Coordination between Engineer and Draughtsman
Hi All,
I would like to ask how actually you coordinate between yourself and your draughtsman? How do you organize the project between you two? And how strict are you with the deadlines etc?
Thanks.
Thanks.
RE: Coordination between Engineer and Draughtsman
Cheers
Greg Locock
Now I have to admit that our industry was not like others since most work was simply updating what already existed or modifying some existing machine to meet a customers specific needs. In my nine years as designer/project engineer, I only worked on two large programs where we started from scratch. I also managed a couple of minor projects where we developed completely new machines, one of which we applied for and was issued a patent (US 4132320). My other patent was for adding a unique feature to an existing machine that was sufficient enough that a new patent could be applied for (US 3877592).
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
I've never understood a 1:1 engineer:designer ratio
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
2. Drafting is notified, creates a pretty print, and saves that to PLM.
3. I'm notified to review, review, and email markups as necessary.
4. Repeat 2&3 as necessary.
5. Once I approve, checking is notified for review.
6. They gripe about corporate drafting standards, sending markups as necessary.
7. Repeat 2-6 until both myself and checking are happy.
8. 16 other people input nonessential data into PLM about part/assembly packaging (ala shipping for parts sales), manufacturing/assembly details, etc.
9. Senior management sees enough boxes checked and blindly signs off.
Ive usually had a single draftsman for about every 10 engineers, no real need for much interaction aside from emails and edited/highlighted pdfs/screenshots for markups.
Twenty years ago, I oversaw the efforts of four designers, by uncovering their layouts at night and leaving notes and sketches, in what was a part time job for me. I was able to stop and chat for only a short time each day.
Starting ten years ago, whoever happens to sit in front of a CAD station is called an engineer,
without regard to education or skill. Some of them have an idea what they are doing. Their MBA bosses can't tell the difference.
Mike Halloran
Pembroke Pines, FL, USA
Are you?
As for the coordination, I have to go to the head of CADD in advance to see what his backup is and plan ahead a week or two, if possible, top have the information to draft to him for assignment when he has an opening in his schedule.
CADD is the bottleneck here and coordination helps, but the delay still happens.
Mike McCann, PE, SE (WA)
In the 1990's there was 1 to 2 engineers for every draftsman.
In the 2000's perhaps 3 to 4 engineers to one draftsman.
Currently all our engineers do our own drawings and details.
With BIM/Revit there's no better way. We have no drafting personnel...only engineers.
Having said that, when I do (did) use a draftsman:
Depends on the skill level of the drafter. If they are more of a tech, then they can many times put together pretty good initial plans and details on their own once briefed on the project.
If they are novices, then there may be more on-going hand-holding and actual sketches/redlines that need to be provided by the engineer.
Always looked at that as my job as the engineer to watch the pace and progress and work with the drafters on getting done on time....too broad of a question in that there are all sorts of schedules and all sorts of drafters with different speeds.
One thing I did find common is that new employee drafters tend to work very fast and get a lot done. As time progresses many (not all) slow down and pace themselves.
I used to count sand. Now I don't count at all.
I'm a pretty lousy Engineer though but hey, can't have everything.
I've tried delegating tasks on various occasions but they generally do a mediocre job and I spend as much time checking their work and giving them input and getting mediocre out put as it would typically take me to get on with it and turn out slightly less mediocre product.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Sadly the opposite is true as well, whoever sits in front of the PC is often called a draftsman without regard for education or skill. Most with engineering degrees have little clue what they are doing and their engineering managers cannot tell the difference.
We would take a fresh sheet and do a new layout incorporating the changes he had made. When that was satisfactory, we would do the first drawing.
Nowadays with cad you erase and re draw while the engineer watches. Or you send him/her a PDF which he scribbles on with red ink .You then change that to suit. Or the engineer draws the whole thing, gets what he/she wants then gives you the finished lousy looking drawing, and says make it look pretty . You do that , then do an interference check on all of the other drawings in the assembly and notify the engineer of the points where the parts will not fit. The engineer vomits red ink all over the drawings and hands them back to you.
B.E.
You are judged not by what you know, but by what you can do.
JAE, I'd like to know more...
How large is the firm? How difficult is it to switch between your engineer and draftsman hat? Do you find projects are generally more profitable as compared with using drafties? What are the downsides of your current arrangement?
Not a large firm (<30)
The design effort gets rather seamless at times. There is a gray fuzzy line between when design ends and drafting begins. Especially with BIM where the design decisions tend to happen much earlier in the process as the building is modeled out as to what it is (rather than sketched in rough idea-fashion and then designed later on). There are also a lot of analysis/design modeling that goes on at the same time as the BIM build model (think RISA Floor - to RISA 3D - to RISA Footing design and then convert over to Revit). Our engineers can draw as fast or faster than any draftsman I've ever worked with.
We think so. The issue with engineers doing their own drawing (modeling) is that you are paying a higher rate to draw vs. a lower rate draftsman. However, when you look at the alternative you have something like this:
1. Engineer sketches up the design or the draftsman (if they are good) will set up plans and sections preliminarily.
2. Draftsman gives first take drawings to engineer.
3. Engineer reviews, calculates, designs, etc. the engineered element and hands back the information to the draftsman.
4. The draftsman draws it up and returns a copy to the engineer for "final" review.
5. The engineer redlines up the "final" and returns it to the draftsman.
6. The draftsman finishes up the redlines.
7. The engineer may re-check the "final" and there may be another cycle.
The back-and-forth of this takes a lot of time. Meeting and briefing the draftsman on the project takes time. When you add it all up you most times have more cost than just having the engineer do it all as a matter of a continuous process within one person's head.
The only thing I can think of is that it seems as though it is more difficult to have more than one engineer working on a project at a time. I think this is more due to Revit/BIM though and not the engineer-draftsman issue.
I'll add some upsides to the arrangement:
1. Quality assurance/quality control is much simpler and quality seems to me higher (comparing the years of working both systems)
2. The engineers have a much more intimate knowledge of the engineered product and drawings.
3. I've seen over the years a lot of personnel conflicts between engineers and draftsman (especially with young engineers and older draftsman) that is avoided by using engineers in the drawing process.
4. Your firm is a leaner cost firm...not as many moving parts.
I'm currently looking into bringing myself up to speed in Revit (~3.5 years design experience). At first, I'd like to be able to do basic things such as note changes, adding/editing typical details, taking sections and drawing rebar/PT. Know any good beginner tutorials?
Take the rebar/PT drawing as an example, one can spend a few hours doing up a nice markup of the rebar/PT in Bluebeam which is then handed onto a draftsmen. This usually involves a few cycles of back & forth to get the drawing 'right.' Now wouldn't it be logical for younger, with <10 years experience who are good with software, to draw the rebar/PT directly in Revit? This method eliminates a whole lot time spent red penning drawings several times over.
Cheers
Greg Locock
That reminds me of when I first started writing G code, I would write the lines on an 8 1/2" x 11" pad , then hand them to a typist who typed the thing out on a teletype machine , They would not trust me to type them out on the machine myself.
B.E.
Thank goodness; I might otherwise be out of a job
TTFN (ta ta for now)
Irvine, CA
Siemens PLM:
UG/NX Museum:
Yeah, the managers like to say, "Just dust off XYZ proposal; it shouldn't take more than a few hours..."
But, just like resumes and cover letters, proposals do need considerable tailoring, so it's sometimes easier just to write the proposal directly to the subject matter.
Irvine, CA
Siemens PLM:
UG/NX Museum:
Like most decisions in life I would say that choosing the "best" process depends on the details of the task at hand. Sure, most engineers are plenty capable of creating a half decent print for simple parts given the usual 100+ classroom hours of GD&T. Give an engineer a complex part however and tell them the print has to meet a book of corporate drafting standards and the situation changes entirely, time lost due to markups, discussion, and correction is miniscule compared to time for print creation where the draftsman is much more efficient. Something else to consider if you are selling to repeat customers is the very real cost of lesser quality prints and models, its a pretty commonly tracked supplier quality metric today bc of this practice of combining roles. Should your combination engineer/draftsman release a couple bad prints to a customer you might regret not having the extra oversight that an experienced draftsman provides. In the same vein, not having separate engineering roles (analyst vs component design vs systems etc) often leads to the proverbial "jack of all trades, master of none" that's sadly common today due (I believe) to technology.
We could not just hire a draftsman to do what I do. He (she) would just be printing out blank sheets w/title blocks. Admittedly, a good draftsman can take a sketch and run with it but our stuff is all serial #1.
CWB1 - I think this brings up a good point. In your world - what you engineer and create may have vastly different drawing/modeling requirements than what my world has in doing structural building designs.
We just don't have that tight of requirements for drafting standards, layer setups, text fonts, etc. Our standards actually just come from we engineers who understand how to properly communicate a design to a contractor bidding and constructing the building. We can do it much faster I think than the option of back-and-forth interplay with a draftsman.
Having drawn it , who do you get to check it?
B.E.
If you have other draftsman checking other's drawings you still need to pay for engineers to check the design in any case.
What you say is true, The job of the drafting checker is not to second guess the engineering ( Although some of them do.) The Checkers job is to make sure Dimensions and tolerance stack ups work properly, that all words are spelled correctly, that material call outs are correct for the job, that the drawing has the correct revision number, and even that the drawing number is correct. In short they are an editor who's main function is to make sure the drawing leaves the office as a working document that can be read by a third party with no glaring typos or errors that prevent production of the part.
An old saying that is still true today is " The error is always, in the thing you, know, is absolutely correct.".
Since you are mostly involved in structural drawings, you would be more involved with steel and concrete sizes and sections. Most times I have been trying to put equipment into the structure.
I have had my times on a light table with 6 or 7 layers of mylar stacked up trying to snake a duct or chute down past machinery and other equipment avoiding columns and walls in the process. New CAD drafting programs like Revit take a lot of the heartburn out of stuff like that, But like any computer program it depends on the operator, Engineer or drafter.
B.E.
Hat tip to my old friend Reg who's no longer with us. He used to occasionally, and with some glee, point out design issues.
He also would occasionally leave off an arrow head on a leader - just to see if we would find it.
We do not have engineers do drafting, but I grew up on Revit (haha still relatively new to the Structural engineering world) and it feels like home to me. I can draft very quickly in Revit, but our draftspersons love to be in control on the revit model. You added one additional thing? Why didn't you tell me!!!! I can no longer properly layout my sheet!!!
You just broached a whole other subject, You added one additional thing? Why didn't you tell me!!!! I can no longer properly layout my sheet!!! Revision control, that deserves a post all on its own.
B.E.
Typically revisions are not a big deal for me in terms of formatting unless the project has already gone out for bid. Before then, it can be a free for all haha.
Either way if they generate change orders on stuff already out for bid , or actually under construction it is not good.
B.E.
In short, communication and control is the issue when it comes to the drafter/engineer relationship. Both better be good in order to be efficient! Otherwise, get to learning the CAD machine!
Irvine, CA
Siemens PLM:
UG/NX Museum:
