Different thickness welds UT
Greetings group, I have a doubt about inspecting a butt weld of two steel plates of different thickness, I should evaluate using the lesser thickness first and then the greater, or should use only the greater thickness to evaluate the joint?
RE: Different thickness welds UT
It is difficult to give a specific answer if no code is referenced. However, generally speaking the acceptance criteria is based on the amplitude of the signal produced by a reflector (discontinuity). The larger the discontinuity, the higher the amplitude of the reflected signal. That being the premise, a reflective surface of 1/16 square inch will produce a signal with an amplitude of let's say 30% of the full display. A reflective surface of 1/8 square inch will double the amplitude (an increase of 6 dB)of the reflected signal. So, a rating of +3 may be the limit for 1/2 inch thick material. Whereas the acceptable rating for the 1/4 inch thick material may be +9 (increase of 6 db) indicating the acceptable size of the reflector is 1/2 of that for the 1/2 inch thick material.
Best regards - Al
Best regards - Al
