Catia VBA multi-fillet?
Hi everyone,
First of all, before anyone replies to this message: Thanks eng-tips! I've learned so much just by browsing through the existing forums. So many talented and generous people around here.
Here's what I'm trying to do.
I have a skin in CATIA that is like a saw-tooth kind of thing.
This skin is composed of about 3000 faces, all of them connected.
I'm trying to apply a fillet on all the top intersecting edges of a user value, and a different fillet on the bottom intersecting edges with another user input value.
Radius is the same for all top edges, and the same for all bottom edges.
I can't for the life of me find a VBA or CATScript way of selecting internal edges, putting them into an array and loop through.
I can for example search and select all edges on a solid and apply a fillet or chamfer via VBA.
Is it even possible to select only the internal edges ?
Any ideas?
RE: Catia VBA multi-fillet?
What about if you fillet surfaces number 3-4 , 6-7 , 9-10, 12-13 (you can find a pattern for those numbers)....counting from left...(of course, being sure that they have proper names, eventually rename them first in another macro).
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
So basically I would create a collection with said surfaces using a loop with a step 2 . Within that loop I could do the fillets, then come back, and with another loop do fillet1 + surface5 - apply second fillet - fillet2 + surface8 and so on.
Then third loop, do fillets with the fillets created, join, save.
Something along these lines? Feel free to suggest another approach, as your scripting knowledge is waaaaaaaay more advanced than mine.
For the time being I don't have another idea, I don't know how was created your geometry, another idea would be maybe you can check if some vertex has same coordinates and get their parents and fillet them?
Or if those lower edges are all of them co-planar...find a way to color them and select them in one shot by color....
I suppose in all cases it would be a long run...
Fernando
Here's what i came up with:
Waddaya think?
CODE --> CatVBA
Sub CATMain() CATIA.ActiveDocument.selection.Clear Dim PartDocumentDest As PartDocument Set PartDocumentDest = CATIA.ActiveDocument Dim PartDest As Part Set PartDest = PartDocumentDest.Part Dim hybridShapeFactory1 As HybridShapeFactory Set hybridShapeFactory1 = PartDest.HybridShapeFactory Set hybridBodies_srf = PartDest.HybridBodies Set hybridBody_srf = hybridBodies_srf.Add() hybridBody_srf.Name = "Fillet_Result" BottomRadius = InputBox("Enter Bottom radius", "Enter radius value in mm", 1) TopRadius = InputBox("Enter top radius", "Enter radius value in mm", 1) 'Collect Input_1 Dim vntTypes2(0) As Variant vntTypes2(0) = "BiDim" Set catSelectLine1 = CATIA.ActiveDocument.selection catSelectLine1.Clear Dim strSelectedItem As String strSelectedItem = catSelectLine1.SelectElement3(vntTypes2, "Select surfaces.", False, CATMultiSelTriggWhenUserValidatesSelection, False) 'strSelectedItem = catSelectLine1.Search "('Generative Shape Design'.Surface & Color='Dark Green'),scr" If (strSelectedItem = "Cancel") Then End Else Dim Line_Coll As New Collection For sCount = 1 To catSelectLine1.Count Line_Coll.Add catSelectLine1.selection.Item(sCount).Value Next End If 'Loop Bottom Fillet: For iInput = 1 To Line_Coll.Count Dim ref1 As Object Set ref1 = catSelectLine1.Item(iInput).Value Dim ref2 As Object Set ref2 = catSelectLine1.Item(iInput + 1).Value Set rf1 = PartDest.CreateReferenceFromObject(ref1) Set rf2 = PartDest.CreateReferenceFromObject(ref2) Dim hybridShapeFilletBiTangent1 As HybridShapeFilletBiTangent Set hybridShapeFilletBiTangent1 = hybridShapeFactory1.AddNewFilletBiTangent(rf1, rf2, BottomRadius, 1, 1, 1, 0) hybridShapeFactory1.GSMVisibility rf1, 0 hybridShapeFactory1.GSMVisibility rf2, 0 hybridBody_srf.AppendHybridShape hybridShapeFilletBiTangent1 hybridShapeFilletBiTangent1.Name = "Fillet_1" iInput = iInput + 1 Set rffil = PartDest.CreateReferenceFromObject(hybridShapeFilletBiTangent1) hybridShapeFactory1.GSMVisibility rffil, 0 Next PartDest.Update Dim catSelectsurf As selection Set catSelectsurf = PartDocumentDest.selection catSelectsurf.Search "Name=Fillet_1,all" Dim FillColl As New Collection For sCount2 = 1 To catSelectsurf.Count FillColl.Add catSelectsurf.selection.Item(sCount2).Value Next 'Invert Surfaces For iAxis = 1 To FillColl.Count Set refInv = PartDest.CreateReferenceFromObject(FillColl.Item(iAxis)) Set hybridShapeAxisToAxis1 = hybridShapeFactory1.AddNewInverse(refInv, -1) hybridBody_srf.AppendHybridShape hybridShapeAxisToAxis1 PartDest.InWorkObject = hybridShapeAxisToAxis1 hybridShapeAxisToAxis1.Name = "Inverse_2" Next PartDest.Update Dim catSelectsurf2 As selection Set catSelectsurf2 = PartDocumentDest.selection catSelectsurf2.Search "Name=Inverse_2,all" Dim FillColl2 As New Collection For sCount3 = 1 To catSelectsurf2.Count FillColl2.Add catSelectsurf2.selection.Item(sCount3).Value Next 'Loop Top Fillet: Dim ref3 As Object Set ref3 = catSelectsurf2.Item(1).Value On Error Resume Next For iInput2 = 1 To FillColl2.Count - 1 Dim ref4 As Object Set ref4 = catSelectsurf2.Item(iInput2 + 1).Value Set rf3 = PartDest.CreateReferenceFromObject(ref3) Set rf4 = PartDest.CreateReferenceFromObject(ref4) Dim hybridShapeFilletBiTangent2 As HybridShapeFilletBiTangent Set hybridShapeFilletBiTangent2 = hybridShapeFactory1.AddNewFilletBiTangent(rf3, rf4, TopRadius, 1, 1, 1, 0) hybridShapeFactory1.GSMVisibility rf3, 0 hybridShapeFactory1.GSMVisibility rf4, 0 hybridBody_srf.AppendHybridShape hybridShapeFilletBiTangent2 Set ref3 = hybridShapeFilletBiTangent2 Next CATIA.ActiveDocument.selection.Clear PartDest.Update End subRE: Catia VBA multi-fillet?
Fernando
