Thermal Fuse for panel heater
Hi – last year a purchased a panel heater but since it has stopped working, I have established that it is the thermal fuse that is gone.
I cannot find on the internet the same fuse, so I need some help to understand these components. Since I cannot find the exact same fuse, I need to figure how I can use an alternative. I can get a 4A fuse with a function temperature of 84°C. As the existing one is set to 65°C will this alternative one be too dangerous to use?
RE: Thermal Fuse for panel heater
http://files.engineering.com/getfile.aspx?folder=f...
http://files.engineering.com/getfile.aspx?folder=b...
Not electrically insulated, some heat shrink can be put over it. The are often used with heat conducting up the leads from a hot terminal. So length is important. The effective temperature can often be raised by making the lead longer than previous. Be sure to heat shrink lead with pliers when soldering to prevent fuse opening up.
Do not be tempted to up-rate the temperature rating of the thermal fuse, it has been chosen carefully by the manufacturer to limit the chance of the appliance catching fire.
I have replaced several of these fuses in coffee pots and the like, and have found that the way that the fuse is installed and the presence of any glass fibre insulation is critical to effecting a lasting repair.
