Retrofit for Seismic
Is anyone aware of literature, documents or authorities that addresses reinforcing plain brick masonry buildings to provide seismic resistance? The area of the work is Canada, but any information would be appreciated. I already have masonry information from some masonry producers as well as the FEMA material.
Dik
RE: Retrofit for Seismic
I think FEMA 547 is your answer, used it to develop a retrofit design for reinforced masonry wall at nuclear power plant. Real fun considering radiological working environment and the fact that everything is through bolted to the masonry.
Jeff
Pipe Stress Analysis Engineer
www.xceed-eng.com
ASCE 41
ASCE 31
IEBC Chapter A1
City of Los Angeles IB/P/BC 2011-053
Thanks, Gentlemen... I have a copy of the FEMA document, will try to chase the others down. Can anyone suggest others? Is there a Canadian equivalent? New Zealand has some excellent information, also.
Dik
