Add studding pad
Add studding pad
I have a 10' diameter CS API 650 tank, flat bottom.
It's about 15 years old. Customer wants to put a 6"
studding pad (thru a vertical weld)located about 6" from
the bottom plate. There is no information on this type
of connection. Does it still need a repad added? Can it just
be welded in or should it be made part of an assembly?
RE: Add studding pad
Api just states repads based on nozzle size. So are you suggesting to use
maybe the ASME pressure vessel code method?
1. A repad. (5.7.2.3(b)
2. Excess shell thickness above the required shell thickness. (5.7.2.3(d)
3. Excess nozzle thickness above what is required in Table 5-4(b). (5.7.2.3(c) and 5.7.2.4)
Limits of reinforcement are provided as well. The procedure is similar to the ASME pressure vessel code procedure, but may have some small tweaks. I haven't done these calculations for a few years though. I believe the reinforcement limits for the nozzle are different for one.
These are more common on pressure vessels rather that API 650 style tanks.
MJCronin
Sr. Process Engineer
customer said that space was very limited but it seems like
a regular nozzle would have work? If I get more info, I'll
let you know.
