Stndard length tolerances for plastic profiles
If I have 5000mm long PEX pipe, should I put +-30 mm tolerance or not? What are standards for tolerances for plastic and other materials?
_____________________________
Enjoy your work and have fun!
RE: Stndard length tolerances for plastic profiles
For the extruded shape, the tolerance should be specified by the manufacturer or some industry spec.
Ben Loosli
looslib, it is not question of particular number, more like how to evade putting tolerances on all lengths by placing ISO standard in title block. I would like to know what ISO I can use for plastic as 2768 is too tight, we do not need to increase cost by requesting supplier to deliver plastic pipes with lengths tolerances by ISO 2768.
So is there any ISO that I can refer to, or just to make table with acceptable tolerances for pipe and place it next to title block?
There are local standards adopted by different countries. To the best of my knowledge, none of them go as far as 5000 mm nominal dimension range.
Using 2768-v for the tolerance class, the tolerance table only goes to 4m which is +/-8mm, so a 5m length would require you to apply your own tolerance.
Ben Loosli
Plastics piping systems — Plastics components — Determination of dimensions
Take closer look:
From ISO 2768-1, Paragraph 1 Scope:
"It applies to dimensions of parts that are produced by metal removal or parts that are formed from sheet metal"
