skew bridge
skew bridge
skew bridge
does anybody has an article or book that related to skew bridge?
thank
RE: skew bridge
What in particular are you looking at for skewed bridges?
RE: skew bridge
more about the skew bridge failure and what is the actual skew angle used in modelling skew bridge......thank
RE: skew bridge
Skew bridge failure?  Can you be more specific?  Do you mean rotation of exterior girders during pouring of the deck?  This can occur on heavily skewed bridges but is usually mitigated with needle beams.
The skew angle is measured by looking station ahead and turning clockwise until you intersect the centerline roadway/track/stream underneath.  Is this what you're asking?
It would be a help to those trying to answer your questions if you would explain your situation/problem more clearly.
RE: skew bridge
You can refer to the book "Bridge deck behaviour" by Hambly
