Trace off causes head to rise way high
Yea.. I was cutting some composite wood and needed the trace off but between each cut I had to lower it back to the material.. anybody know of a setting to stop that?
RE: Trace off causes head to rise way high
Did you set the thickness of wood in the cut conditions with trace off?
Yes sir
When you did the program did you do it if it was 1/2 steel so the M102 line looks like M102(HRS0.500) and than change the material thickness on the cut condition page to 1.00? Because we set up a wood condition that every time we cut a sheet the head would retract and never come down next thing you know the head is 2 inches off the sheet. The cause was it never gave me a good post some lines were missing like the M103 (pierce line).
I can't view the attachment, do you have a copy of the code?
sorry it posted my password up there lol. I ran it on our old aluminum setting with nitrogen cranked up
