pressure external surface complex geometry
In FEMAP
I have a complex geometry with many surfaces
Is there a quick way to quickly select all external surfaces? Instead of doing it one by one
RE: pressure external surface complex geometry
In the "Selector Mode" change from "Normal" to "Front", and then you should be able to select, with a rectangle, the external faces only
