API 5CT label 1 - table C.10
i'm new in API 5CT so i have some doubts about some points.
Looking at the tables of the annex C(example table c.10) first column is "Label 1" what that means? i suppose it is the OD.
If it is the OD we have to extrapolate the values for other OD not mention there?
And talking about this table C.10, for example label 1: 16. Impact test is only required for API connection BC and SC. So for other kind of connections it is not necesary to do the test?
I suppose that if we sell the pipe for stock coupling, my client have to tell us the king of connection they are have to do or just if they need impact properties verification. That's right?
thank you for your help.
RE: API 5CT label 1 - table C.10
