NX9 - Block UI Styler.
I have created a master model from which all the part, part drawings, and the assembly drawings are derived, Also the master model has been controlled using expressions.
I usually use the following way to update the master model.
Tools - Spreadsheet - Add-ins - Extract Exp - (update the necessary changes) - Update NX Part.
But now my customer needs some pop-up or wizard to do the same updates instead of the above method(Spreadsheet)...
I surfed some contents on the internet and ended up with something called Block UI.
Is it the correct solution for my issue or something else is there for this issue.
ponder
RE: NX9 - Block UI Styler.
Yes NXOpen and Block UI/winforms could be used to create a wizard, but I would instead take a hard long look at PTS - Product Template Studio.
Thank you petulf.
Since I don't have any programming knowledge, PTS seems to be a good idea.
But while opening the Product Template Studio, am getting the following error.
Java was not found using UGII_JAVA_HOME.
