Tests to be done on a Pump Before Installation
Hi Everyone
We opened a multi stage centrifugal pump and replaced the mechanical seal. Before installing the pump in the process, what kind of tests to be performed and is there any standard specifying about the test, parameters etc.,?
Oswald Vincent M.S Mech. Engg.
Keep Things Simple.
RE: Tests to be done on a Pump Before Installation
PS: Operating fluid is LPG
Keep Things Simple.
What do you wish to establish, performance - Q / H, efficiency, or simply to establish if the pump has been reassembled correctly?
Probably hidden inside the vendors maintenance manual, but for a mechanical seal it's really about the sealing and pressure containment.
@Artisi: to ensure the right assembly and to ensure the sealing.
@LittleInch: Manual says Hydrostatic test, but I want to know is the a standard available in API, NFPA, ADR etc.
Keep Things Simple.
For correct assembly / seal fittment you can only test 100% correct by running the pump in a test-rig.
Or if assembled by competent staff you probably need to accept that it is correct and monitor start-up for problems.
If repaired by the local cowboys you really need to evaluate competency and make a decision, but for me testing in a rig is the same as testing in-situ,unless of course the distance between the repair shop and the plant are a vast distance apart.
Bear in mind a hydro test will only test for casing leaks and possibly the seal/s.
@Artisi: Our people are qualified and have experience in assembling pump. But there is a person who is insisting to perform a test by running the pump at 30bar with Water. I need a standard to prove that such test is incorrect.
Keep Things Simple.
No standard that I am aware of that says no testing required.
If the one who is insisting has the authority to insist, seems you will have to test. Anyway, covers your arse if there is any problems on test or after re-instalation.
In the situation you describe, we would perform a low pressure air test in our shop before installing the pump. This is an internal policy with a procedure we developed ourselves. This is not required by any code or standard that I am aware of.
Johnny Pellin
We performed a Hydrostatic test at 30bar for 30mins, there was no leak and pump is installed and running successfully. Thanks everyone.
Keep Things Simple.
