POST TENSIONED SLAB DESIGN
Hi, In post tensioned slab design, the serviceability requirements(fc<0.6f'c..etc) are applied even if I put reinforcement in the slab?
RE: POST TENSIONED SLAB DESIGN
When it comes to checking flexural tensile stresses at service, the type of slab will determine the extent of allowable flexural tension (eg one-way slab vs flat plate). Some codes refer to class "U", "C" and "T", for uncracked, cracked and transition, other codes have different nomenclature depending on the exposure, type of slab etc.
Strength requirements for minimum bonded reinforcement must also be satisfied.
