NX9 Journal - Import Two Part Files?
I have the below code to import a part file "Water_jet.prt" automatically. Is there a simple way to change this so it will import both "Water_jet.prt" and "Paintcode.prt" at the same time?
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Menu: File->Import->Part...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Import Part")
Dim partImporter1 As PartImporter
partImporter1 = workPart.ImportManager.CreatePartImporter()
partImporter1.FileName = "R:\hms_tools\NX9\Tooling\part\Notes\Water_jet.prt"
partImporter1.Scale = 1.0
partImporter1.CreateNamedGroup = False
partImporter1.ImportViews = False
partImporter1.ImportCamObjects = False
partImporter1.LayerOption = PartImporter.LayerOptionType.Work
partImporter1.DestinationCoordinateSystemSpecification = PartImporter.DestinationCoordinateSystemSpecificationType.Work
Dim element1 As Matrix3x3
element1.Xx = 1.0
element1.Xy = 0.0
element1.Xz = 0.0
element1.Yx = 0.0
element1.Yy = 1.0
element1.Yz = 0.0
element1.Zx = 0.0
element1.Zy = 0.0
element1.Zz = 1.0
Dim nXMatrix1 As NXMatrix
nXMatrix1 = workPart.NXMatrices.Create(element1)
partImporter1.DestinationCoordinateSystem = nXMatrix1
Dim destinationPoint1 As Point3d = New Point3d(0.0, 0.0, 0.0)
partImporter1.DestinationPoint = destinationPoint1
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Import Part Commit")
Dim nXObject1 As NXObject
nXObject1 = partImporter1.Commit()
theSession.DeleteUndoMark(markId2, Nothing)
partImporter1.Destroy()
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
RE: NX9 Journal - Import Two Part Files?
Take the part import code and turn it into a subroutine, call the subroutine with whatever parts are necessary in Sub Main. Below is a quickly put together, untested version:
CODE
Option Strict Off
Imports System
Imports NXOpen
Module Module71
    Sub Main(ByVal args() As String)
        ImportPart("R:\hms_tools\NX9\Tooling\part\Notes\Water_jet.prt")
        ImportPart("R:\hms_tools\NX9\Tooling\part\Notes\Paintcode.prt")
    End Sub
    Sub ImportPart(ByVal partPath As String)
        partImporter1 = Workpart.ImportManager.CreatePartImporter()
        partImporter1.FileName = partPath
        element1.Xx = 1.0
        element1.Xy = 0.0
        element1.Xz = 0.0
        element1.Yx = 0.0
        element1.Yy = 1.0
        element1.Yz = 0.0
        element1.Zx = 0.0
        element1.Zy = 0.0
        element1.Zz = 1.0
        nXMatrix1 = Workpart.NXMatrices.Create(element1)
    End Sub
End Module
www.nxjournaling.com
