Finding parent reused pattern for the part
I am using reuse pattern in the assembly and gathered option.
Sometimes, we need to update the old models which are not using gathered option.
If constraints are missing and some of the nuts and washers are collapsed, we need to find the parent pattern for that part
to correct the constraints.
But, we unable to find the exact reused pattern which is used to create the particular part.
For that, what we are using now is check one by one in all patterns by opening that and verify where the parts are highlighting.
My query is if it is possible to find out the parent reused pattern by the way we are using ‘center graph’,
it will make easy the correction.
Kindly give any idea.
Suresh
Suresh
