SendKeys does not work on {ENTER} first action
Hi All...I created a simple VBA code to demonstrate the SendKeys command. However, when the very first camera name appears, the SendKeys {"ENTER"} command does not work. I have to manually press Enter key on the keyboard in order to have the loop to continue. SendKeys {"ENTER"} does work on 2nd camera display and after.
So, how could I make the first SendKeys {"ENTER"} command work?
Sub CAMERA()
'//// Display total number of cameras in active document
MsgBox CATIA.ActiveDocument.Cameras.Count
Dim oCamera3D As Camera3D
Dim CameraIdent
For CameraIdent = 1 To CATIA.ActiveDocument.Cameras.Count
Set oCamera3D = CATIA.ActiveDocument.Cameras.Item(CameraIdent)
MsgBox oCamera3D.Name '//// Display camera's name
CATIA.RefreshDisplay = True
SendKeys "{ENTER}"
Next
CATIA.StartCommand "Fit All In"
End Sub
Your help is much appreciated.
RE: SendKeys does not work on {ENTER} first action
does it work if you start your script with a shortcut instead of any other way?
I am looking for a solution on this problem...
Eric N.
what do you mean by " short-cut"?
After running the macro, it stops at "MsgBox oCamera3D.Name", then I have to manually press Enter key on the keyboard in order to have the loop to continue. SendKeys {"ENTER"} does work on 2nd camera display and after.
Any idea?
Sorry Ferdo.....
"...Create your own message box form." You mean use MSgBox command to create a message?
Thanks for your help
Hi Ferdo.... I am not sure how to start and make an user form since I have never done it before. Could it be made in VB Editor? IF so, how do I start?
this forum is for CATIA knowledge sharing, it really seems you should also join a VBA forum and search VBA answers there.
get a VBA programming book at the library or buy one.
I might seem rude but trust me I say that for your own good.
Eric N.
using Tools / customize you can assign a shortcut to your macro (many video on youtube about that)
Eric N.
