Conversion for Continuous Loading
This is a basic question but for some reason it has me stumped. I am modeling a continuous load on a soil layer on a commercial FEA package. This is a plane strain problem where the layer is modelled 20m wide by 10m deep.
I am trying 2 variations with 0.2 m thickness and 1 m thickness. The load the software is applying is 1 kN/m/m for the 1m thickness variation. I would like to find an equivalent loading (i.e one which will give me equivalent stresses and strains throughout the layer) for the 0.2 m thickness case.
I am hesitating between using 0.2 kN/m/m and 5 kN/m/m. The reasoning behind these two numbers is either 1/0.2 = 5 or 1*0.2 = 0.2. Can anyone please explain what 1kN/m/m actually means? and how do we convert it for different thicknesses?
RE: Conversion for Continuous Loading
1 kN/m is the continuous load per 1 meter of thickness
1kN/m per 0.2 m of thickness is : 1 kN/m/0.2 m = 0.2 kN/m for every 0.2 m of thickness
You double-posted this question in the geotechnical threads also. Here is the answer I gave over there -
I am not familiar with your problem, but just looking at the units of the parameters, and if the relationship is linear, then I'd vote for the 0.2 kN/M/M.
Dave
Thaidavid
