Creation of surface for use in Contact Surfaces
Hello all.
I have this small problem.
I have the geometry you can see in the attached file. I created it by using the Merge/Cut instance for the 3 parts you can see. As a result, I got edges created on the Braces and thus it was easy to create surfaces for them.
However, I cannot figure out how to create a similar surface to the Chord of my geometry. The outmost goal is to create a surface conctact interaction and I need to create a similar surface on the chord.
The highlighted surface on the uploaded image belongs to the Brace. How can i copy the same surface to the chord?
I would appreciate any help.
