Troubles with MICOM ALSTOM RELAY COMUNICATION BY IEC 61850 to SIEMENS SCADA
Hi Dear Specialists
I am experimenting troubles, with the integrating of two relays MICOM P40 P643 to Master SCADA SIEMENS, so I need to comunícate MICOM Relays Alstom by using IEC-61850 using media Fibre Optic Redundant card Ethernet.
We have already créate using MCL configurator tool the Data Sets and exported CID file, but SIEMENS Master show Error Comunication Time Out and no show the data set , in spite of using IEC61850 simulator (IEC SCOUT) is showing the data set , I mean the simulator is communicate oK to MICOM without problems.
The data of MICOM Relay are the following P40 Agile 643
P64392NA6M0060M
SER No 33788622/09/16
TEST ID 788622V
DIAG No 10P64301
Please I need urgent assistence fir this matter cause i am at site and coustomer is expecting put in service this sunday
Thank you in advance
Ever
P64392NA6M0060M
TEST ID 788622V
DIAG No 10P64301
Ever
