Trapezoidal sheeting as a protection against instability
Hi, I would like to discuss the verification of the stability of truss when the top bar is secured with trapezoidal steel sheet.
Verification methods are, for example, in EuroCode 3 1-3 and ECCS TC7 TWG 7.5.
Has anyone had contact with this issue and has a computational example?
Best regards!
Best regards!
RE: Trapezoidal sheeting as a protection against instability
Please check the following references regarding the stabilizing action of steel decking to the top flanges of steel beams:
- SCI P360 - section 3.12 and example 4 in Appendix A (found at the following link: http://www.steelconstruction.info/index.php?title=...)
- EN1993-1-1 BB.2.1(1)
- EN1993-1-3 10.1.1(10)
