Ug Nx- Features Suppressed by expression and features did not getting unsuppress
Hello all,
In Ug Nx. I Couldn't able to unsuppress the feature which is already suppressed by expression.
for example.
Step-1
I was applied a radius in one edge of a block.
Step-2
That radius was suppressed by expression.
Step-3
I want to bring back the original feature. I used to make unsuppress the radius. But not suppressed.
Any one can help to me the Why the feature is not getting "Unsuppress" which is already suppressed by expression.
Thanks & Regards
GurusamuelT
for example.
Step-1
Step-2
Step-3
Thanks & Regards
GurusamuelT
RE: Ug Nx- Features Suppressed by expression and features did not getting unsuppress
If you do not longer want to have the SuppressedByExpression, you first have to delete this SBE.
If you want to keep the SBE, you have not the possibility to do this "manualy"
Menu-Edit-Feature-SuppressByExpression-
Change the Expression Option to Delete Shared of Delete for Each, what you which to do and select your Radius.
Now you will be able to manually UnSuppress the Radius.
Br.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Thanks for your response to my query.
Ok. I understand Unless deleted that radius. There is no other way to remove expression without getting any effect to the suppressed features. Thanks for your help.
But still I have a one doubt. There is option shown in UG Nx. Edit features "unsuppress" I tried this option to make the unsuppress but nothing anything changes happen.
When we do the suppress by expression that's working fine but when we do the unsuppress the same thing why did not getting unsuppress.
Thank you Br.
Gurusamuel
