Mould release agent
Mould release agent
We manufacture a Bonded Seal - rubber compound ( EPDM , Nitrile, etc) which is bonded to the inner diameter of a steel washer, to which a bonding agent has been earlier applied.
We use a variety of presses - Compression Transfer, Direct injection for instance.
Does the Forum have any experience of types of release spray for use on the press platens, that is not detrimental to the bonding action?
All advice gratefully received.
Thanks in advance
AlexEss
Thanks in advance
AlexEss
RE: Mould release agent
I think this is the mfgr.: http://www.franklynnusa.com/custom-formulated-mold...
Also, you might talk to the people at Lord Chemicals http://www.lord.com/LokRelease?types=ProductDetail...
Lord makes some of the most trusted bonding and release agents.
Good luck!
AlexEss
