Piperack Design
Piperack Design
For you guys that design process piperacks and pipe supports.
Do you combine a thermal friction force with wind load? I'm not talking about a thermal anchor just the friction force generated from expansion or contraction of piping prior to pipe slip on a support.
RE: Piperack Design
Find what you like to do, earn a living at it, and then make your lifestyle fit your income. — Chuck Yeager
RE: Piperack Design
RE: Piperack Design
If you look at the new ASCE 7-10 it is more ambiguous than 7-05 when it comes to self-straining loads (See ASCE 7-10 Section 2.3.5). I recently came across a client spec that says to combine friction forces with full wind or seismic. I'm not sure I completely agree with that but I also don't know that I agree that a thermal friction force is temporary. The only way for the force to go away is for the pipe to return to it's original length or for the pipe to slip on the support.
It becomes critical on a t-support because if you consider them acting concurrently, you have biaxial bending of the t-support with a wind force perpendicular to the pipe. That can have an affect on anchor design.
RE: Piperack Design
Structural, Alberta
RE: Piperack Design
www.SlideRuleEra.net
www.VacuumTubeEra.net
RE: Piperack Design
2. I have no idea why this notion still persists that industrial structures in general and pipe racks in particular somehow are a completely separate breed of structure that will not submit to the general statistical analysis that has gone into the development of the ASCE 7 load combinations. I think it has to do with "back in the day" when there were so few applicable standards so structural engineers working for EPC companies - not having a whole lot to do, since actual structural design was forbidden them - created their own standards, and of course these got passed down to the younger guys like the stone tablets of Moses.
But these are MODERN times, guys and gals. A LOT of time and study has gone into the load combos, and I do believe you can use them with confidence!
This is what ASCE 7-10 2.3.5 says:
2.3.5 Load Combinations Including Self-Straining Loads
Where applicable, the structural effects of load T
shall be considered in combination with other loads.
The load factor on load T shall be established considering
the uncertainty associated with the likely
magnitude of the load, the probability that the
maximum effect of T will occur simultaneously with
other applied loadings, and the potential adverse
consequences if the effect of T is greater than
assumed. The load factor on T shall not have a value
less than 1.0.
So what this says, to me, is "be an engineer." That means that if you believe the "self-straining load" will "occur simultaneously with other loads," then include it with an appropriate load factor (I use the load factor associated with Live Load because in my mind, the level of uncertainty is about the same).
Now, think about the typical plant operation, and that the wind event represented by W in your load combination is an EXTREME event. For instance, if you're on an offshore platform, this is a m mother of a hurricane on the way, and the shut down and skedaddle. Same for onshore; no one is going to be operating that plant during a high-wind event.
So the answer is, if you have these events occurring, do not include the Self-Straining Load component in the combination.
Very simple.
"No one is completely useless. He can always serve as a bad example." --My Dad ca. 1975
RE: Piperack Design
1) Thanks for the grammar lesson. Maybe check your spelling as I'm not sure what a paperack is.
2) Where you come from do process plants shut down prior to an earthquake? How about a thunderstorm with 100+ MPH winds?
Wadavis/SlideRuleEra,
That makes sense and I could see the pipe sliding and thus relieving the friction force with wind (or seismic) induced deflections. I was looking for discussion, not some absolute "this is what you should use" type of thing. I kind of thought the requirement to include them both simultaneously was overkill but was curious to what others would use. I think some percentage, maybe 50% of the wind or seismic load could be justified and reasonable.
RE: Piperack Design
Edit: if you do have large enough thermal forces at the top of the T support (assuming the top beam is a W-shape) then don't forget a torsional check...
RE: Piperack Design
DaRooster, This is because generally any good pipe stress design that you would be working with would be placing telfon slide plates, expansion joints, rollers, hangers, or something to allow this expansion without major friction.
Uh... Absolutely NOT! Teflon, rollers, or somethings are not normally used. The best it normally gets is steel pipe shoe sliding on a steel or concrete beam. Special circumstances ONLY. Structural expansion joints are not used in pipe rack design. Independent rack sections separated every 100 ft distribute the growth and contraction to amounts manageable without expansion joints in the structural steel frame. Much more important to consider that when designing long continuous conveyor belt bridges and towers.
TLHS, PIP STC01015 (like all codes and design specs) should be used only as a guide when specific and detailed knowledge and information about concurent loading conditions (or whatever else concerns you) is nonexistant.
SlideRuleEra,
wadavis,
Illbay, (I tend to agree with you, except for shut down load case)
Pipe supports or structures buffeted by wind, or otherwise shifting under the pipe is immaterial. The (maximum) value of any lateral load that can ever be transferred between a pipe simply resting (not welded anchored or guided) on its support is the weight of pipe and contents x friction factor. Thermal loads of the pipe to a support can increase only until &fi;W is reached, then slipping occurs so the load never reaches higher values. Likewise wind acting on pipe, transferring the load to supports below could also not reach values above &fi;W, otherwise the pipe would first move and perhaps even slip off the support. Likewise, wind should also be applied with thermal friction load during shutdown. Once the pipe has shifted on it's support "from wind buffeting" or whatever, to the thermal position, the thermal friction load might be less, however shutdown at that point would simply reverse the thermal friction load as the pipe cooled off to ambient temperature.
Rabbit12 (IMO you are using solid and good logic),
It is obvious to me that such concurrent wind (or seismic) and thermal loading (mentioned in the previous paragraph) can and will occur simultaneously. I think some percentage,50% Thermal loads are "dead" loads, as desing temps are used for design values and thermal effects are relatively well known, easily calculated and their application straight forward. Wind loads are live. Chose appropriate factors when applicable to your material design. In your T support case the 10% W&fi; would not apply, because the one or limited number of pipes would not counteract each other. Use 100% W&fi; for your small limited number of pipes.
RE: Piperack Design
RE: Piperack Design
RE: Piperack Design
RE: Piperack Design
Just so we are clear steel on steel is not an issue. I just recommend that one looks close at those types to understand what the pipe is doing globally. I don't even know what to say yet about the steel sitting on concrete yet...you are correct about the use of Teflon on high energy "hot" systems or sometimes very large "cold" systems. Most pipes that don't have much thought put into them are usually (from what I have experienced) small cold systems and these have almost neglible friction loads...but all that said I think your input is important especially if Rabbit is doing similar work to you. Keep in mind that process designs can cover a wide range of markets.
Edit: That picture is pretty much the same concept as a double column (column bay then another column bay with no connection beam). It's just a break in the pipe rack steel. In my designs those are usually a bit closer together (about 10 feet apart) to account for small bore pipe and not just only large bore. http://www.structuremag.org/wp-content/uploads/201...
Also, here is another link where the term "double column" comes from. Keep in mind that it doesn't define the distance between double columns. It is related to buildings but some of same theories can be applied to pipe rack design too. https://www.aisc.org/globalassets/modern-steel/ste...
RE: Piperack Design
RE: Piperack Design
Petrochem very seldom requires any PE stamps. Nonpublic structures on private property, highly restricted access. Once during the occasional blue moon you might see a stamp on structural dwgs, most likely because some guy just got his PE and wants to see how many drawings he can stamp and sign at one sitting. ASME stamps are on the pressure vessels, etc. The only saving grace for structural engineers is that petrochem plants usually go down for some reason other than structural faults. Can you imagine, saying "Ya I stamped the __________ (Bhopal, PiperAlpha, BP Texas City Refinery, fill in the blank) drawings". Once I stamped some site permit conceptual plot plan drawings for a town council meeting, but never anything else. Why take that liability away from the shareholders, if you don't have to.
RE: Piperack Design
RE: Piperack Design
RE: Piperack Design
RE: Piperack Design
Technology is stealing American jobs. Stop H1-Bs for robots.
RE: Piperack Design
RE: Piperack Design
If your pipe is large enough, it will send significant forces to the pipe T-support. However, Deflection isn't a bad thing, just make sure your anchors and overturning can withstand the lateral pipe friction force. Our piping engineers will send us a detailed document on how much force to add to the pipe support, and we add them as a live load. Keep in mind that there is no wind load reductions on the PIP. I think it is important to run ASCE 7 wind loads on large structures, to obtain a wind load reduction.
