Which Screw stud to be used?
Hi All,
I need your help.
I have two 3mm steel sheet. I want to connect both of them with the screw stud.
Also I don't want the screw surface to protrude over the sheet on both sides.
Is there any self tapping screw studs available? if So can anyone help me with the Standard of screws? Is there any other best method ?
I need your help.
RE: Which Screw stud to be used?
- Double flush head rivets
- Press in PEMs
- Spot welds
Mike Halloran
Pembroke Pines, FL, USA
