delivery pipe
delivery pipe
I have a 2'' gear pump.
Is it ok to use a 3'' delivery pipe or will it effect the Q because of less pressure?
Best Regards
Roman Katz
RE: delivery pipe
RE: delivery pipe
The only way in which potentially 3" delivery pipe would limit your flow is your extreme cases where you've been working with a system with much larger piping and changing your pipe size increases the system resistance to such a degree that you start overpressurizing your system and losing flow to the relief path. Slippage can also be a problem at higher discharge pressures, but will only be a fraction of the flow that you'll probably gain.
RE: delivery pipe
RE: delivery pipe
OP - please provide links to associated posts if they pertain to a similar system (or copy in the relevant information).
Edit: Just read your previous post - http://www.eng-tips.com/viewthread.cfm?qid=423001.
RE: delivery pipe
Best Regards
Roman Katz
RE: delivery pipe
I'm not sure you really grasped the nettle of what the other posts says as repeated by adam above.
Your gear pump at a fixed speed will try to flow virtually the same flow through it until it hits either the torque limit of the motor or excess power trip or the internal or external pressure relief limit.
How much flow you will get is dependent on these limits and the downstream system. A bigger pipe has, in general, less frictional resistance for the same flow rate. Your pump only sees the back pressure from the system. As the flow is essentially fixed, shaft power is proportional to pressure. Twice the pressure required to move the same flow, twice the shaft power required to do it.
does that make sense?
LI
RE: delivery pipe
This is a much lower viscosity oil (10 cst) so i believe it will work out.
Best Regards
Roman Katz
