Wf 4.0 versus Creo 3
We are in the process of upgrading.
Does CREO 3 perform better than WF 4 with the same hardware?
RE: Wf 4.0 versus Creo 3
If you had 32-bit OS, 4GB memory and a marginal graphics card with 512MB/1GB, Creo 3 will not run to your satisfaction.
IF you had a 64-bit OS, 16+GB memory and a high end Nvidia graphics card with 3/4GB, Creo 3 will only seem a little bit slower, if at all.
Ben Loosli
I was once led to believe that wf4 could not use all CPU cores whilst creo 3 makes use of multiple cores.
I reasoned out that provided the hardware is decent (Fujistu with xeon @ 2.8Ghz with Quadro k2000) creo would perform better on the same hardware, compared to wf4.
