Inflow or Outflow of a Tank knowing the Volume
I'm trying to find the formula for the inflow rate or outflow rate of a cylinder tank knowing the Volume.
Look online and did not find much literature. Flowrate units should be Gal/Min.
RE: Inflow or Outflow of a Tank knowing the Volume
TTFN (ta ta for now)
Find the volume of the tank. One min later find the volume again.
The difference would tell you have many gallons you lost or gained in a min sample
or flow rate in Gallons/min.
