Timber pole retaining walls
RE: Timber pole retaining walls
The gravel is to help with drainage, thus decreasing the time the end of the pole is in contact with wet ground. No timber material, treated or naturally decay resistant, gives complete surety against rot. Another advantage is that the granular material can more readily be graded than the existing material to allow the poles to bear uniformly.
