Material datasheet SA 278 class 50 and 60
Hi there
Can someone give me the ASME material datasheet of these two materials (ASME SA 278 class 50 and 60). I need these for an strenght calculation problem.
Many thanks in advance
RE: Material datasheet SA 278 class 50 and 60
http://www.red-bag.nl/engintools/material_properties.php
you should add your e-mail address
Leonard@thill.biz
www.thill.biz
you must use the values from ASME Sec II Part D or the construction code. There may be rare times that allow a Code Case or U-2.
