Wiring PV inverters longer than maximum allowable cable length
I am new to MV photovoltaic inverter wiring.
I came to know that the cable length from inverter to distribution panel is limited by manufacturer recommendations (to limit capacitance connected to inverter electronics and thus the capacitive current and induced overvoltages at receiving end).
How to avoid this constraint? if for an installation, the inverter is located away from the distribution panel with a distance exceeding the maximum allowable distance?
I have noted that manufacturer recommend using a bigger CSA cable, however, this means a higher capacitance? *Confused*!! (I believe that the manufacturer looked at the voltage rise/buildup not the cable capacitance limitation).
Any clues?
Any clues?
RE: Wiring PV inverters longer than maximum allowable cable length
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
