Looking for a Parametric Gear file or Willingness to Create one
I am trying to license an invention to a company in Taiwan and they are using Creo 3.0. I have developed a clean parametric model in SolidWorks and want to get a Creo 3.0 version to send them to use.
Does someone have a parametric gear file they are willing to share? Input the number of teeth, pressure angle and module and get a true involute profile. There are other parameters, but these are the essential ones.
If not, I can show someone the technique I use in SolidWorks for them to generate a Creo equivalent.
Thanks in advance!!
- - -Updraft
Thanks in advance!!
- - -Updraft
RE: Looking for a Parametric Gear file or Willingness to Create one
If you are licensing the parametric gear generation Creo3 code, then you better be offering compensation to the person who develops the code for you.
Ben Loosli
