Tube elbow standards, ASME B16.9
Is there a comparable standard to ASME B16.9 for butt-weld tube fittings (OD x wall thickness)? We have had issues in the past with vendors supplying incorrect tube fittings e.g. long vs short radius, different tangent lengths, etc. I am trying to avoid this by calling out a dimensional standard.
RE: Tube elbow standards, ASME B16.9
What exactly do you mean with tube fittings? Do you mean orbital welded tubing fittings? Since you're referring to butt-weld type Im assuming youre not looking for compression type fittings (e.g. Swagelok). ASME BPE defines butt weld type fittings which has dimensions that are in the tube range. Apart from that Im not aware of any other standard which does the same for tubing fittings. For simplicity Im assuming tubing goes up to 1".
Also, keep in mind B16.9 specifies, in general, main fitting dimensions for piping according B36.10/.19. ASME B16.25 specifies dimensions for welding ends based on various OD and wall thickness combinations.
Weldbend shows "Conforms to ASME B16.9 & ASTM A234 WPB", but I'm not sure what the second standard is- may address materials only. This is 1/2" and up pipe-size, generally.
