ASME material data
ASME material data
ASME material data
Hello there,
I want to produce my boilers from SA 275 class 50, but all my calcylations are in SA 275 class 60. Does this mean I have to recalculate them all. Or is it possible to use the old calculations which are all approved by NoBo.
Many thanks in advance
RE: ASME material data
You may be hard pressed to build anything out of SA-275 since this is a MT examination procedure. However,as an AI or PED Inspector I would require you to resubmit calcs. if you want to lower a stress value. If you wanted to raise it,we could talk.
Sorry about that the material should read SA 278 class 50 and 60. But I really want to know how I can get these material data sheet. With the strenght value's.
Oh- See ASME SecVIII Div1 Part UCI,Table UCI-23
