Exporting assemblies
Currently in Inventor, we export assemblies, mostly for analysis, in 2 ways.
Firstly by Pack and Go which basically is a refined Save As, creating a duplicate assembly
Secondly by creating a derived part. For analysis, this is typically done by deriving a fabrication assembly into a single part with each assembly component represented by a separate body. We also use derive to create mirrored assemblies.
As far as I can see the Clone command covers the Pack and Go functionality but I haven't (yet) found an equivalent to the derived part function.
Can anyone help?
Can anyone help?
Nick Green
Lead Design Engineer
IHC Engineering Business Ltd.
UK
RE: Exporting assemblies
- file -> export -> part...
- new part, specify part, choose save location and enter name for new part
- object selection -> all objects
- feature parameters -> remove parameters
- window select around all the bodies that you want to export
- OK
Similarly, the "export parasolid" function could be used instead; the parasolid could then be imported to a new part file. The component bodies would be converted to unparameterized bodies in the new file.www.nxjournaling.com
We have tried using derived parts in Inventor to reduce the number of parts being used by making fabrications into single parts; these were associative to reflect on-going design changes. WE have stopped doing this as while the part count went down, we just replaced an assembly of a few thousand parts with one very complicated part which ended up taking longer to process than the assembly.
Nick Green
UK
