PDW reuse library
PDW reuse library
PDW reuse library
I thought that I did this before but I can't remember. When adding something out of the Metric library (ie a false body) but putting it into an inch file, I get the file is wrong units error.
Is there a setting so I can add Metric items to an inch file from the reuse library?
Brian Marchand-owner
BRM Design
NX 11.0
16G Ram - Nvidia Quadro K4000
Win 7 Pro x64
RE: PDW reuse library
It's not possible, but you can use the convert_mm programm before
Didier Psaltopoulos
http://www.psi-cad.fr
