FE Civil Book - What is the best way to study?
Hey guys! I bought a book from PPI. The book is great and the material is helping me a lot, but I don't have much time to study with the book. Anyone have a better idea to study.
RE: FE Civil Book - What is the best way to study?
WabbabeSE is correct about NCEES's FE Reference Handbook. You can download it for free from NCEES. I printed the reference handbook so as to become intimately familiar with how it was set up and where things were located. Remember on the exam you will only have access to a PDF version of it though so get used to searching with adobe.
When studying, don't worry about any problem that takes more than 2-3 minutes to solve (this makes life a lot easier). Due to the time constraints, its seriously not possible to work problems that long. Just guess and move on. You can always come back if you finish.
The bulk of that exam is recognizing the topic presented in the question, and then knowing where to go in the reference book to find an equation. I found myself doing very little multi-step calcs. For the most part, it was find an equation and then plug and chug. You don't even have to make many unit conversions.
Also, many people are surprised to find out that you will not get pencil and paper for the exam. They give you a dry erase marker and 2-3 re-usable plastic sheets. I hated this, but there is nothing you can do about it. I practiced at home with a dry erase marker just to prepare myself. (If you sit down for the exam and your dry erase marker is old or running out of ink, then immediately ask the proctor for a new one before the exam even starts.)
Good luck!
Things change I guess...
Just know where the pertinent information is helps the most.
I had one general reference book that I used the most with all the subjects and equations contained in it. That was VERY helpful and time saving.
Mike McCann, PE, SE (WA)
Jeff
Pipe Stress Analysis Engineer
www.xceed-eng.com
So it is now a fully computer-administered exam and the "scratch" paper is dry-erase markers and plastic sheets. Opposing technologies! Well done NCEES.
I agree as well. With the searchable PDF available, it makes the exam a bit easier. But it is still good to go over the reference before the exam. Know the general layout.
I used the Lindberg review book, and one practice test from NCEES website. I found the practice test to be a bit more difficult than the exam, so if you can do that, you're probably good.
