Once off software for electronic mechanical engineering tools
Hi all,
I've been looking to see if there are any non-license required software that can help me in my job.
For example, perhaps some program that has all of ASME B16.5 and similar dimensions, pipe dimensions, ASME II-D etc.
The closest I've found is Abuden Toolbox but that I could only find it in Metric (unfortunately).
Otherwise are there any software that is useful in terms of what is described above (hopefully at a small cost).
RE: Once off software for electronic mechanical engineering tools
Mike
On Edit: You can most likely find older versions of B16.5. B16.9, etc, etc as PDF's thru a google search.
