Loading customer defaults in draft
Hi All,
I've made changes in mij customer defaults. Colors of dimension lines and notes have changed.
When I like an old draft to have this new defaults I have to select the dimensions first and inherit the customer defaults. Then I have to select all notes and then inherit the customer defaults again.
Is it possible to inherit all the customer defaults in one go?
Lars
Lars
Lars
NX11.0.1.1 native
Solid Edge
Inventor
RE: Loading customer defaults in draft
Unfortunatly no
Didier Psaltopoulos
http://www.psi-cad.fr
Try google that.
Tomas
Thanx for the answer. Can you give me some pointers what to google for ?
Lars
Lars
NX11.0.1.1 native
Solid Edge
Inventor
Why do you need to select them separately? Why not select all the dimensions and notes at the same time and apply the customer default settings in one go?
www.nxjournaling.com
I'de like to select all (Views, Notes, labels, dimensions, etc.) and load the customer defaults.
I'm still looking for a function who does that in one go :)
Lars
Lars
NX11.0.1.1 native
Solid Edge
Inventor
