Minimum Roof Sheathing Thickness
I have a question about the minimum thickness of roof sheathing, and please bear with me, I am self taught on wood design. With reference to the attached tables, it appears as though IBC 2015 limits roof sheathing to 5/8". However, the NDS Supplement diaphragm shear tables only give values up to 19/32" thick? What am I missing? If IBC limits roof sheathing thickness to 5/8", shouldn't the NDS Supplement table start at 5/8" and go up from there (i.e. who cares what the diaphragm shear capacity of 3/8" sheathing if you aren't allowed to use it per IBC)?
RE: Minimum Roof Sheathing Thickness
http://homeguides.sfgate.com/minimum-plywood-roofi...
BA
Mike McCann, PE, SE (WA)
