Problem with *.OBJ import
RE: Problem with *.OBJ import
An OBJ file won't be editable in Creo. If there is a problem importing it, it will likely need to be handled on the export generation side. Look at the options on the exporter and chose the oldest/least capable format. Creo won't do anything with texture mapping, for example.
