       si67 = ss(6,4) OrElse si67 = ss(6,5) OrElse si67 = ss(6,6) OrElse si67 = ss(6,8) OrElse _
       si67 = ss(0,7) OrElse si67 = ss(1,7) OrElse si67 = ss(2,7) OrElse si67 = ss(3,7) OrElse _
       si67 = ss(4,7) OrElse si67 = ss(5,7) OrElse si67 = ss(7,7) OrElse si67 = ss(8,7) OrElse _
       si67 = ss(7,6) OrElse si67 = ss(7,8) OrElse si67 = ss(8,6) OrElse si67 = ss(8,8) Then GoTo si67
    ss(6,7) = si67
    'lw.WriteLine(" ==> si67 - Passed si67 = " & si67.ToString)
  Else
    If Go_up = True Then GoTo si66
  End If
si68:
  If si(6,8) = 0 Then
  Go_up = False
  si68 = si68 + 1
  If si68 > 9 Then
     si68 = 0
     ss(6,8) = 0
     Go_up = True
     GoTo si67
  End If
    If si68 = ss(6,0) OrElse si68 = ss(6,1) OrElse si68 = ss(6,2) OrElse si68 = ss(6,3) OrElse _
       si68 = ss(6,4) OrElse si68 = ss(6,5) OrElse si68 = ss(6,6) OrElse si68 = ss(6,7) OrElse _
       si68 = ss(0,8) OrElse si68 = ss(1,8) OrElse si68 = ss(2,8) OrElse si68 = ss(3,8) OrElse _
       si68 = ss(4,8) OrElse si68 = ss(5,8) OrElse si68 = ss(7,8) OrElse si68 = ss(8,8) OrElse _
       si68 = ss(7,6) OrElse si68 = ss(7,7) OrElse si68 = ss(8,6) OrElse si68 = ss(8,7) Then GoTo si68
    ss(6,8) = si68
    'lw.WriteLine(" ==> si68 - Passed si68 = " & si68.ToString)
  Else
    If Go_up = True Then GoTo si67
  End If
si70:
  If si(7,0) = 0 Then
  Go_up = False
  si70 = si70 + 1
  If si70 > 9 Then
     si70 = 0
     ss(7,0) = 0
     Go_up = True
     GoTo si68
  End If
    If si70 = ss(7,1) OrElse si70 = ss(7,2) OrElse si70 = ss(7,3) OrElse si70 = ss(7,4) OrElse _
       si70 = ss(7,5) OrElse si70 = ss(7,6) OrElse si70 = ss(7,7) OrElse si70 = ss(7,8) OrElse _
       si70 = ss(0,0) OrElse si70 = ss(1,0) OrElse si70 = ss(2,0) OrElse si70 = ss(3,0) OrElse _
       si70 = ss(4,0) OrElse si70 = ss(5,0) OrElse si70 = ss(6,0) OrElse si70 = ss(8,0) OrElse _
       si70 = ss(6,1) OrElse si70 = ss(6,2) OrElse si70 = ss(8,1) OrElse si70 = ss(8,2) Then GoTo si70
    ss(7,0) = si70
    'lw.WriteLine(" ==> si70 - Passed si70 = " & si70.ToString)
  Else
    If Go_up = True Then GoTo si68
  End If
si71:
  If si(7,1) = 0 Then
  Go_up = False
  si71 = si71 + 1
  If si71 > 9 Then
     si71 = 0
     ss(7,1) = 0
     Go_up = True
     GoTo si70
  End If
    If si71 = ss(7,0) OrElse si71 = ss(7,2) OrElse si71 = ss(7,3) OrElse si71 = ss(7,4) OrElse _
       si71 = ss(7,5) OrElse si71 = ss(7,6) OrElse si71 = ss(7,7) OrElse si71 = ss(7,8) OrElse _
       si71 = ss(0,1) OrElse si71 = ss(1,1) OrElse si71 = ss(2,1) OrElse si71 = ss(3,1) OrElse _
       si71 = ss(4,1) OrElse si71 = ss(5,1) OrElse si71 = ss(6,1) OrElse si71 = ss(8,1) OrElse _
       si71 = ss(6,0) OrElse si71 = ss(6,2) OrElse si71 = ss(8,0) OrElse si71 = ss(8,2) Then GoTo si71
    ss(7,1) = si71
    'lw.WriteLine(" ==> si71 - Passed si71 = " & si71.ToString)
  Else
    If Go_up = True Then GoTo si70
  End If
si72:
  If si(7,2) = 0 Then
  Go_up = False
  si72 = si72 + 1
  If si72 > 9 Then
     si72 = 0
     ss(7,2) = 0
     Go_up = True
     GoTo si71
  End If
    If si72 = ss(7,0) OrElse si72 = ss(7,1) OrElse si72 = ss(7,3) OrElse si72 = ss(7,4) OrElse _
       si72 = ss(7,5) OrElse si72 = ss(7,6) OrElse si72 = ss(7,7) OrElse si72 = ss(7,8) OrElse _
       si72 = ss(0,2) OrElse si72 = ss(1,2) OrElse si72 = ss(2,2) OrElse si72 = ss(3,2) OrElse _
       si72 = ss(4,2) OrElse si72 = ss(5,2) OrElse si72 = ss(6,2) OrElse si72 = ss(8,2) OrElse _
       si72 = ss(6,0) OrElse si72 = ss(6,1) OrElse si72 = ss(8,0) OrElse si72 = ss(8,1) Then GoTo si72
    ss(7,2) = si72
    'lw.WriteLine(" ==> si72 - Passed si72 = " & si72.ToString)
  Else
    If Go_up = True Then GoTo si71
  End If
si73:
  If si(7,3) = 0 Then
  Go_up = False
  si73 = si73 + 1
  If si73 > 9 Then
     si73 = 0
     ss(7,3) = 0
     Go_up = True
     GoTo si72
  End If
    If si73 = ss(7,0) OrElse si73 = ss(7,1) OrElse si73 = ss(7,2) OrElse si73 = ss(7,4) OrElse _
       si73 = ss(7,5) OrElse si73 = ss(7,6) OrElse si73 = ss(7,7) OrElse si73 = ss(7,8) OrElse _
       si73 = ss(0,3) OrElse si73 = ss(1,3) OrElse si73 = ss(2,3) OrElse si73 = ss(3,3) OrElse _
       si73 = ss(4,3) OrElse si73 = ss(5,3) OrElse si73 = ss(6,3) OrElse si73 = ss(8,3) OrElse _
       si73 = ss(6,4) OrElse si73 = ss(6,5) OrElse si73 = ss(8,4) OrElse si73 = ss(8,5) Then GoTo si73
    ss(7,3) = si73
    'lw.WriteLine(" ==> si73 - Passed si73 = " & si73.ToString)
  Else
    If Go_up = True Then GoTo si72
  End If
si74:
  If si(7,4) = 0 Then
  Go_up = False
  si74 = si74 + 1
  If si74 > 9 Then
     si74 = 0
     ss(7,4) = 0
     Go_up = True
     GoTo si73
  End If
    If si74 = ss(7,0) OrElse si74 = ss(7,1) OrElse si74 = ss(7,2) OrElse si74 = ss(7,3) OrElse _
       si74 = ss(7,5) OrElse si74 = ss(7,6) OrElse si74 = ss(7,7) OrElse si74 = ss(7,8) OrElse _
       si74 = ss(0,4) OrElse si74 = ss(1,4) OrElse si74 = ss(2,4) OrElse si74 = ss(3,4) OrElse _
       si74 = ss(4,4) OrElse si74 = ss(5,4) OrElse si74 = ss(6,4) OrElse si74 = ss(8,4) OrElse _
       si74 = ss(6,3) OrElse si74 = ss(6,5) OrElse si74 = ss(8,3) OrElse si74 = ss(8,5) Then GoTo si74
    ss(7,4) = si74
    'lw.WriteLine(" ==> si74 - Passed si74 = " & si74.ToString)
  Else
    If Go_up = True Then GoTo si73
  End If
si75:
  If si(7,5) = 0 Then
  Go_up = False
  si75 = si75 + 1
  If si75 > 9 Then
     si75 = 0
     ss(7,5) = 0
     Go_up = True
     GoTo si74
  End If
    If si75 = ss(7,0) OrElse si75 = ss(7,1) OrElse si75 = ss(7,2) OrElse si75 = ss(7,3) OrElse _
       si75 = ss(7,4) OrElse si75 = ss(7,6) OrElse si75 = ss(7,7) OrElse si75 = ss(7,8) OrElse _
       si75 = ss(0,5) OrElse si75 = ss(1,5) OrElse si75 = ss(2,5) OrElse si75 = ss(3,5) OrElse _
       si75 = ss(4,5) OrElse si75 = ss(5,5) OrElse si75 = ss(6,5) OrElse si75 = ss(8,5) OrElse _
       si75 = ss(6,3) OrElse si75 = ss(6,4) OrElse si75 = ss(8,3) OrElse si75 = ss(8,4) Then GoTo si75
    ss(7,5) = si75
    'lw.WriteLine(" ==> si75 - Passed si75 = " & si75.ToString)
  Else
    If Go_up = True Then GoTo si74
  End If
si76:
  If si(7,6) = 0 Then
  Go_up = False
  si76 = si76 + 1
  If si76 > 9 Then
     si76 = 0
     ss(7,6) = 0
     Go_up = True
     GoTo si75
  End If
    If si76 = ss(7,0) OrElse si76 = ss(7,1) OrElse si76 = ss(7,2) OrElse si76 = ss(7,3) OrElse _
       si76 = ss(7,4) OrElse si76 = ss(7,5) OrElse si76 = ss(7,7) OrElse si76 = ss(7,8) OrElse _
       si76 = ss(0,6) OrElse si76 = ss(1,6) OrElse si76 = ss(2,6) OrElse si76 = ss(3,6) OrElse _
       si76 = ss(4,6) OrElse si76 = ss(5,6) OrElse si76 = ss(6,6) OrElse si76 = ss(8,6) OrElse _
       si76 = ss(6,7) OrElse si76 = ss(6,8) OrElse si76 = ss(8,7) OrElse si76 = ss(8,8) Then GoTo si76
    ss(7,6) = si76
    'lw.WriteLine(" ==> si76 - Passed si76 = " & si76.ToString)
  Else
    If Go_up = True Then GoTo si75
  End If
si77:
  If si(7,7) = 0 Then
  Go_up = False
  si77 = si77 + 1
  If si77 > 9 Then
     si77 = 0
     ss(7,7) = 0
     Go_up = True
     GoTo si76
  End If
    If si77 = ss(7,0) OrElse si77 = ss(7,1) OrElse si77 = ss(7,2) OrElse si77 = ss(7,3) OrElse _
       si77 = ss(7,4) OrElse si77 = ss(7,5) OrElse si77 = ss(7,6) OrElse si77 = ss(7,8) OrElse _
       si77 = ss(0,7) OrElse si77 = ss(1,7) OrElse si77 = ss(2,7) OrElse si77 = ss(3,7) OrElse _
       si77 = ss(4,7) OrElse si77 = ss(5,7) OrElse si77 = ss(6,7) OrElse si77 = ss(8,7) OrElse _
       si77 = ss(6,6) OrElse si77 = ss(6,8) OrElse si77 = ss(8,6) OrElse si77 = ss(8,8) Then GoTo si77
    ss(7,7) = si77
    'lw.WriteLine(" ==> si77 - Passed si77 = " & si77.ToString)
  Else
    If Go_up = True Then GoTo si76
  End If
si78:
  If si(7,8) = 0 Then
  Go_up = False
  si78 = si78 + 1
  If si78 > 9 Then
     si78 = 0
     ss(7,8) = 0
     Go_up = True
     GoTo si77
  End If
    If si78 = ss(7,0) OrElse si78 = ss(7,1) OrElse si78 = ss(7,2) OrElse si78 = ss(7,3) OrElse _
       si78 = ss(7,4) OrElse si78 = ss(7,5) OrElse si78 = ss(7,6) OrElse si78 = ss(7,7) OrElse _
       si78 = ss(0,8) OrElse si78 = ss(1,8) OrElse si78 = ss(2,8) OrElse si78 = ss(3,8) OrElse _
       si78 = ss(4,8) OrElse si78 = ss(5,8) OrElse si78 = ss(6,8) OrElse si78 = ss(8,8) OrElse _
       si78 = ss(6,6) OrElse si78 = ss(6,7) OrElse si78 = ss(8,6) OrElse si78 = ss(8,7) Then GoTo si78
    ss(7,8) = si78
    'lw.WriteLine(" ==> si78 - Passed si78 = " & si78.ToString)
  Else
    If Go_up = True Then GoTo si77
  End If
si80:
  If si(8,0) = 0 Then
  Go_up = False
  si80 = si80 + 1
  If si80 > 9 Then
     si80 = 0
     ss(8,0) = 0
     Go_up = True
     GoTo si78
  End If
    If si80 = ss(8,1) OrElse si80 = ss(8,2) OrElse si80 = ss(8,3) OrElse si80 = ss(8,4) OrElse _
       si80 = ss(8,5) OrElse si80 = ss(8,6) OrElse si80 = ss(8,7) OrElse si80 = ss(8,8) OrElse _
       si80 = ss(0,0) OrElse si80 = ss(1,0) OrElse si80 = ss(2,0) OrElse si80 = ss(3,0) OrElse _
       si80 = ss(4,0) OrElse si80 = ss(5,0) OrElse si80 = ss(6,0) OrElse si80 = ss(7,0) OrElse _
       si80 = ss(6,1) OrElse si80 = ss(6,2) OrElse si80 = ss(7,1) OrElse si80 = ss(7,2) Then GoTo si80
    ss(8,0) = si80
    'lw.WriteLine(" ==> si80 - Passed si80 = " & si80.ToString)
  Else
    If Go_up = True Then GoTo si78
  End If
si81:
  If si(8,1) = 0 Then
  Go_up = False
  si81 = si81 + 1
  If si81 > 9 Then
     si81 = 0
     ss(8,1) = 0
     Go_up = True
     GoTo si80
  End If
    If si81 = ss(8,0) OrElse si81 = ss(8,2) OrElse si81 = ss(8,3) OrElse si81 = ss(8,4) OrElse _
       si81 = ss(8,5) OrElse si81 = ss(8,6) OrElse si81 = ss(8,7) OrElse si81 = ss(8,8) OrElse _
       si81 = ss(0,1) OrElse si81 = ss(1,1) OrElse si81 = ss(2,1) OrElse si81 = ss(3,1) OrElse _
       si81 = ss(4,1) OrElse si81 = ss(5,1) OrElse si81 = ss(6,1) OrElse si81 = ss(7,1) OrElse _
       si81 = ss(6,0) OrElse si81 = ss(6,2) OrElse si81 = ss(7,0) OrElse si81 = ss(7,2) Then GoTo si81
    ss(8,1) = si81
    'lw.WriteLine(" ==> si81 - Passed si81 = " & si81.ToString)
  Else
    If Go_up = True Then GoTo si80
  End If
si82:
  If si(8,2) = 0 Then
  Go_up = False
  si82 = si82 + 1
  If si82 > 9 Then
     si82 = 0
     ss(8,2) = 0
     Go_up = True
     GoTo si81
  End If
    If si82 = ss(8,0) OrElse si82 = ss(8,1) OrElse si82 = ss(8,3) OrElse si82 = ss(8,4) OrElse _
       si82 = ss(8,5) OrElse si82 = ss(8,6) OrElse si82 = ss(8,7) OrElse si82 = ss(8,8) OrElse _
       si82 = ss(0,2) OrElse si82 = ss(1,2) OrElse si82 = ss(2,2) OrElse si82 = ss(3,2) OrElse _
       si82 = ss(4,2) OrElse si82 = ss(5,2) OrElse si82 = ss(6,2) OrElse si82 = ss(7,2) OrElse _
       si82 = ss(6,0) OrElse si82 = ss(6,1) OrElse si82 = ss(7,0) OrElse si82 = ss(7,1) Then GoTo si82
    ss(8,2) = si82
    'lw.WriteLine(" ==> si82 - Passed si82 = " & si82.ToString)
  Else
    If Go_up = True Then GoTo si81
  End If
si83:
  If si(8,3) = 0 Then
  Go_up = False
  si83 = si83 + 1
  If si83 > 9 Then
     si83 = 0
     ss(8,3) = 0
     Go_up = True
     GoTo si82
  End If
    If si83 = ss(8,0) OrElse si83 = ss(8,1) OrElse si83 = ss(8,2) OrElse si83 = ss(8,4) OrElse _
       si83 = ss(8,5) OrElse si83 = ss(8,6) OrElse si83 = ss(8,7) OrElse si83 = ss(8,8) OrElse _
       si83 = ss(0,3) OrElse si83 = ss(1,3) OrElse si83 = ss(2,3) OrElse si83 = ss(3,3) OrElse _
       si83 = ss(4,3) OrElse si83 = ss(5,3) OrElse si83 = ss(6,3) OrElse si83 = ss(7,3) OrElse _
       si83 = ss(6,4) OrElse si83 = ss(6,5) OrElse si83 = ss(7,4) OrElse si83 = ss(7,5) Then GoTo si83
    ss(8,3) = si83
    'lw.WriteLine(" ==> si83 - Passed si83 = " & si83.ToString)
  Else
    If Go_up = True Then GoTo si82
  End If
si84:
  If si(8,4) = 0 Then
  Go_up = False
  si84 = si84 + 1
  If si84 > 9 Then
     si84 = 0
     ss(8,4) = 0
     Go_up = True
     GoTo si83
  End If
    If si84 = ss(8,0) OrElse si84 = ss(8,1) OrElse si84 = ss(8,2) OrElse si84 = ss(8,3) OrElse _
       si84 = ss(8,5) OrElse si84 = ss(8,6) OrElse si84 = ss(8,7) OrElse si84 = ss(8,8) OrElse _
       si84 = ss(0,4) OrElse si84 = ss(1,4) OrElse si84 = ss(2,4) OrElse si84 = ss(3,4) OrElse _
       si84 = ss(4,4) OrElse si84 = ss(5,4) OrElse si84 = ss(6,4) OrElse si84 = ss(7,4) OrElse _
       si84 = ss(6,3) OrElse si84 = ss(6,5) OrElse si84 = ss(7,3) OrElse si84 = ss(7,5) Then GoTo si84
    ss(8,4) = si84
    'lw.WriteLine(" ==> si84 - Passed si84 = " & si84.ToString)
  Else
    If Go_up = True Then GoTo si83
  End If
si85:
  If si(8,5) = 0 Then
  Go_up = False
  si85 = si85 + 1
  If si85 > 9 Then
     si85 = 0
     ss(8,5) = 0
     Go_up = True
     GoTo si84
  End If
    If si85 = ss(8,0) OrElse si85 = ss(8,1) OrElse si85 = ss(8,2) OrElse si85 = ss(8,3) OrElse _
       si85 = ss(8,4) OrElse si85 = ss(8,6) OrElse si85 = ss(8,7) OrElse si85 = ss(8,8) OrElse _
       si85 = ss(0,5) OrElse si85 = ss(1,5) OrElse si85 = ss(2,5) OrElse si85 = ss(3,5) OrElse _
       si85 = ss(4,5) OrElse si85 = ss(5,5) OrElse si85 = ss(6,5) OrElse si85 = ss(7,5) OrElse _
       si85 = ss(6,3) OrElse si85 = ss(6,4) OrElse si85 = ss(7,3) OrElse si85 = ss(7,4) Then GoTo si85
    ss(8,5) = si85
    'lw.WriteLine(" ==> si85 - Passed si85 = " & si85.ToString)
  Else
    If Go_up = True Then GoTo si84
  End If
si86:
  If si(8,6) = 0 Then
  Go_up = False
  si86 = si86 + 1
  If si86 > 9 Then
     si86 = 0
     ss(8,6) = 0
     Go_up = True
     GoTo si85
  End If
    If si86 = ss(8,0) OrElse si86 = ss(8,1) OrElse si86 = ss(8,2) OrElse si86 = ss(8,3) OrElse _
       si86 = ss(8,4) OrElse si86 = ss(8,5) OrElse si86 = ss(8,7) OrElse si86 = ss(8,8) OrElse _
       si86 = ss(0,6) OrElse si86 = ss(1,6) OrElse si86 = ss(2,6) OrElse si86 = ss(3,6) OrElse _
       si86 = ss(4,6) OrElse si86 = ss(5,6) OrElse si86 = ss(6,6) OrElse si86 = ss(7,6) OrElse _
       si86 = ss(6,7) OrElse si86 = ss(6,8) OrElse si86 = ss(7,7) OrElse si86 = ss(7,8) Then GoTo si86
    ss(8,6) = si86
    'lw.WriteLine(" ==> si86 - Passed si86 = " & si86.ToString)
  Else
    If Go_up = True Then GoTo si85
  End If
si87:
  If si(8,7) = 0 Then
  Go_up = False
  si87 = si87 + 1
  If si87 > 9 Then
     si87 = 0
     ss(8,7) = 0
     Go_up = True
     GoTo si86
  End If
    If si87 = ss(8,0) OrElse si87 = ss(8,1) OrElse si87 = ss(8,2) OrElse si87 = ss(8,3) OrElse _
       si87 = ss(8,4) OrElse si87 = ss(8,5) OrElse si87 = ss(8,6) OrElse si87 = ss(8,8) OrElse _
       si87 = ss(0,7) OrElse si87 = ss(1,7) OrElse si87 = ss(2,7) OrElse si87 = ss(3,7) OrElse _
       si87 = ss(4,7) OrElse si87 = ss(5,7) OrElse si87 = ss(6,7) OrElse si87 = ss(7,7) OrElse _
       si87 = ss(6,6) OrElse si87 = ss(6,8) OrElse si87 = ss(7,6) OrElse si87 = ss(7,8) Then GoTo si87
    ss(8,7) = si87
    'lw.WriteLine(" ==> si87 - Passed si87 = " & si87.ToString)
  Else
    If Go_up = True Then GoTo si86
  End If
si88:
  If si(8,8) = 0 Then
  Go_up = False
  si88 = si88 + 1
  If si88 > 9 Then
     si88 = 0
     ss(8,8) = 0
     Go_up = True
     GoTo si87
  End If
    If si88 = ss(8,0) OrElse si88 = ss(8,1) OrElse si88 = ss(8,2) OrElse si88 = ss(8,3) OrElse _
       si88 = ss(8,4) OrElse si88 = ss(8,5) OrElse si88 = ss(8,6) OrElse si88 = ss(8,7) OrElse _
       si88 = ss(0,8) OrElse si88 = ss(1,8) OrElse si88 = ss(2,8) OrElse si88 = ss(3,8) OrElse _
       si88 = ss(4,8) OrElse si88 = ss(5,8) OrElse si88 = ss(6,8) OrElse si88 = ss(7,8) OrElse _
       si88 = ss(6,6) OrElse si88 = ss(6,7) OrElse si88 = ss(7,6) OrElse si88 = ss(7,7) Then GoTo si88
    ss(8,8) = si88
    'lw.WriteLine(" ==> si88 - Passed si88 = " & si88.ToString)
  Else
    If Go_up = True Then GoTo si87
  End If
  If  TimerFlag = True Then
    ufs.UF.EndTimer(start, tv)
  End If
  lw.WriteLine("===================")
  lw.WriteLine( ss(0,0).ToString & " " & ss(0,1).ToString & " " & ss(0,2).ToString & "  " _
              & ss(0,3).ToString & " " & ss(0,4).ToString & " " & ss(0,5).ToString & "  " _
              & ss(0,6).ToString & " " & ss(0,7).ToString & " " & ss(0,8).ToString )
  lw.WriteLine( ss(1,0).ToString & " " & ss(1,1).ToString & " " & ss(1,2).ToString & "  " _
              & ss(1,3).ToString & " " & ss(1,4).ToString & " " & ss(1,5).ToString & "  " _
              & ss(1,6).ToString & " " & ss(1,7).ToString & " " & ss(1,8).ToString )
  lw.WriteLine( ss(2,0).ToString & " " & ss(2,1).ToString & " " & ss(2,2).ToString & "  " _
              & ss(2,3).ToString & " " & ss(2,4).ToString & " " & ss(2,5).ToString & "  " _
              & ss(2,6).ToString & " " & ss(2,7).ToString & " " & ss(2,8).ToString )
  lw.WriteLine("")
  lw.WriteLine( ss(3,0).ToString & " " & ss(3,1).ToString & " " & ss(3,2).ToString & "  " _
              & ss(3,3).ToString & " " & ss(3,4).ToString & " " & ss(3,5).ToString & "  " _
              & ss(3,6).ToString & " " & ss(3,7).ToString & " " & ss(3,8).ToString )
  lw.WriteLine( ss(4,0).ToString & " " & ss(4,1).ToString & " " & ss(4,2).ToString & "  " _
              & ss(4,3).ToString & " " & ss(4,4).ToString & " " & ss(4,5).ToString & "  " _
              & ss(4,6).ToString & " " & ss(4,7).ToString & " " & ss(4,8).ToString )
  lw.WriteLine( ss(5,0).ToString & " " & ss(5,1).ToString & " " & ss(5,2).ToString & "  " _
              & ss(5,3).ToString & " " & ss(5,4).ToString & " " & ss(5,5).ToString & "  " _
              & ss(5,6).ToString & " " & ss(5,7).ToString & " " & ss(5,8).ToString )
  lw.WriteLine("")
  lw.WriteLine( ss(6,0).ToString & " " & ss(6,1).ToString & " " & ss(6,2).ToString & "  " _
              & ss(6,3).ToString & " " & ss(6,4).ToString & " " & ss(6,5).ToString & "  " _
              & ss(6,6).ToString & " " & ss(6,7).ToString & " " & ss(6,8).ToString )
  lw.WriteLine( ss(7,0).ToString & " " & ss(7,1).ToString & " " & ss(7,2).ToString & "  " _
              & ss(7,3).ToString & " " & ss(7,4).ToString & " " & ss(7,5).ToString & "  " _
              & ss(7,6).ToString & " " & ss(7,7).ToString & " " & ss(7,8).ToString )
  lw.WriteLine( ss(8,0).ToString & " " & ss(8,1).ToString & " " & ss(8,2).ToString & "  " _
              & ss(8,3).ToString & " " & ss(8,4).ToString & " " & ss(8,5).ToString & "  " _
              & ss(8,6).ToString & " " & ss(8,7).ToString & " " & ss(8,8).ToString )
  lw.WriteLine("")
  lw.WriteLine("Sudoku 9x9 App")
   lw.WriteLine("Real Time: Solution 1 time = " & (tv.real_time).ToString & " Segonds ")
   lw.WriteLine("CPU Time: Solution 1 time =  " & tv.cpu_time.ToString & " Segonds ")
   TimerFlag = False
  End If
  cnt_stop = cnt_stop + 1
  If cnt_stop = stop_at_solution Then Exit Sub
  Go_up = True
  GoTo si88
 End Sub
Public Sub DSudoku()
   Dim s As Session = Session.GetSession()
   Dim ufs As UFSession = UFSession.GetUFSession()
   Dim lw As ListingWindow = s.ListingWindow
   Dim si(8,8) As Integer
   Dim ss(8,8) As Integer
   Dim Go_up As Boolean = False
   'Dim a(80) As Integer
   Dim si00,si10,si20,si30,si40,si50,si60,si70,si80 As Integer
   Dim si01,si11,si21,si31,si41,si51,si61,si71,si81 As Integer
   Dim si02,si12,si22,si32,si42,si52,si62,si72,si82 As Integer
   Dim si03,si13,si23,si33,si43,si53,si63,si73,si83 As Integer
   Dim si04,si14,si24,si34,si44,si54,si64,si74,si84 As Integer
   Dim si05,si15,si25,si35,si45,si55,si65,si75,si85 As Integer
   Dim si06,si16,si26,si36,si46,si56,si66,si76,si86 As Integer
   Dim si07,si17,si27,si37,si47,si57,si67,si77,si87 As Integer
   Dim si08,si18,si28,si38,si48,si58,si68,si78,si88 As Integer
   Dim start As Short
   Dim tv As NXOpen.UF.TimerValues
   ufs.UF.BeginTimer(start)
   Dim jj As Integer
   For jj=0 To 8
     si(0,jj) = a(jj)
     ss(0,jj) = si(0,jj)
   Next
   For jj=9 To 17
     si(1,jj-9) = a(jj)
     ss(1,jj-9) = si(1,jj-9)
   Next
   For jj=18 To 26
     si(2,jj-18) = a(jj)
     ss(2,jj-18) = si(2,jj-18)
   Next
   For jj=27 To 35
     si(3,jj-27) = a(jj)
     ss(3,jj-27) = si(3,jj-27)
   Next
   For jj=36 To 44
     si(4,jj-36) = a(jj)
     ss(4,jj-36) = si(4,jj-36)
   Next
   For jj=45 To 53
     si(5,jj-45) = a(jj)
     ss(5,jj-45) = si(5,jj-45)
   Next
   For jj=54 To 62
     si(6,jj-54) = a(jj)
     ss(6,jj-54) = si(6,jj-54)
   Next
   For jj=63 To 71
     si(7,jj-63) = a(jj)
     ss(7,jj-63) = si(7,jj-63)
   Next
   For jj=72 To 80
     si(8,jj-72) = a(jj)
     ss(8,jj-72) = si(8,jj-72)
   Next
  lw.Open()
   If valid_check( ss ) = False Then
     'lw.WriteLine(" Input not valid ! ")
     msgbox(" Input not valid ! ")
     Exit Sub
   End If
  si00 = 0: si01 = 0: si02 = 0: si03 = 0: si04 = 0: si05 = 0: si06 = 0: si07 = 0: si08 = 0
  si10 = 0: si11 = 0: si12 = 0: si13 = 0: si14 = 0: si15 = 0: si16 = 0: si17 = 0: si18 = 0
  si20 = 0: si21 = 0: si22 = 0: si23 = 0: si24 = 0: si25 = 0: si26 = 0: si27 = 0: si28 = 0
  si30 = 0: si31 = 0: si32 = 0: si33 = 0: si34 = 0: si35 = 0: si36 = 0: si37 = 0: si38 = 0
  si40 = 0: si41 = 0: si42 = 0: si43 = 0: si44 = 0: si45 = 0: si46 = 0: si47 = 0: si48 = 0
  si50 = 0: si51 = 0: si52 = 0: si53 = 0: si54 = 0: si55 = 0: si56 = 0: si57 = 0: si58 = 0
  si60 = 0: si61 = 0: si62 = 0: si63 = 0: si64 = 0: si65 = 0: si66 = 0: si67 = 0: si68 = 0
  si70 = 0: si71 = 0: si72 = 0: si73 = 0: si74 = 0: si75 = 0: si76 = 0: si77 = 0: si78 = 0
  si80 = 0: si81 = 0: si82 = 0: si83 = 0: si84 = 0: si85 = 0: si86 = 0: si87 = 0: si88 = 0
  Dim cnt_stop As Integer = 0
si00:
 If si(0,0) = 0 Then
   Go_up = False
   si00 = si00 + 1
   If si00 > 9 Then
       lw.WriteLine("***  Sudoku Processing Ended ! ***")
       Exit Sub
   End If
   If si00 = ss(0,1) OrElse si00 = ss(0,2) OrElse si00 = ss(0,3) OrElse si00 = ss(0,4) OrElse _
      si00 = ss(0,5) OrElse si00 = ss(0,6) OrElse si00 = ss(0,7) OrElse si00 = ss(0,8) OrElse _
      si00 = ss(1,0) OrElse si00 = ss(2,0) OrElse si00 = ss(3,0) OrElse si00 = ss(4,0) OrElse _
      si00 = ss(5,0) OrElse si00 = ss(6,0) OrElse si00 = ss(7,0) OrElse si00 = ss(8,0) OrElse _
      si00 = ss(3,3) OrElse si00 = ss(4,4) OrElse si00 = ss(5,5) OrElse _
      si00 = ss(6,6) OrElse si00 = ss(7,7) OrElse si00 = ss(8,8) OrElse _
      si00 = ss(1,1) OrElse si00 = ss(1,2) OrElse si00 = ss(2,1) OrElse si00 = ss(2,2) Then GoTo si00
   ss(0,0) = si00
 Else
   'If Go_up = True Then GoTo si-1
 End If
si01:
 If si(0,1) = 0 Then
   Go_up = False
   si01 = si01 + 1
   If si01 > 9 Then
     si01 = 0
     ss(0,1) = 0
     Go_up = True
     GoTo si00
   End If
   If si01 = ss(0,0) OrElse si01 = ss(0,2) OrElse si01 = ss(0,3) OrElse si01 = ss(0,4) OrElse _
      si01 = ss(0,5) OrElse si01 = ss(0,6) OrElse si01 = ss(0,7) OrElse si01 = ss(0,8) OrElse _
      si01 = ss(1,1) OrElse si01 = ss(2,1) OrElse si01 = ss(3,1) OrElse si01 = ss(4,1) OrElse _
      si01 = ss(5,1) OrElse si01 = ss(6,1) OrElse si01 = ss(7,1) OrElse si01 = ss(8,1) OrElse _
      si01 = ss(1,0) OrElse si01 = ss(1,2) OrElse si01 = ss(2,0) OrElse si01 = ss(2,2) Then GoTo si01
   ss(0,1) = si01
 Else
   If Go_up = True Then GoTo si00
 End If
si02:
 If si(0,2) = 0 Then
   Go_up = False
   si02 = si02 + 1
   If si02 > 9 Then
     si02 = 0
     ss(0,2) = 0
     Go_up = True
     GoTo si01
   End If
   If si02 = ss(0,0) OrElse si02 = ss(0,1) OrElse si02 = ss(0,3) OrElse si02 = ss(0,4) OrElse _
      si02 = ss(0,5) OrElse si02 = ss(0,6) OrElse si02 = ss(0,7) OrElse si02 = ss(0,8) OrElse _
      si02 = ss(1,2) OrElse si02 = ss(2,2) OrElse si02 = ss(3,2) OrElse si02 = ss(4,2) OrElse _
      si02 = ss(5,2) OrElse si02 = ss(6,2) OrElse si02 = ss(7,2) OrElse si02 = ss(8,2) OrElse _
      si02 = ss(1,0) OrElse si02 = ss(1,1) OrElse si02 = ss(2,0) OrElse si02 = ss(2,1) Then GoTo si02
   ss(0,2) = si02
 Else
   If Go_up = True Then GoTo si01
 End If
si03:
 If si(0,3) = 0 Then
   Go_up = False
   si03 = si03 + 1
   If si03 > 9 Then
     si03 = 0
     ss(0,3) = 0
     Go_up = True
     GoTo si02
   End If
   If si03 = ss(0,0) OrElse si03 = ss(0,1) OrElse si03 = ss(0,2) OrElse si03 = ss(0,4) OrElse _
      si03 = ss(0,5) OrElse si03 = ss(0,6) OrElse si03 = ss(0,7) OrElse si03 = ss(0,8) OrElse _
      si03 = ss(1,3) OrElse si03 = ss(2,3) OrElse si03 = ss(3,3) OrElse si03 = ss(4,3) OrElse _
      si03 = ss(5,3) OrElse si03 = ss(6,3) OrElse si03 = ss(7,3) OrElse si03 = ss(8,3) OrElse _
      si03 = ss(1,4) OrElse si03 = ss(1,5) OrElse si03 = ss(2,4) OrElse si03 = ss(2,5) Then GoTo si03
   ss(0,3) = si03
 Else
   If Go_up = True Then GoTo si02
 End If
si04:
 If si(0,4) = 0 Then
   Go_up = False
   si04 = si04 + 1
   If si04 > 9 Then
     si04 = 0
     ss(0,4) = 0
     Go_up = True
     GoTo si03
   End If
   If si04 = ss(0,0) OrElse si04 = ss(0,1) OrElse si04 = ss(0,2) OrElse si04 = ss(0,3) OrElse _
      si04 = ss(0,5) OrElse si04 = ss(0,6) OrElse si04 = ss(0,7) OrElse si04 = ss(0,8) OrElse _
      si04 = ss(1,4) OrElse si04 = ss(2,4) OrElse si04 = ss(3,4) OrElse si04 = ss(4,4) OrElse _
      si04 = ss(5,4) OrElse si04 = ss(6,4) OrElse si04 = ss(7,4) OrElse si04 = ss(8,4) OrElse _
      si04 = ss(1,3) OrElse si04 = ss(1,5) OrElse si04 = ss(2,3) OrElse si04 = ss(2,5) Then GoTo si04
   ss(0,4) = si04
 Else
   If Go_up = True Then GoTo si03
 End If
si05:
 If si(0,5) = 0 Then
   Go_up = False
   si05 = si05 + 1
   If si05 > 9 Then
     si05 = 0
     ss(0,5) = 0
     Go_up = True
     GoTo si04
   End If
   If si05 = ss(0,0) OrElse si05 = ss(0,1) OrElse si05 = ss(0,2) OrElse si05 = ss(0,3) OrElse _
      si05 = ss(0,4) OrElse si05 = ss(0,6) OrElse si05 = ss(0,7) OrElse si05 = ss(0,8) OrElse _
      si05 = ss(1,5) OrElse si05 = ss(2,5) OrElse si05 = ss(3,5) OrElse si05 = ss(4,5) OrElse _
      si05 = ss(5,5) OrElse si05 = ss(6,5) OrElse si05 = ss(7,5) OrElse si05 = ss(8,5) OrElse _
      si05 = ss(1,3) OrElse si05 = ss(1,4) OrElse si05 = ss(2,3) OrElse si05 = ss(2,4) Then GoTo si05
   ss(0,5) = si05
 Else
   If Go_up = True Then GoTo si04
 End If
si06:
 If si(0,6) = 0 Then
   Go_up = False
   si06 = si06 + 1
   If si06 > 9 Then
     si06 = 0
     ss(0,6) = 0
     Go_up = True
     GoTo si05
   End If
   If si06 = ss(0,0) OrElse si06 = ss(0,1) OrElse si06 = ss(0,2) OrElse si06 = ss(0,3) OrElse _
      si06 = ss(0,4) OrElse si06 = ss(0,5) OrElse si06 = ss(0,7) OrElse si06 = ss(0,8) OrElse _
      si06 = ss(1,6) OrElse si06 = ss(2,6) OrElse si06 = ss(3,6) OrElse si06 = ss(4,6) OrElse _
      si06 = ss(5,6) OrElse si06 = ss(6,6) OrElse si06 = ss(7,6) OrElse si06 = ss(8,6) OrElse _
      si06 = ss(1,7) OrElse si06 = ss(1,8) OrElse si06 = ss(2,7) OrElse si06 = ss(2,8) Then GoTo si06
   ss(0,6) = si06
 Else
   If Go_up = True Then GoTo si05
 End If
si07:
 If si(0,7) = 0 Then
   Go_up = False
   si07 = si07 + 1
   If si07 > 9 Then
     si07 = 0
     ss(0,7) = 0
     Go_up = True
     GoTo si06
   End If
   If si07 = ss(0,0) OrElse si07 = ss(0,1) OrElse si07 = ss(0,2) OrElse si07 = ss(0,3) OrElse _
      si07 = ss(0,4) OrElse si07 = ss(0,5) OrElse si07 = ss(0,6) OrElse si07 = ss(0,8) OrElse _
      si07 = ss(1,7) OrElse si07 = ss(2,7) OrElse si07 = ss(3,7) OrElse si07 = ss(4,7) OrElse _
      si07 = ss(5,7) OrElse si07 = ss(6,7) OrElse si07 = ss(7,7) OrElse si07 = ss(8,7) OrElse _
      si07 = ss(1,6) OrElse si07 = ss(1,8) OrElse si07 = ss(2,6) OrElse si07 = ss(2,8) Then GoTo si07
   ss(0,7) = si07
 Else
   If Go_up = True Then GoTo si06
 End If
si08:
 If si(0,8) = 0 Then
   Go_up = False
   si08 = si08 + 1
   If si08 > 9 Then
     si08 = 0
     ss(0,8) = 0
     Go_up = True
     GoTo si07
   End If
   If si08 = ss(0,0) OrElse si08 = ss(0,1) OrElse si08 = ss(0,2) OrElse si08 = ss(0,3) OrElse _
      si08 = ss(0,4) OrElse si08 = ss(0,5) OrElse si08 = ss(0,6) OrElse si08 = ss(0,7) OrElse _
      si08 = ss(1,8) OrElse si08 = ss(2,8) OrElse si08 = ss(3,8) OrElse si08 = ss(4,8) OrElse _
      si08 = ss(5,8) OrElse si08 = ss(6,8) OrElse si08 = ss(7,8) OrElse si08 = ss(8,8) OrElse _
      si08 = ss(3,5) OrElse si08 = ss(4,4) OrElse si08 = ss(5,3) OrElse _
      si08 = ss(6,2) OrElse si08 = ss(7,1) OrElse si08 = ss(8,0) OrElse _
      si08 = ss(1,6) OrElse si08 = ss(1,7) OrElse si08 = ss(2,6) OrElse si08 = ss(2,7) Then GoTo si08
   ss(0,8) = si08
 Else
   If Go_up = True Then GoTo si07
 End If
si10:
 If si(1,0) = 0 Then
   Go_up = False
   si10 = si10 + 1
   If si10 > 9 Then
     si10 = 0
     ss(1,0) = 0
     Go_up = True
     GoTo si08
   End If
   If si10 = ss(1,1) OrElse si10 = ss(1,2) OrElse si10 = ss(1,3) OrElse si10 = ss(1,4) OrElse _
      si10 = ss(1,5) OrElse si10 = ss(1,6) OrElse si10 = ss(1,7) OrElse si10 = ss(1,8) OrElse _
      si10 = ss(0,0) OrElse si10 = ss(2,0) OrElse si10 = ss(3,0) OrElse si10 = ss(4,0) OrElse _
      si10 = ss(5,0) OrElse si10 = ss(6,0) OrElse si10 = ss(7,0) OrElse si10 = ss(8,0) OrElse _
      si10 = ss(0,1) OrElse si10 = ss(0,2) OrElse si10 = ss(2,1) OrElse si10 = ss(2,2) Then GoTo si10
   ss(1,0) = si10
 Else
   If Go_up = True Then GoTo si08
 End If
si11:
 If si(1,1) = 0 Then
   Go_up = False
   si11 = si11 + 1
   If si11 > 9 Then
     si11 = 0
     ss(1,1) = 0
     Go_up = True
     GoTo si10
   End If
   If si11 = ss(1,0) OrElse si11 = ss(1,2) OrElse si11 = ss(1,3) OrElse si11 = ss(1,4) OrElse _
      si11 = ss(1,5) OrElse si11 = ss(1,6) OrElse si11 = ss(1,7) OrElse si11 = ss(1,8) OrElse _
      si11 = ss(0,1) OrElse si11 = ss(2,1) OrElse si11 = ss(3,1) OrElse si11 = ss(4,1) OrElse _
      si11 = ss(5,1) OrElse si11 = ss(6,1) OrElse si11 = ss(7,1) OrElse si11 = ss(8,1) OrElse _
      si11 = ss(3,3) OrElse si11 = ss(4,4) OrElse si11 = ss(5,5) OrElse _
      si11 = ss(6,6) OrElse si11 = ss(7,7) OrElse si11 = ss(8,8) OrElse _
      si11 = ss(0,0) OrElse si11 = ss(0,2) OrElse si11 = ss(2,0) OrElse si11 = ss(2,2) Then GoTo si11
   ss(1,1) = si11
 Else
   If Go_up = True Then GoTo si10
 End If
si12:
 If si(1,2) = 0 Then
   Go_up = False
   si12 = si12 + 1
   If si12 > 9 Then
     si12 = 0
     ss(1,2) = 0
     Go_up = True
     GoTo si11
   End If
   If si12 = ss(1,0) OrElse si12 = ss(1,1) OrElse si12 = ss(1,3) OrElse si12 = ss(1,4) OrElse _
      si12 = ss(1,5) OrElse si12 = ss(1,6) OrElse si12 = ss(1,7) OrElse si12 = ss(1,8) OrElse _
      si12 = ss(0,2) OrElse si12 = ss(2,2) OrElse si12 = ss(3,2) OrElse si12 = ss(4,2) OrElse _
      si12 = ss(5,2) OrElse si12 = ss(6,2) OrElse si12 = ss(7,2) OrElse si12 = ss(8,2) OrElse _
      si12 = ss(0,0) OrElse si12 = ss(0,1) OrElse si12 = ss(2,0) OrElse si12 = ss(2,1) Then GoTo si12
   ss(1,2) = si12
 Else
   If Go_up = True Then GoTo si11
 End If
si13:
 If si(1,3) = 0 Then
   Go_up = False
   si13 = si13 + 1
   If si13 > 9 Then
     si13 = 0
     ss(1,3) = 0
     Go_up = True
     GoTo si12
   End If
   If si13 = ss(1,0) OrElse si13 = ss(1,1) OrElse si13 = ss(1,2) OrElse si13 = ss(1,4) OrElse _
      si13 = ss(1,5) OrElse si13 = ss(1,6) OrElse si13 = ss(1,7) OrElse si13 = ss(1,8) OrElse _
      si13 = ss(0,3) OrElse si13 = ss(2,3) OrElse si13 = ss(3,3) OrElse si13 = ss(4,3) OrElse _
      si13 = ss(5,3) OrElse si13 = ss(6,3) OrElse si13 = ss(7,3) OrElse si13 = ss(8,3) OrElse _
      si13 = ss(0,4) OrElse si13 = ss(0,5) OrElse si13 = ss(2,4) OrElse si13 = ss(2,5) Then GoTo si13
   ss(1,3) = si13
 Else
   If Go_up = True Then GoTo si12
 End If
si14:
 If si(1,4) = 0 Then
   Go_up = False
   si14 = si14 + 1
   If si14 > 9 Then
     si14 = 0
     ss(1,4) = 0
     Go_up = True
     GoTo si13
   End If
   If si14 = ss(1,0) OrElse si14 = ss(1,1) OrElse si14 = ss(1,2) OrElse si14 = ss(1,3) OrElse _
      si14 = ss(1,5) OrElse si14 = ss(1,6) OrElse si14 = ss(1,7) OrElse si14 = ss(1,8) OrElse _
      si14 = ss(0,4) OrElse si14 = ss(2,4) OrElse si14 = ss(3,4) OrElse si14 = ss(4,4) OrElse _
      si14 = ss(5,4) OrElse si14 = ss(6,4) OrElse si14 = ss(7,4) OrElse si14 = ss(8,4) OrElse _
      si14 = ss(0,3) OrElse si14 = ss(0,5) OrElse si14 = ss(2,3) OrElse si14 = ss(2,5) Then GoTo si14
   ss(1,4) = si14
 Else
   If Go_up = True Then GoTo si13
 End If
si15:
 If si(1,5) = 0 Then
   Go_up = False
   si15 = si15 + 1
   If si15 > 9 Then
     si15 = 0
     ss(1,5) = 0
     Go_up = True
     GoTo si14
   End If
   If si15 = ss(1,0) OrElse si15 = ss(1,1) OrElse si15 = ss(1,2) OrElse si15 = ss(1,3) OrElse _
      si15 = ss(1,4) OrElse si15 = ss(1,6) OrElse si15 = ss(1,7) OrElse si15 = ss(1,8) OrElse _
      si15 = ss(0,5) OrElse si15 = ss(2,5) OrElse si15 = ss(3,5) OrElse si15 = ss(4,5) OrElse _
      si15 = ss(5,5) OrElse si15 = ss(6,5) OrElse si15 = ss(7,5) OrElse si15 = ss(8,5) OrElse _
      si15 = ss(0,3) OrElse si15 = ss(0,4) OrElse si15 = ss(2,3) OrElse si15 = ss(2,4) Then GoTo si15
   ss(1,5) = si15
 Else
   If Go_up = True Then GoTo si14
 End If
si16:
 If si(1,6) = 0 Then
   Go_up = False
   si16 = si16 + 1
   If si16 > 9 Then
     si16 = 0
     ss(1,6) = 0
     Go_up = True
     GoTo si15
   End If
   If si16 = ss(1,0) OrElse si16 = ss(1,1) OrElse si16 = ss(1,2) OrElse si16 = ss(1,3) OrElse _
      si16 = ss(1,4) OrElse si16 = ss(1,5) OrElse si16 = ss(1,7) OrElse si16 = ss(1,8) OrElse _
      si16 = ss(0,6) OrElse si16 = ss(2,6) OrElse si16 = ss(3,6) OrElse si16 = ss(4,6) OrElse _
      si16 = ss(5,6) OrElse si16 = ss(6,6) OrElse si16 = ss(7,6) OrElse si16 = ss(8,6) OrElse _
      si16 = ss(0,7) OrElse si16 = ss(0,8) OrElse si16 = ss(2,7) OrElse si16 = ss(2,8) Then GoTo si16
   ss(1,6) = si16
 Else
   If Go_up = True Then GoTo si15
 End If
si17:
 If si(1,7) = 0 Then
   Go_up = False
   si17 = si17 + 1
   If si17 > 9 Then
     si17 = 0
     ss(1,7) = 0
     Go_up = True
     GoTo si16
   End If
   If si17 = ss(1,0) OrElse si17 = ss(1,1) OrElse si17 = ss(1,2) OrElse si17 = ss(1,3) OrElse _
      si17 = ss(1,4) OrElse si17 = ss(1,5) OrElse si17 = ss(1,6) OrElse si17 = ss(1,8) OrElse _
      si17 = ss(0,7) OrElse si17 = ss(2,7) OrElse si17 = ss(3,7) OrElse si17 = ss(4,7) OrElse _
      si17 = ss(5,7) OrElse si17 = ss(6,7) OrElse si17 = ss(7,7) OrElse si17 = ss(8,7) OrElse _
      si17 = ss(3,5) OrElse si17 = ss(4,4) OrElse si17 = ss(5,3) OrElse _
      si17 = ss(6,2) OrElse si17 = ss(7,1) OrElse si17 = ss(8,1) OrElse _
      si17 = ss(0,6) OrElse si17 = ss(0,8) OrElse si17 = ss(2,6) OrElse si17 = ss(2,8) Then GoTo si17
   ss(1,7) = si17
 Else
   If Go_up = True Then GoTo si16
 End If
si18:
 If si(1,8) = 0 Then
   Go_up = False
   si18 = si18 + 1
   If si18 > 9 Then
     si18 = 0
     ss(1,8) = 0
     Go_up = True
     GoTo si17
   End If
   If si18 = ss(1,0) OrElse si18 = ss(1,1) OrElse si18 = ss(1,2) OrElse si18 = ss(1,3) OrElse _
      si18 = ss(1,4) OrElse si18 = ss(1,5) OrElse si18 = ss(1,6) OrElse si18 = ss(1,7) OrElse _
      si18 = ss(0,8) OrElse si18 = ss(2,8) OrElse si18 = ss(3,8) OrElse si18 = ss(4,8) OrElse _
      si18 = ss(5,8) OrElse si18 = ss(6,8) OrElse si18 = ss(7,8) OrElse si18 = ss(8,8) OrElse _
      si18 = ss(0,6) OrElse si18 = ss(0,7) OrElse si18 = ss(2,6) OrElse si18 = ss(2,7) Then GoTo si18
   ss(1,8) = si18
 Else
   If Go_up = True Then GoTo si17
 End If
si20:
 If si(2,0) = 0 Then
   Go_up = False
   si20 = si20 + 1
   If si20 > 9 Then
     si20 = 0
     ss(2,0) = 0
     Go_up = True
     GoTo si18
   End If
   If si20 = ss(2,1) OrElse si20 = ss(2,2) OrElse si20 = ss(2,3) OrElse si20 = ss(2,4) OrElse _
      si20 = ss(2,5) OrElse si20 = ss(2,6) OrElse si20 = ss(2,7) OrElse si20 = ss(2,8) OrElse _
      si20 = ss(0,0) OrElse si20 = ss(1,0) OrElse si20 = ss(3,0) OrElse si20 = ss(4,0) OrElse _
      si20 = ss(5,0) OrElse si20 = ss(6,0) OrElse si20 = ss(7,0) OrElse si20 = ss(8,0) OrElse _
      si20 = ss(0,1) OrElse si20 = ss(0,2) OrElse si20 = ss(1,1) OrElse si20 = ss(1,2) Then GoTo si20
   ss(2,0) = si20
 Else
   If Go_up = True Then GoTo si18
 End If
si21:
 If si(2,1) = 0 Then
   Go_up = False
   si21 = si21 + 1
   If si21 > 9 Then
     si21 = 0
     ss(2,1) = 0
     Go_up = True
     GoTo si20
   End If
   If si21 = ss(2,0) OrElse si21 = ss(2,2) OrElse si21 = ss(2,3) OrElse si21 = ss(2,4) OrElse _
      si21 = ss(2,5) OrElse si21 = ss(2,6) OrElse si21 = ss(2,7) OrElse si21 = ss(2,8) OrElse _
      si21 = ss(0,1) OrElse si21 = ss(1,1) OrElse si21 = ss(3,1) OrElse si21 = ss(4,1) OrElse _
      si21 = ss(5,1) OrElse si21 = ss(6,1) OrElse si21 = ss(7,1) OrElse si21 = ss(8,1) OrElse _
      si21 = ss(0,0) OrElse si21 = ss(0,2) OrElse si21 = ss(1,0) OrElse si21 = ss(1,2) Then GoTo si21
   ss(2,1) = si21
 Else
   If Go_up = True Then GoTo si20
 End If
si22:
 If si(2,2) = 0 Then
   Go_up = False
   si22 = si22 + 1
   If si22 > 9 Then
     si22 = 0
     ss(2,2) = 0
     Go_up = True
     GoTo si21
   End If
   If si22 = ss(2,0) OrElse si22 = ss(2,1) OrElse si22 = ss(2,3) OrElse si22 = ss(2,4) OrElse _
      si22 = ss(2,5) OrElse si22 = ss(2,6) OrElse si22 = ss(2,7) OrElse si22 = ss(2,8) OrElse _
      si22 = ss(0,2) OrElse si22 = ss(1,2) OrElse si22 = ss(3,2) OrElse si22 = ss(4,2) OrElse _
      si22 = ss(5,2) OrElse si22 = ss(6,2) OrElse si22 = ss(7,2) OrElse si22 = ss(8,2) OrElse _
      si22 = ss(3,3) OrElse si22 = ss(4,4) OrElse si22 = ss(5,5) OrElse _
      si22 = ss(6,6) OrElse si22 = ss(7,7) OrElse si22 = ss(8,8) OrElse _
      si22 = ss(0,0) OrElse si22 = ss(0,1) OrElse si22 = ss(1,0) OrElse si22 = ss(1,1) Then GoTo si22
   ss(2,2) = si22
 Else
   If Go_up = True Then GoTo si21
 End If
si23:
 If si(2,3) = 0 Then
   Go_up = False
   si23 = si23 + 1
   If si23 > 9 Then
     si23 = 0
     ss(2,3) = 0
     Go_up = True
     GoTo si22
   End If
   If si23 = ss(2,0) OrElse si23 = ss(2,1) OrElse si23 = ss(2,2) OrElse si23 = ss(2,4) OrElse _
      si23 = ss(2,5) OrElse si23 = ss(2,6) OrElse si23 = ss(2,7) OrElse si23 = ss(2,8) OrElse _
      si23 = ss(0,3) OrElse si23 = ss(1,3) OrElse si23 = ss(3,3) OrElse si23 = ss(4,3) OrElse _
      si23 = ss(5,3) OrElse si23 = ss(6,3) OrElse si23 = ss(7,3) OrElse si23 = ss(8,3) OrElse _
      si23 = ss(0,4) OrElse si23 = ss(0,5) OrElse si23 = ss(1,4) OrElse si23 = ss(1,5) Then GoTo si23
   ss(2,3) = si23
 Else
   If Go_up = True Then GoTo si22
 End If
si24:
 If si(2,4) = 0 Then
   Go_up = False
   si24 = si24 + 1
   If si24 > 9 Then
     si24 = 0
     ss(2,4) = 0
     Go_up = True
     GoTo si23
   End If
   If si24 = ss(2,0) OrElse si24 = ss(2,1) OrElse si24 = ss(2,2) OrElse si24 = ss(2,3) OrElse _
      si24 = ss(2,5) OrElse si24 = ss(2,6) OrElse si24 = ss(2,7) OrElse si24 = ss(2,8) OrElse _
      si24 = ss(0,4) OrElse si24 = ss(1,4) OrElse si24 = ss(3,4) OrElse si24 = ss(4,4) OrElse _
      si24 = ss(5,4) OrElse si24 = ss(6,4) OrElse si24 = ss(7,4) OrElse si24 = ss(8,4) OrElse _
      si24 = ss(0,3) OrElse si24 = ss(0,5) OrElse si24 = ss(1,3) OrElse si24 = ss(1,5) Then GoTo si24
   ss(2,4) = si24
 Else
   If Go_up = True Then GoTo si23
 End If
si25:
 If si(2,5) = 0 Then
   Go_up = False
   si25 = si25 + 1
   If si25 > 9 Then
     si25 = 0
     ss(2,5) = 0
     Go_up = True
     GoTo si24
   End If
   If si25 = ss(2,0) OrElse si25 = ss(2,1) OrElse si25 = ss(2,2) OrElse si25 = ss(2,3) OrElse _
      si25 = ss(2,4) OrElse si25 = ss(2,6) OrElse si25 = ss(2,7) OrElse si25 = ss(2,8) OrElse _
      si25 = ss(0,5) OrElse si25 = ss(1,5) OrElse si25 = ss(3,5) OrElse si25 = ss(4,5) OrElse _
      si25 = ss(5,5) OrElse si25 = ss(6,5) OrElse si25 = ss(7,5) OrElse si25 = ss(8,5) OrElse _
      si25 = ss(0,3) OrElse si25 = ss(0,4) OrElse si25 = ss(1,3) OrElse si25 = ss(1,4) Then GoTo si25
   ss(2,5) = si25
 Else
   If Go_up = True Then GoTo si24
 End If
si26:
 If si(2,6) = 0 Then
   Go_up = False
   si26 = si26 + 1
   If si26 > 9 Then
     si26 = 0
     ss(2,6) = 0
     Go_up = True
     GoTo si25
   End If
   If si26 = ss(2,0) OrElse si26 = ss(2,1) OrElse si26 = ss(2,2) OrElse si26 = ss(2,3) OrElse _
      si26 = ss(2,4) OrElse si26 = ss(2,5) OrElse si26 = ss(2,7) OrElse si26 = ss(2,8) OrElse _
      si26 = ss(0,6) OrElse si26 = ss(1,6) OrElse si26 = ss(3,6) OrElse si26 = ss(4,6) OrElse _
      si26 = ss(5,6) OrElse si26 = ss(6,6) OrElse si26 = ss(7,6) OrElse si26 = ss(8,6) OrElse _
      si26 = ss(3,5) OrElse si26 = ss(4,4) OrElse si26 = ss(5,3) OrElse _
      si26 = ss(6,2) OrElse si26 = ss(7,1) OrElse si26 = ss(8,0) OrElse _
      si26 = ss(0,7) OrElse si26 = ss(0,8) OrElse si26 = ss(1,7) OrElse si26 = ss(1,8) Then GoTo si26
   ss(2,6) = si26
 Else
   If Go_up = True Then GoTo si25
 End If
si27:
 If si(2,7) = 0 Then
   Go_up = False
   si27 = si27 + 1
   If si27 > 9 Then
     si27 = 0
     ss(2,7) = 0
     Go_up = True
     GoTo si26
   End If
   If si27 = ss(2,0) OrElse si27 = ss(2,1) OrElse si27 = ss(2,2) OrElse si27 = ss(2,3) OrElse _
      si27 = ss(2,4) OrElse si27 = ss(2,5) OrElse si27 = ss(2,6) OrElse si27 = ss(2,8) OrElse _
      si27 = ss(0,7) OrElse si27 = ss(1,7) OrElse si27 = ss(3,7) OrElse si27 = ss(4,7) OrElse _
      si27 = ss(5,7) OrElse si27 = ss(6,7) OrElse si27 = ss(7,7) OrElse si27 = ss(8,7) OrElse _
      si27 = ss(0,6) OrElse si27 = ss(0,8) OrElse si27 = ss(1,6) OrElse si27 = ss(1,8) Then GoTo si27
   ss(2,7) = si27
 Else
   If Go_up = True Then GoTo si26
 End If
si28:
 If si(2,8) = 0 Then
   Go_up = False
   si28 = si28 + 1
   If si28 > 9 Then
     si28 = 0
     ss(2,8) = 0
     Go_up = True
     GoTo si27
   End If
   If si28 = ss(2,0) OrElse si28 = ss(2,1) OrElse si28 = ss(2,2) OrElse si28 = ss(2,3) OrElse _
      si28 = ss(2,4) OrElse si28 = ss(2,5) OrElse si28 = ss(2,6) OrElse si28 = ss(2,7) OrElse _
      si28 = ss(0,8) OrElse si28 = ss(1,8) OrElse si28 = ss(3,8) OrElse si28 = ss(4,8) OrElse _
      si28 = ss(5,8) OrElse si28 = ss(6,8) OrElse si28 = ss(7,8) OrElse si28 = ss(8,8) OrElse _
      si28 = ss(0,6) OrElse si28 = ss(0,7) OrElse si28 = ss(1,6) OrElse si28 = ss(1,7) Then GoTo si28
   ss(2,8) = si28
 Else
   If Go_up = True Then GoTo si27
 End If
si30:
 If si(3,0) = 0 Then
   Go_up = False
   si30 = si30 + 1
   If si30 > 9 Then
     si30 = 0
     ss(3,0) = 0
     Go_up = True
     GoTo si28
   End If
   If si30 = ss(3,1) OrElse si30 = ss(3,2) OrElse si30 = ss(3,3) OrElse si30 = ss(3,4) OrElse _
      si30 = ss(3,5) OrElse si30 = ss(3,6) OrElse si30 = ss(3,7) OrElse si30 = ss(3,8) OrElse _
      si30 = ss(0,0) OrElse si30 = ss(1,0) OrElse si30 = ss(2,0) OrElse si30 = ss(4,0) OrElse _
      si30 = ss(5,0) OrElse si30 = ss(6,0) OrElse si30 = ss(7,0) OrElse si30 = ss(8,0) OrElse _
      si30 = ss(4,1) OrElse si30 = ss(4,2) OrElse si30 = ss(5,1) OrElse si30 = ss(5,2) Then GoTo si30
   ss(3,0) = si30
 Else
   If Go_up = True Then GoTo si28
 End If
si31:
 If si(3,1) = 0 Then
   Go_up = False
   si31 = si31 + 1
   If si31 > 9 Then
     si31 = 0
     ss(3,1) = 0
     Go_up = True
     GoTo si30
   End If
   If si31 = ss(3,0) OrElse si31 = ss(3,2) OrElse si31 = ss(3,3) OrElse si31 = ss(3,4) OrElse _
      si31 = ss(3,5) OrElse si31 = ss(3,6) OrElse si31 = ss(3,7) OrElse si31 = ss(3,8) OrElse _
      si31 = ss(0,1) OrElse si31 = ss(1,1) OrElse si31 = ss(2,1) OrElse si31 = ss(4,1) OrElse _
      si31 = ss(5,1) OrElse si31 = ss(6,1) OrElse si31 = ss(7,1) OrElse si31 = ss(8,1) OrElse _
      si31 = ss(4,0) OrElse si31 = ss(4,2) OrElse si31 = ss(5,0) OrElse si31 = ss(5,2) Then GoTo si31
   ss(3,1) = si31
 Else
   If Go_up = True Then GoTo si30
 End If
si32:
 If si(3,2) = 0 Then
   Go_up = False
   si32 = si32 + 1
   If si32 > 9 Then
     si32 = 0
     ss(3,2) = 0
     Go_up = True
     GoTo si31
   End If
   If si32 = ss(3,0) OrElse si32 = ss(3,1) OrElse si32 = ss(3,3) OrElse si32 = ss(3,4) OrElse _
      si32 = ss(3,5) OrElse si32 = ss(3,6) OrElse si32 = ss(3,7) OrElse si32 = ss(3,8) OrElse _
      si32 = ss(0,2) OrElse si32 = ss(1,2) OrElse si32 = ss(2,2) OrElse si32 = ss(4,2) OrElse _
      si32 = ss(5,2) OrElse si32 = ss(6,2) OrElse si32 = ss(7,2) OrElse si32 = ss(8,2) OrElse _
      si32 = ss(4,0) OrElse si32 = ss(4,1) OrElse si32 = ss(5,0) OrElse si32 = ss(5,1) Then GoTo si32
   ss(3,2) = si32
 Else
   If Go_up = True Then GoTo si31
 End If
si33:
 If si(3,3) = 0 Then
   Go_up = False
   si33 = si33 + 1
   If si33 > 9 Then
     si33 = 0
     ss(3,3) = 0
     Go_up = True
     GoTo si32
   End If
   If si33 = ss(3,0) OrElse si33 = ss(3,1) OrElse si33 = ss(3,2) OrElse si33 = ss(3,4) OrElse _
      si33 = ss(3,5) OrElse si33 = ss(3,6) OrElse si33 = ss(3,7) OrElse si33 = ss(3,8) OrElse _
      si33 = ss(0,3) OrElse si33 = ss(1,3) OrElse si33 = ss(2,3) OrElse si33 = ss(4,3) OrElse _
      si33 = ss(5,3) OrElse si33 = ss(6,3) OrElse si33 = ss(7,3) OrElse si33 = ss(8,3) OrElse _
      si33 = ss(0,0) OrElse si33 = ss(1,1) OrElse si33 = ss(2,2) OrElse _
      si33 = ss(6,6) OrElse si33 = ss(7,7) OrElse si33 = ss(8,8) OrElse _
      si33 = ss(4,4) OrElse si33 = ss(4,5) OrElse si33 = ss(5,4) OrElse si33 = ss(5,5) Then GoTo si33
   ss(3,3) = si33
 Else
   If Go_up = True Then GoTo si32
 End If
si34:
 If si(3,4) = 0 Then
   Go_up = False
   si34 = si34 + 1
   If si34 > 9 Then
     si34 = 0
     ss(3,4) = 0
     Go_up = True
     GoTo si33
   End If
   If si34 = ss(3,0) OrElse si34 = ss(3,1) OrElse si34 = ss(3,2) OrElse si34 = ss(3,3) OrElse _
      si34 = ss(3,5) OrElse si34 = ss(3,6) OrElse si34 = ss(3,7) OrElse si34 = ss(3,8) OrElse _
      si34 = ss(0,4) OrElse si34 = ss(1,4) OrElse si34 = ss(2,4) OrElse si34 = ss(4,4) OrElse _
      si34 = ss(5,4) OrElse si34 = ss(6,4) OrElse si34 = ss(7,4) OrElse si34 = ss(8,4) OrElse _
      si34 = ss(4,3) OrElse si34 = ss(4,5) OrElse si34 = ss(5,3) OrElse si34 = ss(5,5) Then GoTo si34
   ss(3,4) = si34
 Else
   If Go_up = True Then GoTo si33
 End If
si35:
 If si(3,5) = 0 Then
   Go_up = False
   si35 = si35 + 1
   If si35 > 9 Then
     si35 = 0
     ss(3,5) = 0
     Go_up = True
     GoTo si34
   End If
   If si35 = ss(3,0) OrElse si35 = ss(3,1) OrElse si35 = ss(3,2) OrElse si35 = ss(3,3) OrElse _
      si35 = ss(3,4) OrElse si35 = ss(3,6) OrElse si35 = ss(3,7) OrElse si35 = ss(3,8) OrElse _
      si35 = ss(0,5) OrElse si35 = ss(1,5) OrElse si35 = ss(2,5) OrElse si35 = ss(4,5) OrElse _
      si35 = ss(5,5) OrElse si35 = ss(6,5) OrElse si35 = ss(7,5) OrElse si35 = ss(8,5) OrElse _
      si35 = ss(0,8) OrElse si35 = ss(1,7) OrElse si35 = ss(2,6) OrElse _
      si35 = ss(6,2) OrElse si35 = ss(7,1) OrElse si35 = ss(8,0) OrElse _
      si35 = ss(4,3) OrElse si35 = ss(4,4) OrElse si35 = ss(5,3) OrElse si35 = ss(5,4) Then GoTo si35
   ss(3,5) = si35
 Else
   If Go_up = True Then GoTo si34
 End If
si36:
 If si(3,6) = 0 Then
   Go_up = False
   si36 = si36 + 1
   If si36 > 9 Then
     si36 = 0
     ss(3,6) = 0
     Go_up = True
     GoTo si35
   End If
   If si36 = ss(3,0) OrElse si36 = ss(3,1) OrElse si36 = ss(3,2) OrElse si36 = ss(3,3) OrElse _
      si36 = ss(3,4) OrElse si36 = ss(3,5) OrElse si36 = ss(3,7) OrElse si36 = ss(3,8) OrElse _
      si36 = ss(0,6) OrElse si36 = ss(1,6) OrElse si36 = ss(2,6) OrElse si36 = ss(4,6) OrElse _
      si36 = ss(5,6) OrElse si36 = ss(6,6) OrElse si36 = ss(7,6) OrElse si36 = ss(8,6) OrElse _
      si36 = ss(4,7) OrElse si36 = ss(4,8) OrElse si36 = ss(5,7) OrElse si36 = ss(5,8) Then GoTo si36
   ss(3,6) = si36
 Else
   If Go_up = True Then GoTo si35
 End If
si37:
 If si(3,7) = 0 Then
   Go_up = False
   si37 = si37 + 1
   If si37 > 9 Then
     si37 = 0
     ss(3,7) = 0
     Go_up = True
     GoTo si36
   End If
   If si37 = ss(3,0) OrElse si37 = ss(3,1) OrElse si37 = ss(3,2) OrElse si37 = ss(3,3) OrElse _
      si37 = ss(3,4) OrElse si37 = ss(3,5) OrElse si37 = ss(3,6) OrElse si37 = ss(3,8) OrElse _
      si37 = ss(0,7) OrElse si37 = ss(1,7) OrElse si37 = ss(2,7) OrElse si37 = ss(4,7) OrElse _
      si37 = ss(5,7) OrElse si37 = ss(6,7) OrElse si37 = ss(7,7) OrElse si37 = ss(8,7) OrElse _
      si37 = ss(4,6) OrElse si37 = ss(4,8) OrElse si37 = ss(5,6) OrElse si37 = ss(5,8) Then GoTo si37
   ss(3,7) = si37
 Else
   If Go_up = True Then GoTo si36
 End If
si38:
 If si(3,8) = 0 Then
   Go_up = False
   si38 = si38 + 1
   If si38 > 9 Then
     si38 = 0
     ss(3,8) = 0
     Go_up = True
     GoTo si37
   End If
   If si38 = ss(3,0) OrElse si38 = ss(3,1) OrElse si38 = ss(3,2) OrElse si38 = ss(3,3) OrElse _
      si38 = ss(3,4) OrElse si38 = ss(3,5) OrElse si38 = ss(3,6) OrElse si38 = ss(3,7) OrElse _
      si38 = ss(0,8) OrElse si38 = ss(1,8) OrElse si38 = ss(2,8) OrElse si38 = ss(4,8) OrElse _
      si38 = ss(5,8) OrElse si38 = ss(6,8) OrElse si38 = ss(7,8) OrElse si38 = ss(8,8) OrElse _
      si38 = ss(4,6) OrElse si38 = ss(4,7) OrElse si38 = ss(5,6) OrElse si38 = ss(5,7) Then GoTo si38
   ss(3,8) = si38
 Else
   If Go_up = True Then GoTo si37
 End If
si40:
 If si(4,0) = 0 Then
   Go_up = False
   si40 = si40 + 1
   If si40 > 9 Then
     si40 = 0
     ss(4,0) = 0
     Go_up = True
     GoTo si38
   End If
   If si40 = ss(4,1) OrElse si40 = ss(4,2) OrElse si40 = ss(4,3) OrElse si40 = ss(4,4) OrElse _
      si40 = ss(4,5) OrElse si40 = ss(4,6) OrElse si40 = ss(4,7) OrElse si40 = ss(4,8) OrElse _
      si40 = ss(0,0) OrElse si40 = ss(1,0) OrElse si40 = ss(2,0) OrElse si40 = ss(3,0) OrElse _
      si40 = ss(5,0) OrElse si40 = ss(6,0) OrElse si40 = ss(7,0) OrElse si40 = ss(8,0) OrElse _
      si40 = ss(3,1) OrElse si40 = ss(3,2) OrElse si40 = ss(5,1) OrElse si40 = ss(5,2) Then GoTo si40
   ss(4,0) = si40
 Else
   If Go_up = True Then GoTo si38
 End If
si41:
 If si(4,1) = 0 Then
   Go_up = False
   si41 = si41 + 1
   If si41 > 9 Then
     si41 = 0
     ss(4,1) = 0
     Go_up = True
     GoTo si40
   End If
   If si41 = ss(4,0) OrElse si41 = ss(4,2) OrElse si41 = ss(4,3) OrElse si41 = ss(4,4) OrElse _
      si41 = ss(4,5) OrElse si41 = ss(4,6) OrElse si41 = ss(4,7) OrElse si41 = ss(4,8) OrElse _
      si41 = ss(0,1) OrElse si41 = ss(1,1) OrElse si41 = ss(2,1) OrElse si41 = ss(3,1) OrElse _
      si41 = ss(5,1) OrElse si41 = ss(6,1) OrElse si41 = ss(7,1) OrElse si41 = ss(8,1) OrElse _
      si41 = ss(3,0) OrElse si41 = ss(3,2) OrElse si41 = ss(5,0) OrElse si41 = ss(5,2) Then GoTo si41
   ss(4,1) = si41
 Else
   If Go_up = True Then GoTo si40
 End If
si42:
 If si(4,2) = 0 Then
   Go_up = False
   si42 = si42 + 1
   If si42 > 9 Then
     si42 = 0
     ss(4,2) = 0
     Go_up = True
     GoTo si41
   End If
   If si42 = ss(4,0) OrElse si42 = ss(4,1) OrElse si42 = ss(4,3) OrElse si42 = ss(4,4) OrElse _
      si42 = ss(4,5) OrElse si42 = ss(4,6) OrElse si42 = ss(4,7) OrElse si42 = ss(4,8) OrElse _
      si42 = ss(0,2) OrElse si42 = ss(1,2) OrElse si42 = ss(2,2) OrElse si42 = ss(3,2) OrElse _
      si42 = ss(5,2) OrElse si42 = ss(6,2) OrElse si42 = ss(7,2) OrElse si42 = ss(8,2) OrElse _
      si42 = ss(3,0) OrElse si42 = ss(3,1) OrElse si42 = ss(5,0) OrElse si42 = ss(5,1) Then GoTo si42
   ss(4,2) = si42
 Else
   If Go_up = True Then GoTo si41
 End If
si43:
 If si(4,3) = 0 Then
   Go_up = False
   si43 = si43 + 1
   If si43 > 9 Then
     si43 = 0
     ss(4,3) = 0
     Go_up = True
     GoTo si42
   End If
   If si43 = ss(4,0) OrElse si43 = ss(4,1) OrElse si43 = ss(4,2) OrElse si43 = ss(4,4) OrElse _
      si43 = ss(4,5) OrElse si43 = ss(4,6) OrElse si43 = ss(4,7) OrElse si43 = ss(4,8) OrElse _
      si43 = ss(0,3) OrElse si43 = ss(1,3) OrElse si43 = ss(2,3) OrElse si43 = ss(3,3) OrElse _
      si43 = ss(5,3) OrElse si43 = ss(6,3) OrElse si43 = ss(7,3) OrElse si43 = ss(8,3) OrElse _
      si43 = ss(3,4) OrElse si43 = ss(3,5) OrElse si43 = ss(5,4) OrElse si43 = ss(5,5) Then GoTo si43
   ss(4,3) = si43
 Else
   If Go_up = True Then GoTo si42
 End If
si44:
 If si(4,4) = 0 Then
   Go_up = False
   si44 = si44 + 1
   If si44 > 9 Then
     si44 = 0
     ss(4,4) = 0
     Go_up = True
     GoTo si43
   End If
   If si44 = ss(4,0) OrElse si44 = ss(4,1) OrElse si44 = ss(4,2) OrElse si44 = ss(4,3) OrElse _
      si44 = ss(4,5) OrElse si44 = ss(4,6) OrElse si44 = ss(4,7) OrElse si44 = ss(4,8) OrElse _
      si44 = ss(0,4) OrElse si44 = ss(1,4) OrElse si44 = ss(2,4) OrElse si44 = ss(3,4) OrElse _
      si44 = ss(5,4) OrElse si44 = ss(6,4) OrElse si44 = ss(7,4) OrElse si44 = ss(8,4) OrElse _
      si44 = ss(0,0) OrElse si44 = ss(1,1) OrElse si44 = ss(2,2) OrElse _
      si44 = ss(6,6) OrElse si44 = ss(7,7) OrElse si44 = ss(8,8) OrElse _
      si44 = ss(0,8) OrElse si44 = ss(1,7) OrElse si44 = ss(2,6) OrElse _
      si44 = ss(6,2) OrElse si44 = ss(7,1) OrElse si44 = ss(8,0) OrElse _
      si44 = ss(3,3) OrElse si44 = ss(3,5) OrElse si44 = ss(5,3) OrElse si44 = ss(5,5) Then GoTo si44
   ss(4,4) = si44
 Else
   If Go_up = True Then GoTo si43
 End If
si45:
 If si(4,5) = 0 Then
   Go_up = False
   si45 = si45 + 1
   If si45 > 9 Then
     si45 = 0
     ss(4,5) = 0
     Go_up = True
     GoTo si44
   End If
   If si45 = ss(4,0) OrElse si45 = ss(4,1) OrElse si45 = ss(4,2) OrElse si45 = ss(4,3) OrElse _
      si45 = ss(4,4) OrElse si45 = ss(4,6) OrElse si45 = ss(4,7) OrElse si45 = ss(4,8) OrElse _
      si45 = ss(0,5) OrElse si45 = ss(1,5) OrElse si45 = ss(2,5) OrElse si45 = ss(3,5) OrElse _
      si45 = ss(5,5) OrElse si45 = ss(6,5) OrElse si45 = ss(7,5) OrElse si45 = ss(8,5) OrElse _
      si45 = ss(3,3) OrElse si45 = ss(3,4) OrElse si45 = ss(5,3) OrElse si45 = ss(5,4) Then GoTo si45
   ss(4,5) = si45
 Else
   If Go_up = True Then GoTo si44
 End If
si46:
 If si(4,6) = 0 Then
   Go_up = False
   si46 = si46 + 1
   If si46 > 9 Then
     si46 = 0
     ss(4,6) = 0
     Go_up = True
     GoTo si45
   End If
   If si46 = ss(4,0) OrElse si46 = ss(4,1) OrElse si46 = ss(4,2) OrElse si46 = ss(4,3) OrElse _
      si46 = ss(4,4) OrElse si46 = ss(4,5) OrElse si46 = ss(4,7) OrElse si46 = ss(4,8) OrElse _
      si46 = ss(0,6) OrElse si46 = ss(1,6) OrElse si46 = ss(2,6) OrElse si46 = ss(3,6) OrElse _
      si46 = ss(5,6) OrElse si46 = ss(6,6) OrElse si46 = ss(7,6) OrElse si46 = ss(8,6) OrElse _
      si46 = ss(3,7) OrElse si46 = ss(3,8) OrElse si46 = ss(5,7) OrElse si46 = ss(5,8) Then GoTo si46
   ss(4,6) = si46
 Else
   If Go_up = True Then GoTo si45
 End If
si47:
 If si(4,7) = 0 Then
   Go_up = False
   si47 = si47 + 1
   If si47 > 9 Then
     si47 = 0
     ss(4,7) = 0
     Go_up = True
     GoTo si46
   End If
   If si47 = ss(4,0) OrElse si47 = ss(4,1) OrElse si47 = ss(4,2) OrElse si47 = ss(4,3) OrElse _
      si47 = ss(4,4) OrElse si47 = ss(4,5) OrElse si47 = ss(4,6) OrElse si47 = ss(4,8) OrElse _
      si47 = ss(0,7) OrElse si47 = ss(1,7) OrElse si47 = ss(2,7) OrElse si47 = ss(3,7) OrElse _
      si47 = ss(5,7) OrElse si47 = ss(6,7) OrElse si47 = ss(7,7) OrElse si47 = ss(8,7) OrElse _
      si47 = ss(3,6) OrElse si47 = ss(3,8) OrElse si47 = ss(5,6) OrElse si47 = ss(5,8) Then GoTo si47
   ss(4,7) = si47
 Else
   If Go_up = True Then GoTo si46
 End If
si48:
 If si(4,8) = 0 Then
   Go_up = False
   si48 = si48 + 1
   If si48 > 9 Then
     si48 = 0
     ss(4,8) = 0
     Go_up = True
     GoTo si47
   End If
   If si48 = ss(4,0) OrElse si48 = ss(4,1) OrElse si48 = ss(4,2) OrElse si48 = ss(4,3) OrElse _
      si48 = ss(4,4) OrElse si48 = ss(4,5) OrElse si48 = ss(4,6) OrElse si48 = ss(4,7) OrElse _
      si48 = ss(0,8) OrElse si48 = ss(1,8) OrElse si48 = ss(2,8) OrElse si48 = ss(3,8) OrElse _
      si48 = ss(5,8) OrElse si48 = ss(6,8) OrElse si48 = ss(7,8) OrElse si48 = ss(8,8) OrElse _
      si48 = ss(3,6) OrElse si48 = ss(3,7) OrElse si48 = ss(5,6) OrElse si48 = ss(5,7) Then GoTo si48
   ss(4,8) = si48
 Else
   If Go_up = True Then GoTo si47
 End If
si50:
 If si(5,0) = 0 Then
   Go_up = False
   si50 = si50 + 1
   If si50 > 9 Then
     si50 = 0
     ss(5,0) = 0
     Go_up = True
     GoTo si48
   End If
   If si50 = ss(5,1) OrElse si50 = ss(5,2) OrElse si50 = ss(5,3) OrElse si50 = ss(5,4) OrElse _
      si50 = ss(5,5) OrElse si50 = ss(5,6) OrElse si50 = ss(5,7) OrElse si50 = ss(5,8) OrElse _
      si50 = ss(0,0) OrElse si50 = ss(1,0) OrElse si50 = ss(2,0) OrElse si50 = ss(3,0) OrElse _
      si50 = ss(4,0) OrElse si50 = ss(6,0) OrElse si50 = ss(7,0) OrElse si50 = ss(8,0) OrElse _
      si50 = ss(3,1) OrElse si50 = ss(3,2) OrElse si50 = ss(4,1) OrElse si50 = ss(4,2) Then GoTo si50
   ss(5,0) = si50
 Else
   If Go_up = True Then GoTo si48
 End If
si51:
 If si(5,1) = 0 Then
   Go_up = False
   si51 = si51 + 1
   If si51 > 9 Then
     si51 = 0
     ss(5,1) = 0
     Go_up = True
     GoTo si50
   End If
   If si51 = ss(5,0) OrElse si51 = ss(5,2) OrElse si51 = ss(5,3) OrElse si51 = ss(5,4) OrElse _
      si51 = ss(5,5) OrElse si51 = ss(5,6) OrElse si51 = ss(5,7) OrElse si51 = ss(5,8) OrElse _
      si51 = ss(0,1) OrElse si51 = ss(1,1) OrElse si51 = ss(2,1) OrElse si51 = ss(3,1) OrElse _
      si51 = ss(4,1) OrElse si51 = ss(6,1) OrElse si51 = ss(7,1) OrElse si51 = ss(8,1) OrElse _
      si51 = ss(3,0) OrElse si51 = ss(3,2) OrElse si51 = ss(4,0) OrElse si51 = ss(4,2) Then GoTo si51
   ss(5,1) = si51
 Else
   If Go_up = True Then GoTo si50
 End If
si52:
 If si(5,2) = 0 Then
   Go_up = False
   si52 = si52 + 1
   If si52 > 9 Then
     si52 = 0
     ss(5,2) = 0
     Go_up = True
     GoTo si51
   End If
   If si52 = ss(5,0) OrElse si52 = ss(5,1) OrElse si52 = ss(5,3) OrElse si52 = ss(5,4) OrElse _
      si52 = ss(5,5) OrElse si52 = ss(5,6) OrElse si52 = ss(5,7) OrElse si52 = ss(5,8) OrElse _
      si52 = ss(0,2) OrElse si52 = ss(1,2) OrElse si52 = ss(2,2) OrElse si52 = ss(3,2) OrElse _
      si52 = ss(4,2) OrElse si52 = ss(6,2) OrElse si52 = ss(7,2) OrElse si52 = ss(8,2) OrElse _
      si52 = ss(3,0) OrElse si52 = ss(3,1) OrElse si52 = ss(4,0) OrElse si52 = ss(4,1) Then GoTo si52
   ss(5,2) = si52
 Else
   If Go_up = True Then GoTo si51
 End If
si53:
 If si(5,3) = 0 Then
   Go_up = False
   si53 = si53 + 1
   If si53 > 9 Then
     si53 = 0
     ss(5,3) = 0
     Go_up = True
     GoTo si52
   End If
   If si53 = ss(5,0) OrElse si53 = ss(5,1) OrElse si53 = ss(5,2) OrElse si53 = ss(5,4) OrElse _
      si53 = ss(5,5) OrElse si53 = ss(5,6) OrElse si53 = ss(5,7) OrElse si53 = ss(5,8) OrElse _
      si53 = ss(0,3) OrElse si53 = ss(1,3) OrElse si53 = ss(2,3) OrElse si53 = ss(3,3) OrElse _
      si53 = ss(4,3) OrElse si53 = ss(6,3) OrElse si53 = ss(7,3) OrElse si53 = ss(8,3) OrElse _
      si53 = ss(0,8) OrElse si53 = ss(1,7) OrElse si53 = ss(2,6) OrElse _
      si53 = ss(6,2) OrElse si53 = ss(7,1) OrElse si53 = ss(8,0) OrElse _
      si53 = ss(3,4) OrElse si53 = ss(3,5) OrElse si53 = ss(4,4) OrElse si53 = ss(4,5) Then GoTo si53
   ss(5,3) = si53
 Else
   If Go_up = True Then GoTo si52
 End If
si54:
 If si(5,4) = 0 Then
   Go_up = False
   si54 = si54 + 1
   If si54 > 9 Then
     si54 = 0
     ss(5,4) = 0
     Go_up = True
     GoTo si53
   End If
   If si54 = ss(5,0) OrElse si54 = ss(5,1) OrElse si54 = ss(5,2) OrElse si54 = ss(5,3) OrElse _
      si54 = ss(5,5) OrElse si54 = ss(5,6) OrElse si54 = ss(5,7) OrElse si54 = ss(5,8) OrElse _
      si54 = ss(0,4) OrElse si54 = ss(1,4) OrElse si54 = ss(2,4) OrElse si54 = ss(3,4) OrElse _
      si54 = ss(4,4) OrElse si54 = ss(6,4) OrElse si54 = ss(7,4) OrElse si54 = ss(8,4) OrElse _
      si54 = ss(3,3) OrElse si54 = ss(3,5) OrElse si54 = ss(4,3) OrElse si54 = ss(4,5) Then GoTo si54
   ss(5,4) = si54
 Else
   If Go_up = True Then GoTo si53
 End If
si55:
 If si(5,5) = 0 Then
   Go_up = False
   si55 = si55 + 1
   If si55 > 9 Then
     si55 = 0
     ss(5,5) = 0
     Go_up = True
     GoTo si54
   End If
   If si55 = ss(5,0) OrElse si55 = ss(5,1) OrElse si55 = ss(5,2) OrElse si55 = ss(5,3) OrElse _
      si55 = ss(5,4) OrElse si55 = ss(5,6) OrElse si55 = ss(5,7) OrElse si55 = ss(5,8) OrElse _
      si55 = ss(0,5) OrElse si55 = ss(1,5) OrElse si55 = ss(2,5) OrElse si55 = ss(3,5) OrElse _
      si55 = ss(4,5) OrElse si55 = ss(6,5) OrElse si55 = ss(7,5) OrElse si55 = ss(8,5) OrElse _
      si55 = ss(0,0) OrElse si55 = ss(1,1) OrElse si55 = ss(2,2) OrElse _
      si55 = ss(6,6) OrElse si55 = ss(7,7) OrElse si55 = ss(8,8) OrElse _
      si55 = ss(3,3) OrElse si55 = ss(3,4) OrElse si55 = ss(4,3) OrElse si55 = ss(4,4) Then GoTo si55
   ss(5,5) = si55
 Else
   If Go_up = True Then GoTo si54
 End If
si56:
 If si(5,6) = 0 Then
   Go_up = False
   si56 = si56 + 1
   If si56 > 9 Then
     si56 = 0
     ss(5,6) = 0
     Go_up = True
     GoTo si55
   End If
   If si56 = ss(5,0) OrElse si56 = ss(5,1) OrElse si56 = ss(5,2) OrElse si56 = ss(5,3) OrElse _
      si56 = ss(5,4) OrElse si56 = ss(5,5) OrElse si56 = ss(5,7) OrElse si56 = ss(5,8) OrElse _
      si56 = ss(0,6) OrElse si56 = ss(1,6) OrElse si56 = ss(2,6) OrElse si56 = ss(3,6) OrElse _
      si56 = ss(4,6) OrElse si56 = ss(6,6) OrElse si56 = ss(7,6) OrElse si56 = ss(8,6) OrElse _
      si56 = ss(3,7) OrElse si56 = ss(3,8) OrElse si56 = ss(4,7) OrElse si56 = ss(4,8) Then GoTo si56
   ss(5,6) = si56
 Else
   If Go_up = True Then GoTo si55
 End If
si57:
 If si(5,7) = 0 Then
   Go_up = False
   si57 = si57 + 1
   If si57 > 9 Then
     si57 = 0
     ss(5,7) = 0
     Go_up = True
     GoTo si56
   End If
   If si57 = ss(5,0) OrElse si57 = ss(5,1) OrElse si57 = ss(5,2) OrElse si57 = ss(5,3) OrElse _
      si57 = ss(5,4) OrElse si57 = ss(5,5) OrElse si57 = ss(5,6) OrElse si57 = ss(5,8) OrElse _
      si57 = ss(0,7) OrElse si57 = ss(1,7) OrElse si57 = ss(2,7) OrElse si57 = ss(3,7) OrElse _
      si57 = ss(4,7) OrElse si57 = ss(6,7) OrElse si57 = ss(7,7) OrElse si57 = ss(8,7) OrElse _
      si57 = ss(3,6) OrElse si57 = ss(3,8) OrElse si57 = ss(4,6) OrElse si57 = ss(4,8) Then GoTo si57
   ss(5,7) = si57
 Else
   If Go_up = True Then GoTo si56
 End If
si58:
 If si(5,8) = 0 Then
   Go_up = False
   si58 = si58 + 1
   If si58 > 9 Then
     si58 = 0
     ss(5,8) = 0
     Go_up = True
     GoTo si57
   End If
   If si58 = ss(5,0) OrElse si58 = ss(5,1) OrElse si58 = ss(5,2) OrElse si58 = ss(5,3) OrElse _
      si58 = ss(5,4) OrElse si58 = ss(5,5) OrElse si58 = ss(5,6) OrElse si58 = ss(5,7) OrElse _
      si58 = ss(0,8) OrElse si58 = ss(1,8) OrElse si58 = ss(2,8) OrElse si58 = ss(3,8) OrElse _
      si58 = ss(4,8) OrElse si58 = ss(6,8) OrElse si58 = ss(7,8) OrElse si58 = ss(8,8) OrElse _
      si58 = ss(3,6) OrElse si58 = ss(3,7) OrElse si58 = ss(4,6) OrElse si58 = ss(4,7) Then GoTo si58
   ss(5,8) = si58
 Else
   If Go_up = True Then GoTo si57
 End If
si60:
 If si(6,0) = 0 Then
   Go_up = False
   si60 = si60 + 1
   If si60 > 9 Then
     si60 = 0
     ss(6,0) = 0
     Go_up = True
     GoTo si58
   End If
   If si60 = ss(6,1) OrElse si60 = ss(6,2) OrElse si60 = ss(6,3) OrElse si60 = ss(6,4) OrElse _
      si60 = ss(6,5) OrElse si60 = ss(6,6) OrElse si60 = ss(6,7) OrElse si60 = ss(6,8) OrElse _
      si60 = ss(0,0) OrElse si60 = ss(1,0) OrElse si60 = ss(2,0) OrElse si60 = ss(3,0) OrElse _
      si60 = ss(4,0) OrElse si60 = ss(5,0) OrElse si60 = ss(7,0) OrElse si60 = ss(8,0) OrElse _
      si60 = ss(7,1) OrElse si60 = ss(7,2) OrElse si60 = ss(8,1) OrElse si60 = ss(8,2) Then GoTo si60
   ss(6,0) = si60
 Else
   If Go_up = True Then GoTo si58
 End If
si61:
 If si(6,1) = 0 Then
   Go_up = False
   si61 = si61 + 1
   If si61 > 9 Then
     si61 = 0
     ss(6,1) = 0
     Go_up = True
     GoTo si60
   End If
   If si61 = ss(6,0) OrElse si61 = ss(6,2) OrElse si61 = ss(6,3) OrElse si61 = ss(6,4) OrElse _
      si61 = ss(6,5) OrElse si61 = ss(6,6) OrElse si61 = ss(6,7) OrElse si61 = ss(6,8) OrElse _
      si61 = ss(0,1) OrElse si61 = ss(1,1) OrElse si61 = ss(2,1) OrElse si61 = ss(3,1) OrElse _
      si61 = ss(4,1) OrElse si61 = ss(5,1) OrElse si61 = ss(7,1) OrElse si61 = ss(8,1) OrElse _
      si61 = ss(7,0) OrElse si61 = ss(7,2) OrElse si61 = ss(8,0) OrElse si61 = ss(8,2) Then GoTo si61
   ss(6,1) = si61
 Else
   If Go_up = True Then GoTo si60
 End If
si62:
 If si(6,2) = 0 Then
   Go_up = False
   si62 = si62 + 1
   If si62 > 9 Then
     si62 = 0
     ss(6,2) = 0
     Go_up = True
     GoTo si61
   End If
   If si62 = ss(6,0) OrElse si62 = ss(6,1) OrElse si62 = ss(6,3) OrElse si62 = ss(6,4) OrElse _
      si62 = ss(6,5) OrElse si62 = ss(6,6) OrElse si62 = ss(6,7) OrElse si62 = ss(6,8) OrElse _
      si62 = ss(0,2) OrElse si62 = ss(1,2) OrElse si62 = ss(2,2) OrElse si62 = ss(3,2) OrElse _
      si62 = ss(4,2) OrElse si62 = ss(5,2) OrElse si62 = ss(7,2) OrElse si62 = ss(8,2) OrElse _
      si62 = ss(0,8) OrElse si62 = ss(1,7) OrElse si62 = ss(2,6) OrElse _
      si62 = ss(3,5) OrElse si62 = ss(4,4) OrElse si62 = ss(5,3) OrElse _
      si62 = ss(7,0) OrElse si62 = ss(7,1) OrElse si62 = ss(8,0) OrElse si62 = ss(8,1) Then GoTo si62
   ss(6,2) = si62
 Else
   If Go_up = True Then GoTo si61
 End If
si63:
 If si(6,3) = 0 Then
   Go_up = False
   si63 = si63 + 1
   If si63 > 9 Then
     si63 = 0
     ss(6,3) = 0
     Go_up = True
     GoTo si62
   End If
   If si63 = ss(6,0) OrElse si63 = ss(6,1) OrElse si63 = ss(6,2) OrElse si63 = ss(6,4) OrElse _
      si63 = ss(6,5) OrElse si63 = ss(6,6) OrElse si63 = ss(6,7) OrElse si63 = ss(6,8) OrElse _
      si63 = ss(0,3) OrElse si63 = ss(1,3) OrElse si63 = ss(2,3) OrElse si63 = ss(3,3) OrElse _
      si63 = ss(4,3) OrElse si63 = ss(5,3) OrElse si63 = ss(7,3) OrElse si63 = ss(8,3) OrElse _
      si63 = ss(7,4) OrElse si63 = ss(7,5) OrElse si63 = ss(8,4) OrElse si63 = ss(8,5) Then GoTo si63
   ss(6,3) = si63
 Else
   If Go_up = True Then GoTo si62
 End If
si64:
 If si(6,4) = 0 Then
   Go_up = False
   si64 = si64 + 1
   If si64 > 9 Then
     si64 = 0
     ss(6,4) = 0
     Go_up = True
     GoTo si63
   End If
   If si64 = ss(6,0) OrElse si64 = ss(6,1) OrElse si64 = ss(6,2) OrElse si64 = ss(6,3) OrElse _
      si64 = ss(6,5) OrElse si64 = ss(6,6) OrElse si64 = ss(6,7) OrElse si64 = ss(6,8) OrElse _
      si64 = ss(0,4) OrElse si64 = ss(1,4) OrElse si64 = ss(2,4) OrElse si64 = ss(3,4) OrElse _
      si64 = ss(4,4) OrElse si64 = ss(5,4) OrElse si64 = ss(7,4) OrElse si64 = ss(8,4) OrElse _
      si64 = ss(7,3) OrElse si64 = ss(7,5) OrElse si64 = ss(8,3) OrElse si64 = ss(8,5) Then GoTo si64
   ss(6,4) = si64
 Else
   If Go_up = True Then GoTo si63
 End If
si65:
 If si(6,5) = 0 Then
   Go_up = False
   si65 = si65 + 1
   If si65 > 9 Then
     si65 = 0
     ss(6,5) = 0
     Go_up = True
     GoTo si64
   End If
   If si65 = ss(6,0) OrElse si65 = ss(6,1) OrElse si65 = ss(6,2) OrElse si65 = ss(6,3) OrElse _
      si65 = ss(6,4) OrElse si65 = ss(6,6) OrElse si65 = ss(6,7) OrElse si65 = ss(6,8) OrElse _
      si65 = ss(0,5) OrElse si65 = ss(1,5) OrElse si65 = ss(2,5) OrElse si65 = ss(3,5) OrElse _
      si65 = ss(4,5) OrElse si65 = ss(5,5) OrElse si65 = ss(7,5) OrElse si65 = ss(8,5) OrElse _
      si65 = ss(7,3) OrElse si65 = ss(7,4) OrElse si65 = ss(8,3) OrElse si65 = ss(8,4) Then GoTo si65
   ss(6,5) = si65
 Else
 End If
si66:
 If si(6,6) = 0 Then
   Go_up = False
   si66 = si66 + 1
   If si66 > 9 Then
     si66 = 0
     ss(6,6) = 0
     Go_up = True
     GoTo si65
   End If
      si66 = ss(0,0) OrElse si66 = ss(1,1) OrElse si66 = ss(2,2) OrElse _
      si66 = ss(3,3) OrElse si66 = ss(4,4) OrElse si66 = ss(5,5) OrElse _
   ss(6,6) = si66
 Else
 End If
si67:
 If si(6,7) = 0 Then
   Go_up = False
   si67 = si67 + 1
   If si67 > 9 Then
     si67 = 0
     ss(6,7) = 0
     Go_up = True
     GoTo si66
   End If
   ss(6,7) = si67
 Else
 End If
si68:
 If si(6,8) = 0 Then
   Go_up = False
   si68 = si68 + 1
   If si68 > 9 Then
     si68 = 0
     ss(6,8) = 0
     Go_up = True
     GoTo si67
   End If
   ss(6,8) = si68
 Else
 End If
si70:
 If si(7,0) = 0 Then
   Go_up = False
   si70 = si70 + 1
   If si70 > 9 Then
     si70 = 0
     ss(7,0) = 0
     Go_up = True
     GoTo si68
   End If
   ss(7,0) = si70
 Else
 End If
si71:
 If si(7,1) = 0 Then
   Go_up = False
   si71 = si71 + 1
   If si71 > 9 Then
     si71 = 0
     ss(7,1) = 0
     Go_up = True
     GoTo si70
   End If
      si71 = ss(0,8) OrElse si71 = ss(1,7) OrElse si71 = ss(2,6) OrElse _
      si71 = ss(3,5) OrElse si71 = ss(4,4) OrElse si71 = ss(5,3) OrElse _
   ss(7,1) = si71
 Else
 End If
si72:
 If si(7,2) = 0 Then
   Go_up = False
   si72 = si72 + 1
   If si72 > 9 Then
     si72 = 0
     ss(7,2) = 0
     Go_up = True
     GoTo si71
   End If
   ss(7,2) = si72
 Else
 End If
si73:
 If si(7,3) = 0 Then
   Go_up = False
   si73 = si73 + 1
   If si73 > 9 Then
     si73 = 0
     ss(7,3) = 0
     Go_up = True
     GoTo si72
   End If
   ss(7,3) = si73
 Else
 End If
si74:
 If si(7,4) = 0 Then
   Go_up = False
   si74 = si74 + 1
   If si74 > 9 Then
     si74 = 0
     ss(7,4) = 0
     Go_up = True
     GoTo si73
   End If
   ss(7,4) = si74
 Else
 End If
si75:
 If si(7,5) = 0 Then
   Go_up = False
   si75 = si75 + 1
   If si75 > 9 Then
     si75 = 0
     ss(7,5) = 0
     Go_up = True
     GoTo si74
   End If
   ss(7,5) = si75
 Else
 End If
si76:
 If si(7,6) = 0 Then
   Go_up = False
   si76 = si76 + 1
   If si76 > 9 Then
     si76 = 0
     ss(7,6) = 0
     Go_up = True
     GoTo si75
   End If
   ss(7,6) = si76
 Else
 End If
si77:
 If si(7,7) = 0 Then
   Go_up = False
   si77 = si77 + 1
   If si77 > 9 Then
     si77 = 0
     ss(7,7) = 0
     Go_up = True
     GoTo si76
   End If
      si77 = ss(0,0) OrElse si77 = ss(1,1) OrElse si77 = ss(2,2) OrElse _
      si77 = ss(3,3) OrElse si77 = ss(4,4) OrElse si77 = ss(5,5) OrElse _
   ss(7,7) = si77
 Else
 End If
si78:
 If si(7,8) = 0 Then
   Go_up = False
   si78 = si78 + 1
   If si78 > 9 Then
     si78 = 0
     ss(7,8) = 0
     Go_up = True
     GoTo si77
   End If
   ss(7,8) = si78
 Else
 End If
si80:
 If si(8,0) = 0 Then
   Go_up = False
   si80 = si80 + 1
   If si80 > 9 Then
     si80 = 0
     ss(8,0) = 0
     Go_up = True
     GoTo si78
   End If
      si80 = ss(0,8) OrElse si80 = ss(1,7) OrElse si80 = ss(2,6) OrElse _
      si80 = ss(3,5) OrElse si80 = ss(4,4) OrElse si80 = ss(5,3) OrElse _
   ss(8,0) = si80
 Else
 End If
si81:
 If si(8,1) = 0 Then
   Go_up = False
   si81 = si81 + 1
   If si81 > 9 Then
     si81 = 0
     ss(8,1) = 0
     Go_up = True
     GoTo si80
   End If
   ss(8,1) = si81
 Else
 End If
si82:
 If si(8,2) = 0 Then
   Go_up = False
   si82 = si82 + 1
   If si82 > 9 Then
     si82 = 0
     ss(8,2) = 0
     Go_up = True
     GoTo si81
   End If
   ss(8,2) = si82
 Else
 End If
si83:
 If si(8,3) = 0 Then
   Go_up = False
   si83 = si83 + 1
   If si83 > 9 Then
     si83 = 0
     ss(8,3) = 0
     Go_up = True
     GoTo si82
   End If
   ss(8,3) = si83
 Else
 End If
si84:
 If si(8,4) = 0 Then
   Go_up = False
   si84 = si84 + 1
   If si84 > 9 Then
     si84 = 0
     ss(8,4) = 0
     Go_up = True
     GoTo si83
   End If
   ss(8,4) = si84
 Else
 End If
si85:
 If si(8,5) = 0 Then
   Go_up = False
   si85 = si85 + 1
   If si85 > 9 Then
     si85 = 0
     ss(8,5) = 0
     Go_up = True
     GoTo si84
   End If
   ss(8,5) = si85
 Else
 End If
si86:
 If si(8,6) = 0 Then
   Go_up = False
   si86 = si86 + 1
   If si86 > 9 Then
     si86 = 0
     ss(8,6) = 0
     Go_up = True
     GoTo si85
   End If
   ss(8,6) = si86
 Else
 End If
si87:
 If si(8,7) = 0 Then
   Go_up = False
   si87 = si87 + 1
   If si87 > 9 Then
     si87 = 0
     ss(8,7) = 0
     Go_up = True
     GoTo si86
   End If
   ss(8,7) = si87
 Else
 End If
si88:
 If si(8,8) = 0 Then
   Go_up = False
   si88 = si88 + 1
   If si88 > 9 Then
     si88 = 0
     ss(8,8) = 0
     Go_up = True
     GoTo si87
   End If
      si88 = ss(0,0) OrElse si88 = ss(1,1) OrElse si88 = ss(2,2) OrElse _
      si88 = ss(3,3) OrElse si88 = ss(4,4) OrElse si88 = ss(5,5) OrElse _
   ss(8,8) = si88
 Else
 End If
  End If
  lw.WriteLine("")
  lw.WriteLine("")
  lw.WriteLine("")
  lw.WriteLine("Diagonal Sudoku 9x9 App")
   TimerFlag = False
  End If
  Go_up = True
  GoTo si88
 End Sub
 Function valid_check( ByRef ss(,) As Integer ) As Boolean
  Dim r,c As Integer
  Dim j As Integer
  Dim k As Integer
  Dim f As Integer
  Dim b(8,8) As Integer
  b(0,0)=ss(0,0):b(0,1)=ss(0,1):b(0,2)=ss(0,2):b(0,3)=ss(1,0):b(0,4)=ss(1,1):b(0,5)=ss(1,2):b(0,6)=ss(2,0):b(0,7)=ss(2,1):b(0,8)=ss(2,2)
  b(1,0)=ss(0,3):b(1,1)=ss(0,4):b(1,2)=ss(0,5):b(1,3)=ss(1,3):b(1,4)=ss(1,4):b(1,5)=ss(1,5):b(1,6)=ss(2,3):b(1,7)=ss(2,4):b(1,8)=ss(2,5)
  b(2,0)=ss(0,6):b(2,1)=ss(0,7):b(2,2)=ss(0,8):b(2,3)=ss(1,6):b(2,4)=ss(1,7):b(2,5)=ss(1,8):b(2,6)=ss(2,6):b(2,7)=ss(2,7):b(2,8)=ss(2,8)
  b(3,0)=ss(3,0):b(3,1)=ss(3,1):b(3,2)=ss(3,2):b(3,3)=ss(4,0):b(3,4)=ss(4,1):b(3,5)=ss(4,2):b(3,6)=ss(5,0):b(3,7)=ss(5,1):b(3,8)=ss(5,2)
  b(4,0)=ss(3,3):b(4,1)=ss(3,4):b(4,2)=ss(3,5):b(4,3)=ss(4,3):b(4,4)=ss(4,4):b(4,5)=ss(4,5):b(4,6)=ss(5,3):b(4,7)=ss(5,4):b(4,8)=ss(5,5)
  b(5,0)=ss(3,6):b(5,1)=ss(3,7):b(5,2)=ss(3,8):b(5,3)=ss(4,6):b(5,4)=ss(4,7):b(5,5)=ss(4,8):b(5,6)=ss(5,6):b(5,7)=ss(5,7):b(5,8)=ss(5,8)
  b(6,0)=ss(6,0):b(6,1)=ss(6,1):b(6,2)=ss(6,2):b(6,3)=ss(7,0):b(6,4)=ss(7,1):b(6,5)=ss(7,2):b(6,6)=ss(8,0):b(6,7)=ss(8,1):b(6,8)=ss(8,2)
  b(7,0)=ss(6,3):b(7,1)=ss(6,4):b(7,2)=ss(6,5):b(7,3)=ss(7,3):b(7,4)=ss(7,4):b(7,5)=ss(7,5):b(7,6)=ss(8,3):b(7,7)=ss(8,4):b(7,8)=ss(8,5)
  b(8,0)=ss(6,6):b(8,1)=ss(6,7):b(8,2)=ss(6,8):b(8,3)=ss(7,6):b(8,4)=ss(7,7):b(8,5)=ss(7,8):b(8,6)=ss(8,6):b(8,7)=ss(8,7):b(8,8)=ss(8,8)
  For r = 0 To 8
    For c = 0 To 8
      f = 0
      If ss(r,c)<> 0 Then
        f = 0
        For j = 0 To 8
          If j = r Then Continue For
          If ss(j,c)<>ss(r,c) Then Continue For
          f = 1
        Next
        If f = 1 Then Return False
        f = 0
        For j = 0 To 8
          If j = c Then Continue For
          If ss(r,j)<>ss(r,c) Then Continue For
          f = 1
        Next
      End If
    Next
  Next
  For r = 0 To 8
    For c = 0 To 8
      If b(r,c)<> 0 Then
        f = 0
        For j = 0 To 8
          If b(r,c)<>b(r,j) Then Continue For
          f = 1
        Next
      End If
    Next
  Next
  Return True
 End Function
End Class
RE: NX Journal and Block UI Styler combination
Hi, thank you both for the reply.
Your block styler code which was given is greatly appreciated.
I've come up with the following code :
// WARNING!! This file is overwritten by the Block UI Styler while generating
// the automation code. Any modifications to this file will be lost after
// generating the code again.
// Filename: C:\Users\MTS PG 6\Desktop\BlockDialog2.cs
// This file was generated by the NX Block UI Styler
// Created by: MTS PG 6
// Version: NX 10
// Date: 04-21-2017 (Format: mm-dd-yyyy)
// Time: 11:20 (Format: hh-mm)
// Purpose: This TEMPLATE file contains C# source to guide you in the
// construction of your Block application dialog. The generation of your
// dialog file (.dlx extension) is the first step towards dialog construction
// within NX. You must now create a NX Open application that
// utilizes this file (.dlx).
// The information in this file provides you with the following:
// 1. Help on how to load and display your Block UI Styler dialog in NX
// using APIs provided in NXOpen.BlockStyler namespace
// 2. The empty callback methods (stubs) associated with your dialog items
// have also been placed in this file. These empty methods have been
// created simply to start you along with your coding requirements.
// The method name, argument list and possible return values have already
// been provided for you.
//These imports are needed for the following template code
using System;
using NXOpen;
using NXOpen.BlockStyler;
//Represents Block Styler application class
public class BlockDialog2
//class members
private static Session theSession = null;
private static UI theUI = null;
private string theDlxFileName;
private NXOpen.BlockStyler.BlockDialog theDialog;
private NXOpen.BlockStyler.Group group0;// Block type: Group
private NXOpen.BlockStyler.IntegerBlock integer0;// Block type: Integer
private NXOpen.BlockStyler.IntegerBlock integer01;// Block type: Integer
private NXOpen.BlockStyler.IntegerBlock integer02;// Block type: Integer
private NXOpen.BlockStyler.Group group01;// Block type: Group
private NXOpen.BlockStyler.LinearDimension linear_dim0;// Block type: Linear Dim
private NXOpen.BlockStyler.LinearDimension linear_dim01;// Block type: Linear Dim
private NXOpen.BlockStyler.LinearDimension linear_dim02;// Block type: Linear Dim
//Bit Option for Property: SnapPointTypesOnByDefault
public static readonly int SnapPointTypesOnByDefault_UserDefined = (1 << 0);
public static readonly int SnapPointTypesOnByDefault_Inferred = (1 << 1);
public static readonly int SnapPointTypesOnByDefault_ScreenPosition = (1 << 2);
public static readonly int SnapPointTypesOnByDefault_EndPoint = (1 << 3);
public static readonly int SnapPointTypesOnByDefault_MidPoint = (1 << 4);
public static readonly int SnapPointTypesOnByDefault_ControlPoint = (1 << 5);
public static readonly int SnapPointTypesOnByDefault_Intersection = (1 << 6);
public static readonly int SnapPointTypesOnByDefault_ArcCenter = (1 << 7);
public static readonly int SnapPointTypesOnByDefault_QuadrantPoint = (1 << 8);
public static readonly int SnapPointTypesOnByDefault_ExistingPoint = (1 << 9);
public static readonly int SnapPointTypesOnByDefault_PointonCurve = (1 <<10);
public static readonly int SnapPointTypesOnByDefault_PointonSurface = (1 <<11);
public static readonly int SnapPointTypesOnByDefault_PointConstructor = (1 <<12);
public static readonly int SnapPointTypesOnByDefault_TwocurveIntersection = (1 <<13);
public static readonly int SnapPointTypesOnByDefault_TangentPoint = (1 <<14);
public static readonly int SnapPointTypesOnByDefault_Poles = (1 <<15);
public static readonly int SnapPointTypesOnByDefault_BoundedGridPoint = (1 <<16);
public static readonly int SnapPointTypesOnByDefault_FacetVertexPoint = (1 <<17);
//Constructor for NX Styler class
public BlockDialog2()
try
theSession = Session.GetSession();
theUI = UI.GetUI();
theDlxFileName = "BlockDialog2.dlx";
theDialog = theUI.CreateDialog(theDlxFileName);
theDialog.AddApplyHandler(new NXOpen.BlockStyler.BlockDialog.Apply(apply_cb));
theDialog.AddOkHandler(new NXOpen.BlockStyler.BlockDialog.Ok(ok_cb));
theDialog.AddUpdateHandler(new NXOpen.BlockStyler.BlockDialog.Update(update_cb));
theDialog.AddInitializeHandler(new NXOpen.BlockStyler.BlockDialog.Initialize(initialize_cb));
theDialog.AddDialogShownHandler(new NXOpen.BlockStyler.BlockDialog.DialogShown(dialogShown_cb));
catch (Exception ex)
//---- Enter your exception handling code here -----
throw ex;
//------------------------------- DIALOG LAUNCHING ---------------------------------
// Before invoking this application one needs to open any part/empty part in NX
// because of the behavior of the blocks.
// Make sure the dlx file is in one of the following locations:
// 1.) From where NX session is launched
// 2.) $UGII_USER_DIR/application
// 3.) For released applications, using UGII_CUSTOM_DIRECTORY_FILE is highly
// recommended. This variable is set to a full directory path to a file
// containing a list of root directories for all custom applications.
// e.g., UGII_CUSTOM_DIRECTORY_FILE=$UGII_ROOT_DIR\menus\custom_dirs.dat
// You can create the dialog using one of the following way:
// 1. Journal Replay
// 1) Replay this file through Tool->Journal->Play Menu.
// 2. USER EXIT
// 1) Create the Shared Library -- Refer "Block UI Styler programmer's guide"
// 2) Invoke the Shared Library through File->Execute->NX Open menu.
public static void Main()
BlockDialog2 theBlockDialog2 = null;
try
theBlockDialog2 = new BlockDialog2();
// The following method shows the dialog immediately
theBlockDialog2.Show();
theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString());
finally
if(theBlockDialog2 != null)
theBlockDialog2.Dispose();
// This method specifies how a shared image is unloaded from memory
// within NX. This method gives you the capability to unload an
// internal NX Open application or user exit from NX. Specify any
// one of the three constants as a return value to determine the type
// of unload to perform:
// Immediately : unload the library as soon as the automation program has completed
// Explicitly : unload the library from the "Unload Shared Image" dialog
// AtTermination : unload the library when the NX session terminates
// NOTE: A program which associates NX Open applications with the menubar
// MUST NOT use this option since it will UNLOAD your NX Open application image
// from the menubar.
public static int GetUnloadOption(string arg)
//return System.Convert.ToInt32(Session.LibraryUnloadOption.Explicitly);
return System.Convert.ToInt32(Session.LibraryUnloadOption.Immediately);
// return System.Convert.ToInt32(Session.LibraryUnloadOption.AtTermination);
// Following method cleanup any housekeeping chores that may be needed.
// This method is automatically called by NX.
public static void UnloadLibrary(string arg)
try
//---- Enter your code here -----
//This method shows the dialog on the screen
public NXOpen.UIStyler.DialogResponse Show()
try
theDialog.Show();
return 0;
//Method Name: Dispose
public void Dispose()
if(theDialog != null)
theDialog.Dispose();
theDialog = null;
//---------------------Block UI Styler Callback Functions--------------------------
//Callback Name: initialize_cb
public void initialize_cb()
try
group0 = (NXOpen.BlockStyler.Group)theDialog.TopBlock.FindBlock("group0");
integer0 = (NXOpen.BlockStyler.IntegerBlock)theDialog.TopBlock.FindBlock("integer0");
integer01 = (NXOpen.BlockStyler.IntegerBlock)theDialog.TopBlock.FindBlock("integer01");
integer02 = (NXOpen.BlockStyler.IntegerBlock)theDialog.TopBlock.FindBlock("integer02");
group01 = (NXOpen.BlockStyler.Group)theDialog.TopBlock.FindBlock("group01");
linear_dim0 = (NXOpen.BlockStyler.LinearDimension)theDialog.TopBlock.FindBlock("linear_dim0");
linear_dim01 = (NXOpen.BlockStyler.LinearDimension)theDialog.TopBlock.FindBlock("linear_dim01");
linear_dim02 = (NXOpen.BlockStyler.LinearDimension)theDialog.TopBlock.FindBlock("linear_dim02");
//Callback Name: dialogShown_cb
//This callback is executed just before the dialog launch. Thus any value set
//here will take precedence and dialog will be launched showing that value.
public void dialogShown_cb()
try
//Callback Name: apply_cb
public int apply_cb()
int errorCode = 0;
try
string[] coOrds = new string[3];
coOrds[0] = linear_dim0.ToString(); // Dimension Values
coOrds[1] = linear_dim01.ToString(); // Dimension Values
coOrds[2] = linear_dim02.ToString(); // Dimension Values
CreateBlock(coOrds);
//double[] dimension = new string[3];
//dimension[0] = (string)linear_dim0.ToString(); // attempt fail
//dimension[1] = (string)linear_dim01.ToString(); // attempt fail
//dimension[2] = (string)linear_dim02.ToString(); // attempt fail
//dimension[0] = (string)linear_dim0.Value(); // attempt fail
//dimension[1] = (string)linear_dim01.Value(); // attempt fail
//dimension[2] = (string)linear_dim01.Value(); // attempt fail
//string expression = dimension[0].ToString(); // attempt fail
//string expression = dimension[1].ToString(); // attempt fail
//string expression = dimension[2].ToString(); // attempt fail
errorCode = 1;
return errorCode;
//Callback Name: update_cb
public int update_cb( NXOpen.BlockStyler.UIBlock block)
try
if(block == integer0)
else if(block == integer01)
else if(block == integer02)
else if(block == linear_dim0)
else if(block == linear_dim01)
else if(block == linear_dim02)
return 0;
//Callback Name: ok_cb
public int ok_cb()
int errorCode = 0;
try
errorCode = apply_cb();
//---- Enter your callback code here -----
errorCode = 1;
return errorCode;
//Function Name: GetBlockProperties
//Returns the propertylist of the specified BlockID
public PropertyList GetBlockProperties(string blockID)
PropertyList plist =null;
try
plist = theDialog.GetBlockProperties(blockID);
return plist;
public void CreateBlock(string[] coOrds)
NXOpen.Session theSession = NXOpen.Session.GetSession();
NXOpen.Part workPart = theSession.Parts.Work;
NXOpen.Part displayPart = theSession.Parts.Display;
NXOpen.Features.Feature nullNXOpen_Features_Feature = null;
NXOpen.Features.BlockFeatureBuilder blockFeatureBuilder1;
blockFeatureBuilder1 = workPart.Features.CreateBlockFeatureBuilder(nullNXOpen_Features_Feature);
NXOpen.Point3d originPoint1 = new NXOpen.Point3d(0, 0, 0);
// blockFeatureBuilder1.SetOriginAndLengths(originPoint1, "100", "100", "100"); // old code
blockFeatureBuilder1.SetOriginAndLengths(originPoint1, coOrds[0], coOrds[1], coOrds[2]);
NXOpen.Features.Feature feature1;
feature1 = blockFeatureBuilder1.CommitFeature();
// Version: NX 10
using System;
using NXOpen;
//class members
try
theUI = UI.GetUI();
throw ex;
// 2. USER EXIT
try
finally
try
try
theDialog.Show();
return 0;
theDialog = null;
try
try
int errorCode = 0;
try
errorCode = 1;
return errorCode;
try
return 0;
public int ok_cb()
int errorCode = 0;
try
errorCode = 1;
return errorCode;
try
return plist;
However, it tells me that block length must be greater then zero, meaning it is not recording and using the value that i've input from the block styler.. what am i doing wrong here?
Thanks in advance !
Cheers
