Reuse part with excel part library question
In the Progressive Die Wizard module you get a bunch of tabs added to the reuse library. One is PDW false bodies, which allow you to place the false body of a cap screw, select its size and length, then you can use it for subtracting your counter bored hole and link it into the part you are bolting to and subtract the tap dia out of it as well. Works great. I was looking at the excel sheet that it works with and it had attributes listed in there. I was wondering if anyone knows how to use these or where they get placed once you put the reusable feature in the file.
I attached a snippet of the attributes as listed in the excel sheet
Brian Marchand-owner
BRM Design
NX 11.0
16G Ram - Nvidia Quadro K4000
Win 7 Pro x64
