Concrete Creep Coefficient
What is the normal range for concrete creep coefficient (sometimes called creep factor) as defined in EC2 Clause 7.4.3?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Concrete Creep Coefficient
The long term creep coefficient is just the basic coefficient multiplied by the final coefficient.
https://www.hindawi.com/journals/ace/2012/626592.f...
https://newtonexcelbach.wordpress.com/2017/04/06/r...
has a function that will return creep and shrinkage coefficients to AS 3600 or EC2. There can be quite large differences between the two.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Is there a main reason why AS3600 can be almost double the value of EC2?
I guess it could mainly be due to the local aggregates ?
I had a look at the AS3600 page 40, there is a factor dependent on the hypothesis thickness,
which seems significant.
If I design a 1-m width of a floor slab, should I use the full perimeter of the slab ? or just should use the sides which expose to the atmosphere (i.g. only top and bottom for calculation of perimeter "u") ?
