Save Failed Modeler error: irrecoverable run-time error
Hi guys,
I am running NX 9.0.2.5. I am having this error message come up every time I try to save this particular file. It allows me to save after running part cleanup sometimes, other times the session just freezes and never comes back after the error message.
What is causing this to pop up? I went though my features and removed all of the associative measures, and unparameterized features that didn't need to be associative, like lines and project curves etc.
There is nothing associative to this file in another external file.
I also attached a picture of the error.
Thanks for the help
Rob
RE: Save Failed Modeler error: irrecoverable run-time error
Report the error to GTAC, they may be able to clean up the file for you.
www.nxjournaling.com
Rob,
Another thing to try might be that if you're working in Native NX (no Teamcenter involved), try opening a new NX file then open the original NX file with which you're having issues (if you have the parametric model, great). Try to copy the solid body and pasting it into the new NX file (which should bring over ALL features if done correctly). It's possible the database within the original model file is corrrupted or something weird. Sometimes this will get rid of oddities like you're having.
You may have to clean up Expressions, etc. if you're anal retentive detail oriented about such things.
Yes, the strikethrough was intended to be humor/slightly poking fun at those of us that can't live with expressions like p1'0'00'000.
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
