HSS Slip Connection
HSS Slip Connection
HSS Slip Connection
Anyone have a good detail for a HSS square tube to W Beam? I was thinking two knife plates and bolted with vertical elongated holes. less than 2K lateral load.
RE: HSS Slip Connection
What size beam and post? How much slip do yu need?
Is the HSS a beam and the W-section a girder? Tops at same elevation? What has led to the need for vertical slip?
Sounds to me like the HSS is a wind post, supported laterally at the top by a rafter. If so, the slotted connection is common and appropriate. Leave the bolts slightly loose and weld the nuts.
Yes, HSS wind column and a W beam. No more than 3/4" deflection in the beam. Post CL and Beam CL will be in same plane.
When space permits, we've gone so far as to provide a 4 sided pocket and omitted the bolt.
Can you use a through bolt at the HSS with clip angles/BAR stock welded to the overhead W Beam. The clip angles/BAR have the vertically slotted holes. Can provide shims to facilitate 'fit up'.
Dik
@ Dik, seems very similar to what I am proposing with just a single plate at the top and bolted.
OP: it's a good detail... I've used it lots of times with HSS and W sections. With W sections, single clip/BAR to web and no shims required. With HSS, double clip/BAR and shims. Through bolt can be threaded rod, fasteners to be finger tight and threads peened.
Dik
