Removing selection stickness from cam operation
Hello! Writing a short journal that would save screenshots for each tool movement in CAM operation. My main problem is that I don't know how to remove selection sickness from "NXOpen.CAM.CAMObject". here is the code below. Wanted this to work for any process, not just cavity milling as below. Thanks in advance.
CODE --> vb
Option Strict Off
Imports System
Imports System.Drawing
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
Dim kinematicConfigurator1 As NXOpen.SIM.KinematicConfigurator
kinematicConfigurator1 = workPart.KinematicConfigurator
Dim objects1(0) As NXOpen.CAM.CAMObject
Dim cavityMilling1 As NXOpen.CAM.CavityMilling = CType(workPart.CAMSetup.CAMOperationCollection.FindObject("CORNER_ROUGH"), NXOpen.CAM.CavityMilling)
objects1(0) = nCGroup1
Dim isvControlPanelBuilder1 As NXOpen.SIM.IsvControlPanelBuilder
isvControlPanelBuilder1 = kinematicConfigurator1.CreateIsvControlPanelBuilder(NXOpen.SIM.IsvControlPanelBuilder.VisualizationType.ToolPathSimulation, objects1)
isvControlPanelBuilder1.SetSingleStep(NXOpen.SIM.IsvControlPanelBuilder.SingleStepType.Block)
isvControlPanelBuilder1.SetSpeed(10)
Dim simulationOptionsBuilder1 As NXOpen.CAM.SimulationOptionsBuilder
simulationOptionsBuilder1 = isvControlPanelBuilder1.SimulationOptionsBuilder
Dim response1 As Integer
response1 = isvControlPanelBuilder1.SetShow3dMaterialRemoval(True)
isvControlPanelBuilder1.SingleStepForward()
        ExportScreenshot("C:\Users\capproj\Desktop\testfolder\NX_screenshot0001.png")
        ExportScreenshot("C:\Users\capproj\Desktop\testfolder\NX_screenshot0002.png")
        ExportScreenshot("C:\Users\capproj\Desktop\testfolder\NX_screenshot0003.png")
        ExportScreenshot("C:\Users\capproj\Desktop\testfolder\NX_screenshot0004.png")
        ExportScreenshot("C:\Users\capproj\Desktop\testfolder\NX_screenshot0005.png")
        ExportScreenshot("C:\Users\capproj\Desktop\testfolder\NX_screenshot0006.png")
End Sub
