PMI from DWG part (master model based design) not visible on sheets...
I have model.prt and model-dwg1.prt. PMI that are made in model.prt are visible in sheets in model-dwg1.prt. I can not make visible PMI that are made in model-dwg1.prt modeling. Assuming that I am using only Top view for all PMI, how to make visible both PMI from model.prt and from model-dwg1.prt, in Top view that is placed on sheet in model-dwg1.prt?
_____________________________
Enjoy your work and have fun!
RE: PMI from DWG part (master model based design) not visible on sheets...
If the PMI was created in the -dwg file, make sure to select the -dwg file when placing a base view. NX defaults to adding a view from the master model, in which case the PMI won't be visible since it doesn't exist there.
www.nxjournaling.com
So, if you understand the cowski's answer, it's not possible to have all PMI in the same view
Didier Psaltopoulos
http://www.psi-cad.fr
It seam that it is not possible... I was hoping that it is. So If we have PMI from model and PMI from DWG file we need two views to show all PMI. I have to admit it is rare situation that I will have both, but it would be helpful if PMI can be inherited from both sources in one view.
