Tank Dent Aceptance Criteria
Good Evening sirs,
what are the acceptance criteria for a tank vent?
During the construction, perhaps for a incorrect procedure welding of a stair support, we have suffered this distorsion.
thanks
regards
thanks
regards
RE: Tank Dent Aceptance Criteria
Maybe check Roark's to see if there are any calculations for plate stress with distortions. If there isn't, you may be able to figure out residual stress from the dent and then use that to figure out total plate stress while the tank is at normal/max operating conditions.
What is distorsion or do you mean distortion?
http://www.eng-tips.com/viewthread.cfm?qid=330996
Jeff
Pipe Stress Analysis Engineer
www.xceed-eng.com
